Cold Air Inductions
Old 12-05-2011, 02:16 PM   #57
cjt037
boost+v6=me=:)
cjt037's Avatar
Drives: Turbo'd 6er
My cars stab messes up every know and then. When doing burnouts and such but for the most part I turn it half off
http://www.camaro5.com/forums/showthread.php?t=185528
435.7 RWHP 405 RWTQ
JUST A LITTLE V6... Try me
cjt037 is offline   Reply With Quote
Old 12-05-2011, 02:17 PM   #58
cjt037
boost+v6=me=:)
cjt037's Avatar
Drives: Turbo'd 6er
Originally Posted by puertoricanfont View Post
looking forward how you solved the fuel issue
We all my guess is remote injectors
435.7 RWHP 405 RWTQ
Old 12-05-2011, 02:43 PM   #59
Pt_killa
Pt_killa's Avatar
Drives: Black 2010 Camaro V6
Cool, is that your car in the avatar? If so it looks sick, how did you make the various engine bay parts glow like that! puertoricanfront and sixjax, you have some competition in the looks dept.
(Sold Sept 2015) Stock 18" Heritage w/ BFG G-Force ZR tires / Blacked out bowties and tail lights / DIY Remote-Mount Turbo Kit (Precision 6776S .81ar ex. @ 6.5psi, Tial 38mm WG, Greddy Type-S BOV) / RX Catch Can / RX-FTI 3600 Stall / Blue Well Lights / Team LLT
Pt_killa is offline   Reply With Quote
Old 12-05-2011, 02:53 PM   #60
cjt037
boost+v6=me=:)
cjt037's Avatar
Drives: Turbo'd 6er
Light bars two of them one in front of intercooler one behind bumper facing up
435.7 RWHP 405 RWTQ
Old 12-05-2011, 03:00 PM   #61
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
Originally Posted by SIXJAK View Post
Heeeeeeeyyyyyy, isn't your car stock?
Yeah, dont even know what modification means
Originally Posted by Pt_killa View Post
Yea the power is awesome lol the traction control goes haywire and stabilitrac shuts off if I stay on it for too long. Cj or grethen did your car do that when you hit it or held it at the track?
That is great to hear man! And you dont turn it all off? Or does the stab and TC go haywire with it all off.
If this is with it all on, turn all of it off and get us some new video
CAMARO
Old 12-05-2011, 05:29 PM   #62
puertoricanfont
Drives: 2016 scat pack charger
hey cut a college student some slack. Im broke for a while lol.
puertoricanfont is offline   Reply With Quote
Old 12-05-2011, 06:21 PM   #63
cjt037
boost+v6=me=:)
cjt037's Avatar
Drives: Turbo'd 6er
I have alot better pictures in Mt build thread
435.7 RWHP 405 RWTQ
Old 12-05-2011, 06:41 PM   #64
SC2150
For now we are using a modified top intake cover with 6 high impedance injectors spraying directly into the top of each intake runner with a stand alone controller that allows us to control fuel delivery to each cyliner, but the new heads Brodix is making for us will have an additional mounting boss cast in and machined allowing 2 of the OEM HPDI pumps to run off of the cam lobes that run the stock one with additional harness adaptors so it is plug & play all the way. Maintains the 2600#'s of pressure and provides all the fuel needed for 700 plus HP and no complicated wiring or controllers. Was to simple!
Old 12-05-2011, 07:01 PM   #65
cjt037
boost+v6=me=:)
cjt037's Avatar
Drives: Turbo'd 6er
This is very good to know
435.7 RWHP 405 RWTQ
Old 12-05-2011, 07:54 PM   #66
puertoricanfont
Old 12-05-2011, 08:50 PM   #67
Mach
Mach's Avatar
Drives: White M6 1LT RS
Good Job Tracy!!
Pfadt Sway Bars - FE3 Suspension - Barton Shifter - IdealG's Clutch Master Cylinder - Trifecta - Vmax TB - Vararam Intake - MACE 25mm Insulator - Plenum Insulator - Ported/Gasket Matched Intake Manifold - Rx Catchcan - AAC DRL's - 4 Pack Aux Gauges - Steering Controls - AAC Afterburners - DIY Led Sidemarkers - ZL1 Front End
Next mod: Done!
Mach is offline   Reply With Quote
Old 12-05-2011, 09:40 PM   #68
DarkneSS
Drives: 2010 Camaro 2SS/RS 6MT
Sooooooooooooooooooooo fueling issue is solved?
DarkneSS is offline   Reply With Quote
Old 12-05-2011, 09:56 PM   #69
Yellow_Glide
Yellow_Glide's Avatar
Drives: 2011 1LT "Chakita". 04 Yota
New heads, intakes, injectors, fuel pumps.... Just when I thought I had the parts list complete.
Hi, my name is Chakita. I have cams!!!!
Build thread: http://www.camaro5.com/forums/showthread.php?p=3847083
Yellow_Glide is offline   Reply With Quote
Old 12-05-2011, 10:15 PM   #70
blackTT600
Drives: 2011 2LT M6 SC
I just don't make enough $$ for you Tracy! Dam you are the man!
blackTT600 is offline   Reply With Quote
