Apex Motorsports Washer Tank Relocation Kit & Air Scoop
By: SOPMOD & Billy Speed I have to apologize to Apex; I have been overwhelmed with my real job, car shows and starting a car club. Nevertheless, Chase sent me their Washer Tanker Relocation kit and Air Scoop last August. I finally got it installed today. The install was very straight forward and anyone with basic mechanical skills should be able to complete the install with ease.The car we used is a 2010 Camaro 1SS and already had a CAI previously installed. We also removed the front bumper cover in order to do some other work. While we had the bumper cover off, we also completed this review. The removal of the front bumper cover is not necessary to complete the install of this kit. ![]() The kit removed from the package * ![]() Once we had the car jacked up and wheels removed. It was necessary to remove the attached screws and push pins that retained the inner fender cover. Inner fender (wheel well) cover removal points. ![]() Once push pins and screws are removed the inner fender cover can be pulled back out of the way to allow access to accomplish the installation. * * ![]() This is the factory pump before removal * * ![]() Pump removal and draining of the tank. * * ![]() This is the area in the plastic shroud that needs to be removed. We used masking tape and made the cut with a wiz wheel. ![]() Making the cut with wiz wheel. Bumper cover is removed. This made it easier for us to photograph the install process. Note: This install does not require bumper cover removal. ![]() We used a hand file to clean the edges after we made the vertical and horizontal cuts. ![]() This is the scoop from the front, showing the two mounting locations. ![]() The new 2 quart tank mounted on the scoop and the factory pump is in place. ![]() Routing of the remote fill hose. We used zip ties to secure it outside of the CAI. ![]() We decided to mount the remote fill on the CAI as suggested in the instructions. The CAI was removed and marked for drilling locations. ![]() Drilling the mounting holes for remote fill.*** ![]() Once remote fill was mounted, we re-installed the CAI. ![]() This is what everything looks like after the installation is completed. Note: Bumper cover is removed for photos. The scoop also lines up well with Stillen air ducts. We did have to modify the scoop to clear the Stillen air ducts. This was a well thought out kit and I really think Apex knocked it out of the park! It was a very simple installation and only took about an hour to fully complete. Most anyone with basic mechanical skills should be able to accomplish this install with ease. We honestly did not find anything negative about the kit and found everything needed to complete the install was included in the kit. So if you have a CAI, this is a must do modification that is very reasonably priced. Contact Chase at Apex Motorsports for this kit and many other aftermarket components. They are truly a customer service oriented company that will go above and beyond to meet your needs. ![]() ![]() Phone: 502-930-APEX(2739) http://www.apex-speed.com/
XSPower Longtube + Catback "Engine to Tip" polished steel VMAX ported Throttle Body 160 degree thermostat Street Tune East Coast Supercharging Cold Air Inductions TRex Phantom Black Billet Grill. Upper and lower Custom Badging Lloyd Floors mats splash guards Underhood Engine bay done AAC LED mailslot strip lights Flowing Cheese Fondue waterfall in console Various food items to dip into warm cheese ![]() |
El Presidente (SJCC)
This was a great Mod!
Thanks "G" for getting it posted for me! SOPMOD...OUT!
You do not need a parachute to skydive. You only need a parachute to skydive twice. People sleep peacefully in their beds at night only because a soldier stands ready to do violence on their behalf. |
TK-421
Drives: 2012 2SS/RS Summit White #349 Join Date: Mar 2011
subscribed... i've been planning to installed mine since october.
2012 CAMARO 2SS/RS A6 L99, TPW 7-18-2011 FIRST PRODUCTION WEEK 2012 MODEL #349
"LIKE" me on my FACEBOOK page http://www.facebook.com/stormtroopercamaro2ssrs MY BUILD THREAD: http://www.camaro5.com/forums/showthread.php?t=209482 - COTW 6/25/13 |
TK-421
do you really need to take out the CAI to install this?
Only one nut to remove it after cover is off.
Makes it alot easier to drill the remote fill holes. I guess if you had a right angle drill you could do it in place? SOPMOD...OUT!
#6 |
That is an outstanding installation thread. Thank you for taking the time to put it together and posting it.
#7 |
1LT RS 2011 BLACK
Great DIY thread. My CAI w/ scoop is on the way and I appreciate all the info. I'm planning on using two jack stands. Will that work? Also, do I need a torque wrench for the wheel?
#8 |
Thank you for your order. Two is plenty. I definitely recommend getting one and torquing your wheels to spec.
#9 |
synergy2011
I have trouble getting the bracket and washer bolt to line up do I need to trim the plastic more or ?? Thanks
2011 synergy green ss/rs,rally stripes
#10 | |
![]() ![]() ![]() ![]() ![]() Drives: 2010 2SS RS M6 Join Date: Mar 2011
Traded-in car: K&N Typhoon intake, JBA Shorty headers, Solo mid-pipes/hi-flow cats, GMPP Track Pack axle-back, Vmax ported TB, Billet Custom catch can, billet tensioner pulley, Hines Hex Vents, Z/TA rear spoiler, ProCustom headlight covers, Drake black/riveted quarter window covers, GM satin fuel door, chrome and brushed caps/covers under the hood, EmblemPros underhood bowtie & fuel rail "Camaro" plates, chrome "SS" door kick-panels, chrome trunk latch plate & strut rods, Street Scene lower grille ducts w/LED lights, front bowtie-delete, Yates Performance pedals, 35% tint, etc.
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro LLT/RS Join Date: Apr 2012
Great write up! This will be a big help when I do this install next weekend!
#12 |
My Dream Car
Drives: 2011 SIM LS3 1SS Join Date: Jul 2009
Awesome write up' just got my parts and now I think I can do it myself
#13 |
#14 |
![]() ![]() Drives: 2010 camaro pace car, 2008 cts bl, Join Date: Jun 2011
What is the performance benefit of this? How many horses is it good for?
Mods, 2r max cam, ls3 conv,kooks lt w/hf cats,kooks street sleeper cat back with magnaflow res x-pipe, roto fab cai, v-max TB, vigilante 3700 stall, 3.70 LPE, 442hp/392tq, Mike Norris Tune 11.71@116.24 1.63 60' m&h DR's
| High IAT's vs. PERFORMANCE | M6HuggerSS | Forced Induction - V8 | 29 | 08-30-2011 02:19 PM |
| g5cr cai system anybody install or looking at one "pics" | camarossrs2150 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 41 | 07-14-2011 09:26 PM |
| Hot air Intakes -By Kenne bell | ADM PERFORMANCE | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 66 | 02-08-2011 09:33 PM |
| List of Intakes that will work with the TVS-2300 MagnaCharger | JJ2010 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 26 | 03-19-2010 03:11 AM |
| AirAid Cold Air Intake anyone? | FLYNNZL1 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 12 | 01-01-2010 10:05 PM |
