autoguy
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Sponsor Announcements / Giveaways / Contests
Sponsor Announcements / Giveaways / Contests Announcements, giveaways, and contests from our sponsors
Old 11-30-2011, 12:54 PM   #1
SC2150
SC2150's Avatar
Drives: 2001 Camaro SS
RX Oil Separating catchcan System Giveaway!!!
It's back!!!! Those that remember the last ones know the rules. This will run from today (11/30/2011) until Sat, Dec 24th at midnight. Any entries after that are not eligable. Your post in the thread is an entry. Only 1 entry per week. Make your entry informative if you already have one of the systems.
Sunday morning I will post the winer (selected my a random number generator).
If you already have a RX PCV oil separating system, you can choose a billet SC pulley, Tensioner pulley, or other RX product of similar value. If you are planning on buying one don't wait, we will refund you if you win. INCLUDING the VMax CNC ported throttle body!
Your choice of the single or the dual valve system:
What makes the RX performance
the most effective oil separating catchcan
on the market?
There are several factors that come into play to effectively remove & trap oil mist/vapors from the PCV flow.
1. Condensation
This is the most effective, and how most cans work (even an empty beer can will catch a good amount of oil of plumbed inline).
The vapors traveling through the can make contact with the outer (cooling) surface and the oil is condensed to droplets where they fall to the bottom of the can and are trapped for removal.
  1. Slowing the velocity of the flow in a large enough chamber to prevent these droplets from being carried through the can and into the intake manifold.
  2. The distance from the inlet to outlet of the RX can is nearly 9” where most cans are 1-1 1/2” which allows for oil pull-through as a good amount of the vapors just take the path of least resistance without a chance to cool, condense, and trap the oil droplets.
The larger of the Billet filter media cans works the best of that style with the smallest being the least effective due to the lack of area to allow the flow to slow enough for the droplets to fall out of suspension.
Lastly come the Ebay and other off-brands that are nothing more than an empty can wit 2 fittings attached. These WILL catch oil, but most comes in and right out the outlet, and the home depot/lowes air compressor plastic devices. They will again catch oil, but let far to much through.
The RX can has a perforated dispersion tune running down the center from the inlet that disperses the gasses to contact the most possible cooling/condensing surface, a diverter cylinder to further direct the vapors into the cooling chamber and away from the outlet, then it is large enough in area (nearly 1 qt) to allow the flow to slow enough to drop out of suspension, it then flows around an internal disc baffle system giving it one more surface to contact and cool and forces it to contact the outer cooling surface evenly before exiting through and integrated poly check valve to prevent any reversion.
Does that mean these other cans are junk? Absolutely not! Most are extremely high quality in construction & appearance, and DO catch most of the oil, so they should all be considered as good choices over nothing at all, and will prevent most of the issues oil in the intake air charge cause. So weigh the price and your goals in making your choice.
The RX can requires NO disassembly to clean. The filter media cans require disassemble & cleaning (including removing the mesh and cleaning it) every few days/weeks of use to be truly effective. The RX has a easy drain valve on the bottom and a remote 1' long drain hose to zip tie in place so you can simply put a drain pan under the car to catch it. No mess, No dis-assembly, and no internal cleaning needed ever.
The RX can is the ONLY can on the market with an integrated PCV/check valve to ensure the proper flow/metering that the LSX V8's require.
RX performance has the ONLY can specifically configured for forced induction applications with dual poly check valves integrated into the design, and the RX standard can is $139 (add $20 for FI) and the best tech support by email, PM. or phone nearly 24/7 and detailed application diagrams for most any car/motor/power adder combo.
Make sure to specify the make/model/year/motor/mods/and polished or the color desired.
Also, add $39 for the matching breather kit.
http://www.youtube.com/user/bbrunson.../2/6hDXTzByEyk
www.RevXtreme.com
941-721-1826
Turbo & Supercharging specialist
VMax porting development from the begining
RX Super Chiller
SC2150 is online now   Reply With Quote
Old 11-30-2011, 12:56 PM   #2
StellarAuto
StellarAuto's Avatar
Drives: 2010 Camaro 2SS
Cool. Have previous thread saved and expecting one from Santa!
C][SIGPIC] Going as fast as my accountant will let me!
StellarAuto is offline   Reply With Quote
Old 11-30-2011, 12:58 PM   #3
Birm
Birm's Avatar
Drives: FSP
Im in...please
Cammed, Slammed and Blown to Perfection
http://www.floridaspeedandpower.com/
Birm is offline   Reply With Quote
Old 11-30-2011, 12:59 PM   #4
SC2150
SC2150's Avatar
Have a top mount Super Charger? Below is what the intercooler can look like in a few thousand miles runnning w/out one. The varnish/residue buildup already has reduced the cooling ability and over time will restrict the flow as well.
www.RevXtreme.com
941-721-1826
RX Super Chiller
Old 11-30-2011, 12:59 PM   #5
SlowSS
SlowSS's Avatar
Drives: 2010 Camaro SS
In for the win!
SlowSS is offline   Reply With Quote
Old 11-30-2011, 01:01 PM   #6
philthy
philthy's Avatar
Drives: 1969 Chevelle/2010 Camaro 2LT
Pick me, pick me !! (please)
2LT Victory Red w/ Black leather interior, automatic trans, polished 19" wheels, R6P (Early Order)
Factory style spoiler, Magnaflow axleback exhaust with resonated x-pipe, Injen CAI, RX catchcan and breather, ABL dash mod,
Drake billet shifter with leather boot, GM splash guards, Toyo Proxes4 tires for summer, Blizzak tires with Moda rims for winter driving
Pre-ordered November 17, 2008
Delivered May 14, 2009
philthy is offline   Reply With Quote
Old 11-30-2011, 01:02 PM   #7
drakedgar
drakedgar's Avatar
Drives: Camaro
I'm in!
drakedgar is offline   Reply With Quote
Old 11-30-2011, 01:06 PM   #8
1COR.1:18
Whosoever Will
1COR.1:18's Avatar
Drives: 2010 1LT Victory Red
I'm in, Santa I want a RX Oil Separating catchcan System
1COR.1:18 is offline   Reply With Quote
Old 11-30-2011, 01:10 PM   #9
bee sting
bee sting's Avatar
Drives: 2010 2LT RS Yellow - Black Stripes
I'm in ! I personally have this on my.V6 along with the breather cap . Great system and have posted pics to prove the amount of oil this catch cam system has kept out of my intake !
Thanks again Tracy and hope to win some of your other products.
TEAM LLT
JBA Shorty Headers - VMax TB - Black Ice-Olator - Ported Intake Manifold - InJen CAI - MRT.V2 Axel Back- PFADT Lowering Springs
Build Thread-http://www.camaro5.com/forums/showthread.php?t=184272
bee sting is offline   Reply With Quote
Old 11-30-2011, 01:12 PM   #10
cyberLS
cyberLS's Avatar
Drives: 2010 Cyber Grey LS
in
cyberLS is online now   Reply With Quote
Old 11-30-2011, 01:18 PM   #11
tennyson1
Tennyson1
tennyson1's Avatar
Drives: Camaro
Im in....do want...
tennyson1 is offline   Reply With Quote
Old 11-30-2011, 01:37 PM   #12
The Stig
I used to be Stieger....
The Stig's Avatar
Drives: a PBM camaro
week #1
Stieger's BLACK Build Thread thanks for the sig Russ
Old 11-30-2011, 01:40 PM   #13
TOMSBLKV6
TOMSBLKV6's Avatar
Drives: 2012 black v6
Im in
TOMSBLKV6 is offline   Reply With Quote
Old 11-30-2011, 01:47 PM   #14
gorgeous-ss
Drives: 2011 ss/rs
I'm in I need one lol just took off my intake the other day and decided I need one
Sent from my Eris using Tapatalk
gorgeous-ss is offline   Reply With Quote
Old 11-30-2011, 01:47 PM   #15
blazzin1
blazzin1's Avatar
Drives: 2010 2SS/RS
I want one too please!!!!
blazzin1 is offline   Reply With Quote
Old 11-30-2011, 01:54 PM   #16
Harley1
Harley1's Avatar
Drives: Ahh....DCB F29
In please!
Harley1 is offline   Reply With Quote
Old 11-30-2011, 02:09 PM   #17
jasycz28
I don't understand
jasycz28's Avatar
I am in.
"JSick"
2010 Camaro 2SS
jasycz28 is offline   Reply With Quote
Old 11-30-2011, 02:12 PM   #18
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
I'm in
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, BMR Trailing & Toe Arms, full rear cradle & diff bushings, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, Hawk HPS Brake pads, GTO clutch reservoir, LS9 cam, Comp Cam valve springs, Melling 10296 oil pump, CR 5 timing chain, LS2 damper, CAI Cold Air Induction, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9 & 20x11 DS3 wheels with Pirelli Pzero 275/40/20 & 305/35/20 tires, '11 Convertible spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat, GM SS Fender & LS3 Emblems.
flht99b is online now   Reply With Quote
Old 11-30-2011, 02:12 PM   #19
lakersftbl69
lakersftbl69's Avatar
Drives: 2010 camaro 1ss/rs
Pick me please for the rjt catch can please please please
ordered dec 15 2008 picked up on june 8 2009.
upgrades kooks 1 3/4" LTH w/ high flow cats, roto fab cai, corsa exhaust, rx catch can, hurst short throw shifter. stage 3 comp cam, 3.91 gears 445rwhp 410 rwtq all installed and dyno tuned from slowhawk performance.
lakersftbl69 is offline   Reply With Quote
Old 11-30-2011, 02:12 PM   #20
steveo9043
steveo9043's Avatar
Drives: 2012 45th AE 2SS Coupe
I'm in! One of the first mods I wanted to do anyways.
steveo9043 is offline   Reply With Quote
Old 11-30-2011, 02:16 PM   #21
busabruce
busabruce's Avatar
Drives: 2010 GT500
I'm in!!
busabruce is offline   Reply With Quote
Old 11-30-2011, 02:20 PM   #22
justa25thTA
justa25thTA's Avatar
Drives: 2011 Camaro SS/RS LS3
I'm in, probably the only way I will get a catch can.
Yeah, I'll get around to it...
justa25thTA is offline   Reply With Quote
Old 11-30-2011, 02:27 PM   #23
rydahog
rydahog's Avatar
Drives: 2012 SS 45th..Auto
OK,,here is mine,, could use something new in engine compartment..
rydahog is offline   Reply With Quote
Old 11-30-2011, 02:35 PM   #24
Muscle SS
All blackkk
Drives: 2010 2SS/RS LS3
Hope it will look pretty under the hood
Drivin it like I stole it.
Muscle SS is offline   Reply With Quote
Old 11-30-2011, 02:35 PM   #25
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
Count me in for this!
The Few, The Proud, The Aqua Blue Metallics 709 of 3903 New England Camaro5 . My Camaro Journal
Heritage Grill, Cold Air Inductions Intake, Elite Engineering Catch Can, BMR 1" Lowering Springs, Sway Bars and End Links, Clear Image Jet Hot Ceramic Coated headers and High Flow Cats, Hurst Billet 2 Shifter, LSR Billet Strut Washers, DynoMax Axle Back Exhaust, JANNETTY MAGIC!
AFM turned off by my dealer???? fastfreddie 5th Gen Camaro SS LS LT General Discussions 95 08-25-2012 02:55 PM
The RX Catchcan PCV system giveaway!!! SC2150 Sponsor Announcements / Giveaways / Contests 291 12-28-2011 06:28 PM
