Cold Air Inductions
Old 11-25-2011, 04:44 PM   #1
insidethreat07
insidethreat07's Avatar
Drives: 2001 Camaro 3.8
Differential Question Need Help
I have an 01 V6 with an open differential. I have a 3 series gear (3.42) and a 4 channel (has traction control). Now heres my question. Would a 3 series posi unit and a 3 channel (with out traction control) fir in my rear end with out any problems? Im debating on buying it for $125 shipped. So I need some input ASAP. Thanks a lot. Derek
2001 Camaro V6
2016 Camaro 2SS
insidethreat07 is offline   Reply With Quote
Old 11-25-2011, 05:55 PM   #2
insidethreat07
Here is the email he sent me
The posi that I am selling is originally out of a 3 channel rearend and will also work in a 4 channel rearend housing
You can't put a posi from your 4 channel housing into a 3 channel housing,
but you can put a 3 channel posi into a 4 channel housing because the sensors are
on the ends and by using my 3 channel posi you don't change any of that.
2001 Camaro V6
2016 Camaro 2SS
Custom wheel offset question ... Bowtie Junkman Wheels and Tires Talk Sponsored by The Tire Rack 4 04-23-2010 06:16 PM
open differential question jleinaweaver V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 2 02-18-2010 01:04 PM
Question Involving 4.10 gears & Bushings Deric884 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 1 02-13-2010 07:53 AM
Limited Slip Differential question jrcase V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 2 01-31-2010 06:03 PM
Differential Question TheMadHatter99 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 32 02-19-2009 09:16 PM
