Jason 98 TA
Old 12-01-2011, 03:15 PM   #1
collins motorsport
collins motorsport's Avatar
Drives: 1967 SS 785hp pro touring, 2012 ZL1
aftermarket pulley kit?
Worth it?
collins motorsport is offline   Reply With Quote
Old 12-01-2011, 03:20 PM   #2
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
SURE!!! There goes the warranty though? When doesn't adding a little boost to the OEM blower not add power? Yopu can't get crazy, though, without addressing IATs, fuel/spark/tuning, or the bottom end of the motor. The highest I've seen advertised has been 19psi through the OEM 1900, with all the supporting IAT mods' (no meth' or anything though, as far as I can tell), and H/C and bolt-ons. I'm not going that high, but I'm thinking about pushing boost and supporting IATs through to 600 RWHP with minor bolt-ons. I believe that should be pretty easy
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/Kooks 1 7/8" LTs and 3" H-pipe/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WB/ Pioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 12-01-2011, 03:24 PM   #3
collins motorsport
Well I mean Im not planning on going too crazy I have my 67 for that (actually considering supercharging it now that I mention it lol) but I would like to do some minor modifications to pull a little extra umph out of it.
Old 01-02-2012, 11:26 PM   #4
Speed74SS
Speed74SS's Avatar
Drives: 2010 LPE 650+ CTS-V
Originally Posted by UnleashedBeast View Post
Why did GM only use the 1.9L Eaton TVS supercharger on the ZL1? They used the 2.3L on the ZR1. I understand they have to keep the gap between the two cars, but darn...kinda fail.
2012 ZL1 6.2L with 1.9L TVS Eaton
2013 GT500 5.8L with 2.3L TVS Eaton
2007-2012 GT500 5.4L with 2.1L Roots Eaton
2003-2004 Cobra 4.6L with 1.9L Roots Eaton
Seems kinda backwards considering the more cubic inches an engine has, the more displacement required from a supercharger.
I have a custom built VMP TVS 2.3L on my 2009 5.4L engine.
You can get 650+ to the wheels with the 1.9L - if thats not enough then at some point you can throw a bigger blower on.
Speed74SS is offline   Reply With Quote
Old 01-03-2012, 02:30 PM   #5
gmgdave
gmgdave's Avatar
Drives: 12 ZL1 & 08 Suzuki Boulevard C50
I put a reduction pulley on my current car the weekend I brought home in 2005. Has not affected the warranty. I increases boost from about 11psi to 16psi. The only other thing I added was CAI. Never had a tune and it has not made a difference. Car has 33k now and runs like a champ. I have tracked the car and it does just great.
2012 ZL1 - #413 - IOM - Mods; Exhaust Commander. GMG Third Brake Light Pulsar, Tinted Windows, color matched Engine cover, ZL1 Floor Mats
gmgdave is offline   Reply With Quote
Old 01-03-2012, 08:25 PM   #6
htron50
htron50's Avatar
Drives: 2017 ZL1 Status "Thank You!"
I seriously think if you have a mechanical problem they WILL THROW THE FLAG AT YOU!
htron50 is offline   Reply With Quote
Old 01-03-2012, 09:30 PM   #7
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I believe that's with boost only. I swear another Cadillac tuner is above 700 with that tiny 1900 with supporting long block enhancements
Old 01-04-2012, 12:50 AM   #8
gmgdave
gmgdave's Avatar
Nope you are wrong. I have numerous friends that have done the same mods as I have. The dealer has performed all required maintenance and service. The Service Manager and even the Owner of the dealership are aware of the mods and still provide the service needed. My belt tensioner was part of a recall; they changed it and even put on a new belt, all under warranty. It all comes down to dealer relationship.
Old 01-04-2012, 09:09 AM   #9
Speed74SS
Speed74SS's Avatar
Smaller, less efficient blowers create more heat the faster you spin them. You begin to have IAT heat soak issues. It doesn't matter that the smaller blower can get you to the desired power level, as it's just going to produce a lot of HEAT doing it.
That is why you upgrade to a bigger & better Heat Exchanger & pump to keep the IAT's down. KD Innovations has one and it works great!!
Old 01-04-2012, 01:41 PM   #10
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
This I know, and we do this in GT500 land. Still, the larger blowers producing less heat require less heat removal from the bigger/better heat exchangers.
I'm not speaking on his behalf, but I believe he was just pointing out that 1900 is not peetered out on LSA in stock form and that there is still significant untapped potential left in it. Obvisously, the 2300 has a lot more in it (not to mention the even larger TSs and centrifi's), but there is also a sweet spot where all blowers operate and seeing as how the head and cam combination on LSA is not all that aggressive, 9.5 psi on the 1900 is not leaning on it too much, and we may not want to dismiss it so quick before taking it's potential into consideration. Personally, I was thinking about a 2300-LS9 swap, but I believe with some HE/IC mods', I think I'll be just fine running the OEM 1900 for where I want to be.
That's just me, though
Old 01-04-2012, 02:52 PM   #11
Speed74SS
Speed74SS's Avatar
I think you will be fine with pulleys / HX etc. I am at 540hp to the wheels with headers & CAI running about 7lbs of boost. I will let you know how it turns out when LPE gets done with it in March. We are doing a 2.55 upper & 9.17 lower with ported S/C snout and ID850 Injectors. This combo will provide a 38% overdrive which will provide maybe 6-7 lbs of boost back and hopefully hit close to 650 to the wheels. This is without changing the cam also. I will see where the IAT's are at and how she runs on the road track also. I am sure a bigger blower would be better on the IATs but if I can keep the stock charger and keep the IATs in check for 650hp, then I will be happy.
I am sure once the ZL1's hit the streets people will be tearing into them and getting great results - shouldn't be too long
Old 01-04-2012, 03:43 PM   #12
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
AWESOME!!! That's a combo' I'm contemplating, minus headers. I might go with some ARH-shorties because of CARB, but I'm looking at the pulleys and hoping for 600 to the ground. That will be plenty to keep me happy for as long as I can afford gas to fill the beast Please keep us posted, because what's going to work for you is going to work for us, too
Old 01-04-2012, 05:46 PM   #13
Speed74SS
Speed74SS's Avatar
Will do - can't wait to see you guys take delivery of the ZL1's also
Old 02-04-2012, 09:59 AM   #14
BLACK10
BLACK10's Avatar
Smaller pulley, meth injection, headers and a tune.........then you will have a beast
TVS2300 & 1900 Pulley Info & Size ... 8aStang Forced Induction - V8 17 06-11-2013 12:21 AM
SOLO Performance Camaro CONVERTIBLE Axle-Back Exhaust Kit GOINGSOLO2 V8 Bolt-Ons & Tunes 26 09-18-2012 01:15 PM
Just ordered Alky Meth Kit and 3.33 pulley! dmax86 Forced Induction - V8 0 02-08-2011 09:27 PM
ULTIMATE PERFORMANCE* TURBO Camaro SS -- 750hp Custom Single Turbo Kit (T04Z) Ultimate Performance Forced Induction - V8 496 10-11-2009 02:29 PM
2010 Camaro Fog/DRL Light 5202 HID kits .... HID_Guy Exterior Parts & Accessories 1 09-07-2009 01:19 PM
