#2401 |
With them being so much, Im sure somebody will be making some aftermarket ones pretty quick.
No more ZL1 stamped in the hood LOL...
#2402 |
On a list for a 2014 Z28
![]() Drives: 2010 Camaro 2SS M6 Join Date: Oct 2008
Why, if i know you where going to do that i will get you one with some damage.
#2403 |
Brand new ones damaged? Just did not want to open the hood, and everyone point out that it says ZL1 on there.
#2404 |
Yes in shipping i got one with the rear tip smashed some not much, that is why i repacked it to ship.
#2405 | |
Checked all the wiring today all 4 lights are lighting up! Thank you for both harnesses! You made it easy! Also installed the brake coolers onto the lower grille. Monday I will put the car on the lift and see how the fitting goes for the lower air deflector/belly pan. Hoping to have everything painted on Friday. Pictures to follow!! Picture of first part of brake coolers on the grille. I attached some pictures of my P13 Plasmas. Instead of cutting the female connecter, I cut the bulb connector one it was pretty easy.
#2406 |
Good work, i did not have any P13 at the time.
#2407 |
Problem I have with the center air duct part. It doesn't have the mount to mount the air temperature sensor. I assume they are located somewhere else on the ZL1s I just can't find it in my parts book or software. Im thinking I can cut my old one off and plastic weld it on to the new center duct. Maybe you will have better luck finding it.
I also had to trim the left back corner slightly for it to fit properly.
#2408 | |
Crystal Red Tintcoat FTW
Drives: 2012 CRT 2SS/RS Beige interior Join Date: Oct 2011
I know I can get an aftermarket hood but I really want a steel or aluminum hood. Does anyone see a vendor making just the insert in the future? |
#2409 |
SoCal Mayhem
Drives: 2010 2SS/RS ABM Camaro A6 Join Date: May 2009
Ofer, i can't thank you enough for your help today!!!! i'm so happy with my car it's unbelievable. especially once i washed it!
#2410 |
SoCal C5 Family Member
Now go and do some Mayhem Ryan.
#2411 |
ABM ZL1 would be amazing
#2412 |
SoCal Mayhem
a few others stopped by and we all agreed on the same thing. they NEED to bring back a blue like this or ABM.
#2413 | |
Looks grate and thank you.
#2414 |
Lower air deflector/belly pan is installed now. I had to do some cutting so it can fit with my Kooks headers. I also had to drill some holes into the cradle then put screws to hold it in place. I thought it was going to be a direct fit, minus the cutting. I did not get pictures, but if I get it back on the lift ill snap a few pictures.
Going to spray the underside of the hood tomorrow IOM.
#2415 |
NOW CAMMED & SUPERCHARGED
Drives: 2010 Camaro 2SS/RS Black w/ IOM Join Date: Oct 2008
Pls provide details i have kooks as well!
Livernois Motorsports: Maggie 2300 7psi, Livernois 2C cam/L99 to LS3 Conversion, Ported TB, Rotofab w/adm race scoop, adm trans cooler,Kooks headers no cats, Kooks 3" exhaust. METCO breather. Precision 2400 Vigilante TC. Eibach Lowering Springs & Swaybars. BMR Trailing arms, BMR Rear Cradle Bushings, BMR Toe Rods, BMR Differential bushings. Vossen CV3 20's w/ 305 Nitto 555R@25psi. Zl1 front bumper. OE Zl1 Hood and matte black insert. 556RWHP/500RWTQ L99
#2416 |
![]() Drives: 2ss camaro 2010 Join Date: Jan 2011
ZL1 INSERT FEELER
having my fiberglass guy about to make a mold for the zl1 insert slightly different any intrest please pm me
#2417 |
![]() ![]() Drives: 2011 Summit White 2LS Join Date: Jun 2011
#2418 | |
![]() ![]() Drives: 85 Vette, 07 Escalade ESV, 03 GMC, Join Date: Nov 2009
How slightly different is this going to be? There are quite a few waiting for alternatives to the expensive OEM's CF inserts. Want mine to clear a Maggie
ADM Performance installed and tuned: Maggie, Stainless Works Power LTs, ADM race cai, ADM ZL1 scoop Whiteside Customs Super Street 2 Package w/ coilovers BC Racing Coilovers and lowered, Whiteline Bushings & Swaybars MBRP catback exhaust, ZL1 bumper conversion, Drake billet shifter, Hurst paddles, NLP rear spoiler, OEM GFX, Vis Racing hood, ASA GT5 wheels |
#2419 |
SoCal Mayhem
Thanks bro! Those are stock RS headlights.
#2420 |
Im glad I went with the stock peice it is deff a nice one! I was able to get my insert to clear my maggie with just changing the coupler on my cai that comes off the throttle body. 40 dollar fix!
#2421 |
#2422 |
#2423 | |
. We ABMers would like to stay exclusive
#2424 |
I don't have the info, but from reading posts by 2SSRS, RAYS and JSHARP, the bottom parts of the insert (for channeling water forward to the radiator) at the throttle body needs about 0.5 to 1.0 inch????
#2425 |
Yes I would say an inch would be good. you just need to get your air intake tube going south asap when it comes off the lip of the throttle body. The quicker it dives the better clearance you will have. Then you fab up something on the other end to turn it back into the filter tube. I used two 45 degree couples one on each end and trimmed them to get it to dive quicker. So maybe more like a 50to60 degree coupler would be ideal.
| Thread Tools | |
| CAMARO WIKI | Tran | Wiki | 42 | 05-18-2013 09:32 AM |
| Gran Turismo 5 November 24th, 2010 | Nezacant | Gaming Lounge | 562 | 04-21-2011 09:23 PM |
| Winner, winner - Jalopnik compares the Big 3 | Number 3 | 5th Gen Camaro SS LS LT General Discussions | 31 | 04-17-2011 03:24 PM |
| Pedders Suspension Benchmark Track Testing and New Jersey Track Day | Info@PeddersUSA.com | USA - NY / NJ / PA | 35 | 10-26-2009 05:20 PM |
| #4768 - Delivered and Made Ready the Right Way! | Number_9 | 5th Gen Camaro SS LS LT General Discussions | 62 | 07-16-2009 02:42 AM |
