Solo Performance
Member Car Journals Want to keep a long term Camaro project journal to share with the community? Use this forum to create a single thread which you can update over time to document the progress.
Old 12-01-2011, 12:26 PM   #1
Agent Utah
Drives: '10 Camaro Victory Red
Arrow 900 HP Blown 429 Insanity! [COTW 4/30/12]
My '10 SS with just over 3,000 miles on it, was just not doing it for me power wise. I had a '68 in high school, and never really had the money to do what I wanted to with it.
I decided to do it right this time.
Here's the build sheet
(copy and pasted from the email the shop sent)
EnglandGreen Chaos F1R Package Stroker Package:
Use existing LS3 as core. Stroke motor to 429 cubic inch, 9.8:1 compression ratio
Callies Compstar crank
Callies Compstar rods
Diamond Pistons for forced induction applications
ACL/FM Rod, main, and cam bearings
Rear main seal
Rear cover gasket
Oil pan gasket
Valley cover gasket
Cylinder Heads:
Port existing cylinder heads
Upgrade valves
Head gaskets
ARP 12 pt. head studs
Morel lifters
Billet EnglandGreen Chaos 429ci F1R valve covers
Coil pack relocation and coil covers
Exhaust System:
Complete American Racing header system from engine to tips (with high flow cats), all stainless steel
Electric cutout system
Cam Package/Valvetrain:
High flow/High volume oil pump
160 degree thermostat
7.4 chromemoly hardened pushrods (upgrade to 3/8")
ATI SFI Balancer
Patriot Extreme dual valve springs with titanium retainers
Front cover gasket
Front cover seal
Oil pick up o-ring
Katech C5-R timing chain
Water pump gaskets EnglandGreen Chaos II camshaft ARP 12pt. Balancer bolt
ARP cam bolt kit
Cam sprocket
Yella Terra LS3 rocker arms
Induction System:
FAST 102 mm intake manifold for LS3 Powdercoat FAST to match customer car or customer's choice of color
FAST intake manifold port seals
V-Max ported LS3 (2010+) throttle body
Procharger System:
Procharger F1R Race Supercharger System Upgraded 1300HP intercooler
Polish supercharger head unit
Polish supercharger brackets
Fuel System:
Custom EnglandGreen 1300HP fuel system
Drivetrain:
McLeod RXT Twin Clutch GM Slave cylinder Remote bleeder
Pilot bearing
Flywheel bolts
DSS 2010 Camaro 1000HP Level 5 rear axles
RPM 3.91 ratio differential
Additional Items:
Dual nozzle Alky Control methanol kit
Tech AFZ Camaro heater hose relocation
Fluids
Break in miles on new motor, clutch, gears before final tuning
EnglandGreen Custom Street and Dyno tuning
Pics so far...
In addition to the list above, have also build the tranny, ordered up new suspension gear (coil overs, etc) Brembo slotted brake setup, upgraded the driveline and bumped the cam.
Shooting for 850 at the wheels.
Agent Utah is offline   Reply With Quote
Old 12-01-2011, 12:33 PM   #2
blake-b
blake-b's Avatar
Drives: Black 2010 2SS/RS LS3
Nice build. I don't think you will have any issues hitting your power goals. Is the F1R on there for mock-up purposes or is the engine being installed with it on?
Old 12-01-2011, 12:55 PM   #3
Stingr69
'69 Owned Since '79
Stingr69's Avatar
You need something to catch the driveshaft when it flys out.
-Mark.
Old 12-01-2011, 02:05 PM   #4
Nmbr1gmfan
Drives: Fast
Wrong gear.
http://www.youtube.com/watch?v=fPvVm...&feature=share
New and improved non-violation sig vid!!
Nmbr1gmfan is offline   Reply With Quote
Old 12-01-2011, 02:54 PM   #5
Agent Utah
Originally Posted by Nmbr1gmfan View Post
Wrong gear.
Old 12-01-2011, 02:58 PM   #6
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
Very nice! What expecting for horsepower/torque?
The Few, The Proud, The Aqua Blue Metallics 709 of 3903 New England Camaro5 . My Camaro Journal
Heritage Grill, Cold Air Inductions Intake, Elite Engineering Catch Can, BMR 1" Lowering Springs, Sway Bars and End Links, Clear Image Jet Hot Ceramic Coated headers and High Flow Cats, Hurst Billet 2 Shifter, LSR Billet Strut Washers, DynoMax Axle Back Exhaust, JANNETTY MAGIC!
Old 12-01-2011, 02:58 PM   #7
Squintz Palladoris
Squintz Palladoris's Avatar
Drives: 2010 IOM 1SS M6
Wrong gear.
Damn you must be phsycic.
He didn't list cam specs, tire size, or what type of racing if any he is doing. Where did you draw this conclusion?
Argent,
Definately looks like a nice build.
Squintz Palladoris is offline   Reply With Quote
Old 12-01-2011, 03:03 PM   #8
Agent Utah
Argent,
lol...
Nittos (stock rims) don't have the cam specs handy. I'll be using it just on the street, with a run on the dragstrip maybe 4-5 times a year. It's just the right gearing to get that heavy ass off the line..
Old 12-01-2011, 04:58 PM   #9
Squintz Palladoris
Originally Posted by Agent Utah View Post
lol...
Yeah you should be fine with that ratio. With a 28.7" tire you should be around 6500 RPM in 4th gear at 141 MPH. I will caution you about spending money on the stock diff though. With the manual trans you will be MUCH safer with a 9" setup or The LPE Diff. Less money in the long run.
Old 12-01-2011, 05:06 PM   #10
SSOOCH
"El Dictator"
SSOOCH's Avatar
Drives: 08 HHR SS, 2010 Camaro SS/RS #16429
Very nice Agent Utah. You should bring that thing to some of our events here in Utah. If you ever go to DYNO Days at JDP Motorsports in Sandy I'm pretty sure you'll win for highest RWHP when you're done building that thing.
Old 12-01-2011, 05:09 PM   #11
SSOOCH
"El Dictator"
SSOOCH's Avatar
When are we going to see that thing run at RMR or Track Days out at MMSP in Tooele?
Old 12-01-2011, 05:50 PM   #12
jrpxxii
jrpxxii's Avatar
Love the build but I would be worried with a LS3 stroked to 429ci with 9:8:1 and using LS3 heads with an F1R. The McLeod RXT is awesome but I am guessing it is only a matter of time before the trans fails without upgrading it as mine didnt last very long. I would highly recommend a driveshaft as well as you have put together a great build but the stock ds could cause some big issues if it comes apart. Good luck you are going to love the F1R.
Old 12-01-2011, 09:31 PM   #13
LSX-80MM
Ghostly Unknown
LSX-80MM's Avatar
Drives: Silver Ice 2010 SS/RS A6
Nice build...definately will need to do the 9" sooner or later,And I'd say bout 15lbs of boost and you'll be hitting your goal....keep us updated
416,GMPPLSX-LS3 6 Bolt Heads,Custom 80mmComp Turbo,ID850 Injectors Lonnies Twin Pump Setup,Circle D built 6l80eCircle D multi disc billet conv,3in Magnaflow Exhaust,CoolingMist Meth,RX Dual Catch Can,InnovateWB,AeroforceInterceptor,AEM Truboost Controller,matte black Forgestars.
LSX-80MM is offline   Reply With Quote
Old 12-01-2011, 11:28 PM   #14
Nmbr1gmfan
Drives: Fast
This thing will make tons of TQ, and will be happier pulling less gear. It will be fun cruising though.
Old 12-01-2011, 11:32 PM   #15
R.I.P. jesserayjames
Drives: 2010 IOM 2SSRS
wow, another Chevy monster to rule the dragways
2010 SSRS is online now   Reply With Quote
Old 12-02-2011, 01:41 AM   #16
Darth V8R
I'm on a horse
Darth V8R's Avatar
Looking great! Hope to see you at the track in '12
Darth V8R is offline   Reply With Quote
Old 12-02-2011, 07:33 AM   #17
old motorhead
Drives: Maggie blown LS3 vette
Isn't an LS3 with clean up bore and 4" stroke a 416 cid? Is this build using even more than a 4" stroke?
old motorhead is online now   Reply With Quote
Old 12-02-2011, 08:23 AM   #18
Agent Utah
Updated pics....
Old 12-02-2011, 08:24 AM   #19
Agent Utah
That's the plan. Haven't been to the dragstrip since High School. I'll for sure bring her out this year..
Old 12-02-2011, 08:25 AM   #20
Agent Utah
Agreed. I posted the original build sheet. But we have since ordered a built tranny, and upgraded the driveline.
Old 12-02-2011, 08:26 AM   #21
Agent Utah
Hell if I know.. lol
Old 12-02-2011, 08:31 AM   #22
YOUNGnRECKLESS
Building the Beast
YOUNGnRECKLESS's Avatar
Drives: 2010 VR LS3
awesome build...cant wait to see it done, especially since its a Victory Red!!! love the color matched FAST intake
YOUNGnRECKLESS is offline   Reply With Quote
Old 12-02-2011, 08:34 AM   #23
IPS Brandon
IPS Brandon's Avatar
Drives: 2010 Camaro SS black
Send a message via AIM to IPS Brandon
Did they sleeve that block?
IPS Brandon is offline   Reply With Quote
Old 12-02-2011, 09:20 AM   #24
Agent Utah
Thanks. Yeah, the intake turned out nice...
Old 12-02-2011, 04:15 PM   #25
JDP Tech
JDP Tech's Avatar
Drives: 2010 CGM Camaro 2SS/RS 429 LSX A6
Wow, very nice!
You'll have to swing it by here in Sandy when you bolt it all in so we can take a look!
What suspension parts did you order? You'll probably need some solid subframe mounts, solid engine mounts, trailing arms, toe links, and heavy duty axles to put even half that power safely to the ground!
Nice build so far!
Feel free to call, PM, or email us anytime!
- Jeremy
JDP Tech is offline   Reply With Quote
Blown LS3 in Sec. Gen carguy 1st & 2nd Generation Camaros 78 04-17-2012 04:13 PM
First Fire up... Blown 429 Agent Utah Forced Induction - V8 44 02-14-2012 07:21 PM
Rear stock speakers blown.. NoynuR Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 31 09-13-2011 03:25 PM
