Flowmaster Exhaust
Old 04-13-2009, 01:38 PM   #1
M3
Drives: 2002 BMW M3 Cabriolet
How Bulletproof should the SS 6-Speed Drivetrain Be?
I'm a noob, contemplating a Camaro. Have been looking at Challengers, and, I've heard good things about the Camaro SS, so, I'm checking it out.
I know about the Holden Platform that it's built on, and how well regarded it is. My question is regarding the entire Drivetrain. I'm not the type that wails on my Cars, but, I do put them thru the paces.
How tough is the 6-Speed, and the Independent Rear Axle, and all associated hardware? The Engine I'm assuming is pretty much bulletproof, what with Chevrolet's reputation for small block V8's.
What's routine maintinence on the 6-speed and the rear diff?
Thanks;
LJB
M3 is offline   Reply With Quote
Old 04-13-2009, 01:49 PM   #2
Douge
Eurotrash Connossieur
Drives: 1985 Mercedes 500SEL
Not to be captain obvious but it is essentially the same drivetrain as the Corvette. They are pretty rugged as the Corvette guys hammer on them pretty hard. Chevy trucks with small blocks go and go and go so I assume if you wanted to 250K is a pretty reasonable mileage goal for a Camaro. That would be my expectation.
2011 Camaro Convertible 2SS, Imperial Blue/Gray Silver Rally Stripes
Douge is offline   Reply With Quote
Old 04-13-2009, 01:49 PM   #3
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
The powertrain is pretty much right out of the Corvette; engine and transmission both...And the rear-end has been said to be good to 650hp.
I think "bulletproof" would be an understatement.
EDIT -- they did drive the test cars to 200,000+ miles...and they were still willing to go more.
Old 04-13-2009, 01:55 PM   #4
M3
What do you think Routine Maintinence on the 6-Speed Manual Trans & the Rear Diff is?
LJB
Old 04-13-2009, 02:01 PM   #5
Douge
LJB
Personally I would service the trans fluid at 60K ish although I can't tell you what GM recommends, might be lifetime fluid but I wouldn't buy that unless you are not keeping it more than a couple years.
I would expect the clutch to go 60-90K though I have heard much less and much more.
Old 04-13-2009, 02:02 PM   #6
Mr. Wyndham
LJB
None. Admittedly, I don't have much experience with rear-ends...but as for the transmission -- this is straight from General Motors:
The 6-speed uses Texaco ATF Type III 1863 fluid and is certified "fill-for-life," requiring no fluid changes. The clutch is activated hydraulically, which automatically compensates for clutch disc wear, eliminating manual adjustments. The Tremec TR6060 six-speed has evolved from a design that aimed to require virtually no maintenance in all but the most severe conditions.
Old 04-13-2009, 02:07 PM   #7
M3
Does the Trans have a Dipstick & a Drain in the Pan?
LJB
Old 04-13-2009, 02:22 PM   #8
TT C6
Banned
Drives: C6, 96 383ci Z28 hardtop
I would say the drivetrain is as close to bulletproof as a stock drivetrain gets.
Below is for the modders:
You guys are forgetting a MAJOR issue......WEIGHT.
The C6 weighs in around 3,200 lbs.
The Camaro SS is over 3,900lbs.
So, maybe the Corvette is "bulletproof". BUT, the Camaro SS is still unproven.
Case in point, look at how the "Corvette" drivetrain is holding up in the Trailblazer SS. The auto trans (sprag) has been a issue in the STOCK TBSS.
TT C6 is offline   Reply With Quote
Old 04-13-2009, 02:24 PM   #9
Number 3
Hail to the King baby!
Number 3's Avatar
Drives: '16 ATS 2.0T & '17 Buick LaCrose
So, maybe the Corvette is "bulletproof". but the Camaro needs to be proven.
4 Speed in the Trailblazer, new 6 speed in the Camaro.
"Speed, it seems to me, provides the one genuinely modern pleasure." - Aldous Huxley Link to Every Camaro photo I've taken in Hi-Resolution
Old 04-13-2009, 02:37 PM   #10
TT C6
Banned
I know, bro.
But, you should know that was the Corvette trans until 2006.
I only used it as an example for Corvette drivetrain in a heavier vehicle.
Old 04-13-2009, 03:21 PM   #11
Chevyrocker
Weekend Rockstar
Chevyrocker's Avatar
Drives: Depends on the day...
***Fill for life translates to 100,000 miles...FYI
Shortcuts can slow you down...
Chevyrocker is offline   Reply With Quote
Old 04-13-2009, 03:26 PM   #12
etrigan
etrigan's Avatar
Drives: 2010 2SS/RS Black Camaro
Transmission fluid in a manual transmission? Really?
"No matter where you go, there you are."
-B.B.
VIN #2G1FT1EW6A9106795
1100, Preliminary order accepted:10/13/08
6000, Del. to me:5/20/09
etrigan is offline   Reply With Quote
Old 04-13-2009, 03:33 PM   #13
CDBiker220
Drives: 98 camaro z28
The transmission is rated to 650 ftlbs of torque, so I think its good for awhile, the IRS still needs to be proven but like stated will probably be good till 600ish hp
CDBiker220 is offline   Reply With Quote
Old 04-13-2009, 04:06 PM   #14
M3
Sounds like they're pretty overbuilt.
Good. I Like Overkill. Hence, I'm looking at a Camaro SS...
LJB
camaro ss vs cobalt ss pandalove182 4th Generation Camaros 26 06-27-2011 03:13 PM
I think Chevy just lost me on the SS... V6 for me. Supercoolyo Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 41 10-23-2008 08:38 PM
SS to be produced 1st? CWI 5th Gen Camaro SS LS LT General Discussions 21 10-18-2008 01:58 AM
rs ss??? CaptianSam Camaro Photos | Spyshots | Video | Media Gallery 17 10-15-2008 04:17 AM
