Camaro DIY & HOW-TO instructions & discussions All DIY projects & discussions
Old 01-01-2012, 06:29 PM   #626
sene
Drives: 2011 Summit White 2LS
Originally Posted by 2SSRS View Post
Dont wast your time buying a new switch there is a lot more involved, it has more to do with the BCM then a switch.
What if I was to conceal a regular auxilary switch behind the OEM switch. So I push in the stock GM switch which in turn physically pushes an auxilary switch that's mounted behind it and activates the fogs? Is there room behind the dash for something like that?
sene is offline   Reply With Quote
Old 01-01-2012, 07:20 PM   #627
11 Camaro IBM
Drives: Camaro IBM
Should the painting cost more or less than the fascia? sene did the upper absorber and lower support fit? in the v6 thanks
11 Camaro IBM is offline   Reply With Quote
Old 01-01-2012, 07:31 PM   #628
sene
I paid $150 to get mine painted. I've been away from my camaro, and I haven't ordered the lower support yet.
Old 01-01-2012, 07:32 PM   #629
11 Camaro IBM
Drives: Camaro IBM
Thanks sene I'm still waiting on the parts to come in
Old 01-01-2012, 07:34 PM   #630
2SSRS
On a list for a 2014 Z28
2SSRS's Avatar
Drives: 2010 Camaro 2SS M6
Have you opened one up before? its all electrical in side there is no room for mechanical switch, The electrical switch sends a signal to the BCM to turn on the power, that is how it works, All the wires are the same if you have a camaro, So i need to test if at all times it sending a signal for the HID in my case and if so how to make a harness that i can make work.
More.
2SSRS is offline   Reply With Quote
Old 01-01-2012, 07:35 PM   #631
2SSRS
2SSRS's Avatar
How is that Guy and does he want a lot more bumpers to paint.
Old 01-01-2012, 07:43 PM   #632
iFast
iFast's Avatar
Drives: '10 Camaro SS/RS and '01 Bullitt
I'm probably going to go with something like this to solve the issue of how to wire up the second set of foglights:
http://www.ebay.com/itm/SMOKE-PROJEC...item53eac19924
This way all I have to do it pop in my current drl into the zl1 fascia then wire up the second fog lights separately. The given switch sucks. I'll probably scrap that switch for a different one that I can flush mount somewhere of my choosing.
Question: How do the drl and fog lights mount into the zl1 fascia. Is there some hardware that holds in place or do they just "pop" into place??
2010 Camaro 1SS. Halltech Intake. SLP Loudmouth I Exhaust. BMR 1.4''/1.0'' Lowering Springs. ZL-1 Front Fascia. NLP Rear Spoiler. 20'' TSW Nurburgring w/ Nitto Invos.
2001 DHG Bullitt Mustang GT. 5.0 Shortblock. Patriot cams and heads. Flowmaster Axle-Back, Magnaflow X-Pipe. Eibach sportline lowering springs. Steeda Tri-ax. 03-04 Cobra Front Fascia. 18'' XXR 521s w/ Sumitomo HTR Z IIs.
2007 Kawasaki ZX-10R. Akrapovic CF Slip-ons. K&N filter. 520 conversion w/ -1/+2 sprockets. Speedo-healer. Lockhart-Phillips fi controller. Pirelli DCIIIs.
iFast is offline   Reply With Quote
Old 01-01-2012, 07:44 PM   #633
11 Camaro IBM
Drives: Camaro IBM
Hey 2SSRS on my LS will I have to make a switch with the PNP your making or will all the lights just come on with the parking lights? Thanks
Old 01-01-2012, 07:50 PM   #634
2SSRS
2SSRS's Avatar
The fog pops in the DRL go to post 13 in the second illustration you need part #21 to hold them in.
I will make it both ways so let me know how you want it.
Old 01-01-2012, 07:55 PM   #635
11 Camaro IBM
Drives: Camaro IBM
Thanks 2SSRS I just like it simple so with the parking lights and what's your take on the radiator shroud do we need it?
Old 01-01-2012, 07:56 PM   #636
iFast
iFast's Avatar
Is it part number: 20957334 to hold the drl into the fascia? And where can I find that part? Can't find it online.
Old 01-01-2012, 08:02 PM   #637
sene
I didn't even know the part number for it Just working off my imagination and simplistic mind.
What if instead of the signal going to the BCM you routed it to a relay that activates the fogs?
Old 01-01-2012, 08:06 PM   #638
sene
I'll let you know when I pick up my car tomorrow but from the picture he sent me he does good quality work (had him also fill the holes in my trunk lid from my stock spoiler for the high wing spoiler install).
I'm sure he wouldn't say no to more work. How many did you have in mind?
Old 01-01-2012, 08:08 PM   #639
MValdez17
MValdez17's Avatar
Drives: 2010 Camaro 2SS/RS
If you want the Airflow to the engine that the ZL1 offers and the brake coolers than yes, you will have to get the inner fender liners for brake coolers too.
For the Air duct its part#10, and the side baffles Left#9, Right#9. Fan Shroud is on the back side of the Radiator.
2009 Yamaha R1
2011 Corvette Grand Sport
2010 2SS/RS Black & IOM Mods Here
MValdez17 is offline   Reply With Quote
Old 01-01-2012, 08:11 PM   #640
sene
Let me know if you find something that actually looks like it came from the factory. I cringe when I see cheap radio shack rocker switches on nice cars.
Old 01-01-2012, 08:16 PM   #641
11 Camaro IBM
Drives: Camaro IBM
AAC has those great looking lighted switches for their halos
Old 01-01-2012, 08:17 PM   #642
MValdez17
MValdez17's Avatar
AAC has those great looking laminated switches for their halos
http://www.automotivelightstore.com/...ingSwitch.aspx
Just what I was looking at! lol
2009 Yamaha R1
Old 01-01-2012, 08:28 PM   #643
2SSRS
2SSRS's Avatar
N.P. its all new to me too, that is why i want to see if in the right place on the BCM i can add the wire and the use the non RS switch and it will work.
I have my bumper and hood and new fenders too, if you want send me a pm after.
I don't think you need it this is why, The ZL1 has a intercooler and the parts are to flow air in to it, For a non intercooler car i see no need for the parts.
If it works i will post up.
Where do you install one if you have the HUD.
Old 01-01-2012, 08:29 PM   #644
sene
I think I'd have to see those mounted but I'm not liking the finish or the shape. It still doesn't look like "factory" enough
Old 01-01-2012, 08:33 PM   #645
11 Camaro IBM
Drives: Camaro IBM
I don't have an AAC switch I just thought they looked nice thanks for the info on the shroud less money to spend for such a cool mod
Old 01-01-2012, 08:34 PM   #646
MValdez17
MValdez17's Avatar
I don't like having switches shown in my interior unless it is factory. Even if this is what will be needed for the fog lights I will have it under my dash hidden.
2009 Yamaha R1
Old 01-01-2012, 08:47 PM   #647
MValdez17
MValdez17's Avatar
If you are wanting to have brake coolers they will be needed. But if you don't then use what you have currently.
I'm going this far putting the ZL1 bumper on and other parts needed, might as well do the other little stuff. More cool air to your engine is always a good thing! I will be supercharged soon this will be my set up.
2009 Yamaha R1
Old 01-01-2012, 08:49 PM   #648
11 Camaro IBM
Drives: Camaro IBM
Thats pretty cool have fun with the power
Old 01-01-2012, 08:58 PM   #649
sene
I wouldn't want to have to reach for a hidden switch just to turn on m fogs.
Here's one I found: http://www.jshmotors.com/jdm-dc2-int...witch_p304.php
Just disregard all the other rice stuff on there
Old 01-01-2012, 09:06 PM   #650
MValdez17
MValdez17's Avatar
I wouldn't have it completely hidden just mount it at the bottom of the knee bolster near the hood release. Arms reach.
You can probably find a GM one where it is not so long in the back like the Honda one shown.
http://www.ebay.com/itm/2007-09-SATU...item35b7a95bb3
2009 Yamaha R1
CAMARO WIKI Tran Wiki 43 06-05-2013 04:54 PM
Gran Turismo 5 November 24th, 2010 Nezacant Gaming Lounge 562 04-21-2011 09:23 PM
Winner, winner - Jalopnik compares the Big 3 Number 3 5th Gen Camaro SS LS LT General Discussions 31 04-17-2011 03:24 PM
Pedders Suspension Benchmark Track Testing and New Jersey Track Day Info@PeddersUSA.com USA - NY / NJ / PA 35 10-26-2009 05:20 PM
#4768 - Delivered and Made Ready the Right Way! Number_9 5th Gen Camaro SS LS LT General Discussions 62 07-16-2009 02:42 AM
