Old 12-02-2011, 11:31 AM   #1
kiteman
Drives: 2012 45th Camaro, 2SS/M6
L99 vs. LS3
in no way am i trying to start any type of bash thread, but i really don't understand these two engines and/or why they were used. the LS3 has quite a bit more horsepower than the L99, but is the camaro with the L99 lighter or slower (stock) than the LS3? why couldn't GM incorporate the LS3 for the auto trans too?
kiteman is offline   Reply With Quote
Old 12-02-2011, 11:33 AM   #2
camslambam
Drives: 2010 SS, 06 SRT10 Ram
L99 is simply a restricted LS3. Smaller heads, crappier cam, horrible tune and shorter pistons.
Main reason for L99 was to avoid gas guzzler tax.
Tune an L99 and you have an LS3, just with an auto transmission which, in reality, makes it faster than an LS3.
L99 also have a bit more torque down low than the LS3.
camslambam is offline   Reply With Quote
Old 12-02-2011, 11:34 AM   #3
aet08
Drives: c
L99 has different lifters for the valves for the active fuel management, it disables 2 of the cylinders when under low load to increase MPG
aet08 is offline   Reply With Quote
Old 12-02-2011, 11:40 AM   #4
kiteman
but there is no gas guzzler tax on the ls3 either? is there? i sure as hell didn't pay any i don't think...
so let's just say stock for stock, is the ls3 still faster or is the l99 car actually lighter and they are comparable?
edit: i may have answered my question...i just found this:
Averages are fine, but the big difference is between the fastest LS3 and L99 stock.
12.58 compared to a 12.86. That's a world of difference.
Old 12-02-2011, 11:47 AM   #5
1Camaro2SS
1Camaro2SS's Avatar
Drives: 2010 2SS/RS L99
LS3 should have been used for autos period. GM screwed this one up. No need for L99.
432 RWHP 391 RWTQ 12.37 1/4 mile on stock tires
1Camaro2SS is offline   Reply With Quote
Old 12-02-2011, 11:57 AM   #6
cab2g
love. my. car.
cab2g's Avatar
Drives: 2011 2SS/RS
it's all about the gas guzzler tax. To be honest, reading the tax code, we should've been hit with it...
The IRS collects the tax directly from the manufacturer or importer of the vehicles. The following table shows the gas guzzler tax rates which have been in effect since January 1, 1991. The manufacturer or importer must pay this amount for each vehicle that does not meet the minimum fuel economy level of 22.5 mpg.
Combined fuel economy of: Amount
at least 22.5 mpg No tax
at least 21.5, but less than 22.5 mpg $1000
at least 20.5, but less than 21.5 mpg $1300
at least 19.5, but less than 20.5 mpg $1700
at least 18.5, but less than 19.5 mpg $2100
at least 17.5, but less than 18.5 mpg $2600
at least 16.5, but less than 17.5 mpg $3000
at least 15.5, but less than 16.5 mpg $3700
at least 14.5, but less than 15.5 mpg $4500
at least 13.5, but less than 14.5 mpg $5400
at least 12.5, but less than 13.5 mpg $6400
less than 12.5 mpg $7700
http://www.epa.gov/fueleconomy/guzzler/420f11033.htm
The 2010 Camaro SS manual and automatic have a combined fuel economy of 19MPG according to the EPA here (even the V6 should've gotten the tax @ 22MPG combined):
http://www.fueleconomy.gov/feg/Power...ro&srchtyp=ymm
GM either found a loophole, or is not passing the cost on to consumers outside of the MSRP like some manufacturers do.
cab2g is offline   Reply With Quote
Old 12-02-2011, 11:58 AM   #7
camslambam
L99 is a hell of an engine. The STOCK L99, yes is a screw up, but once you get it tuned, bolt ons and cammed then it is a nasty little bugger.
Old 12-02-2011, 11:59 AM   #8
camslambam
Stock for stock, if the LS3 driver can shift, the LS3 will win. This is expected... An L99 is simply a dumbed down LS3.
Old 12-02-2011, 12:04 PM   #9
kiteman
sure, understood. most people don't tune though, so that's good to know.
Old 12-02-2011, 12:11 PM   #10
MyIBMssRS
Drives: 10 IBM SS RS/14 1500 Z71
Active fuel management disables 4 cylinders.
MyIBMssRS is offline   Reply With Quote
Old 12-02-2011, 12:12 PM   #11
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
The L99 will shut down to 4 cylinders under light load, NOT 2. Tune it and it is fun as hell.
Scott@Bjorn3D is offline   Reply With Quote
Old 12-02-2011, 12:22 PM   #12
kiteman
tune is not that common of a thing though. seems crazy gm got away with charging more for a less powerful engine!
Old 12-02-2011, 12:44 PM   #13
JWoj3540
JWoj3540's Avatar
Drives: 2012 2SS/RS M6
The reason the L99 costs more is because an automatic transmission is much more costly to manufacture than a manual transmission...it's not because of the engine itself, although this may play some small factor.
JWoj3540 is offline   Reply With Quote
Old 12-02-2011, 12:48 PM   #14
daveagogo1
TRI COUNTY TAMPA
daveagogo1's Avatar
Drives: 2011 1SS/RS VR/BLK A6
The two have very little difference in the real world. The l99 is quicker off the line but a tad slower up top. This is why the avg quarter times are so close. They are pretty dead even overall.
Originally Posted by HufferSS View Post
Fast cars have rubber on the quarter panels...you sissies need to knock it off.
daveagogo1 is offline   Reply With Quote
Comprehensive L99 to LS3 conversion parts list DieselDork Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 17 03-05-2012 09:33 PM
LS3 engine specifications Tran Wiki 3 10-06-2010 11:56 PM
LS3 vs L99? SGOS252382 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 34 09-18-2010 04:55 PM
Watched a 2011 5.0 GT at the track. JJ#48Racing Chevy Camaro vs... 143 07-21-2010 07:56 PM
L99 engine specifications Tran Wiki 0 10-19-2008 12:40 PM
