Solo Performance
Old 12-03-2011, 09:46 PM   #1
mickey123456
Drives: 2012 ZL1
How will you upgrade your ZL1?
I'm thinking Hennessey or Lingenfelter.
Just wondering what everyone is planning! Please write the brands so that I can look up the part to maybe save some money instead of ordering a package from one of the companies mentioned above.
Thank You!!!!!
Mickey
mickey123456 is offline   Reply With Quote
Old 12-03-2011, 10:03 PM   #2
1st Gen Forever
ZL1 #140
1st Gen Forever's Avatar
Drives: Camaros: 68 SS, 10 2SS/RS, 12 ZL1
http://www.planetlsx.com/tech/How_To...009__CTS-V/146
This draws my attention...
1st Gen Forever is offline   Reply With Quote
Old 12-03-2011, 10:48 PM   #3
Blown355
Blown355's Avatar
Drives: 2017 ZL1 A10
Man, I really like that pulley!! Kinda expensive though.
2017 ZL1
A10
Redhot with stripe
Blown355 is offline   Reply With Quote
Old 12-03-2011, 11:39 PM   #4
Sesiom Summers
Drives: Camaro Z-28 2001 / 2015 50th GT
Send a message via MSN to Sesiom Summers
http://www.phastekperformance.com/20...-zl1-630hp.htm
I think this will be nice, but my father cant find a zl1 yet
Sesiom Summers is offline   Reply With Quote
Old 12-05-2011, 09:13 AM   #5
tsnow
tsnow's Avatar
Drives: 12' ZL1, AGM 6M
ADM for:
LS9 cam or similar grind with supporting hardware
pulleys to bring boost back to stock
thermostat
tune
ADM intake?
pull cats?
ported TB and blower snout?
crankcase evac system?
separate clutch fl. res. from brake master?
hopefully stock fuel system will support these mods.
tsnow is offline   Reply With Quote
Old 12-05-2011, 01:40 PM   #6
Sales@Hennessey
Sales@Hennessey's Avatar
Drives: 2010 Camaro
Send a message via AIM to Sales@Hennessey
Mickey,
Thank you for the email a few hours ago. We look forward to getting you the details on the complete parts and packages that we will be available for the ZL1.
Speak to you soon.
James
Sales@Hennessey is offline   Reply With Quote
Old 12-05-2011, 01:57 PM   #7
wontsellit
Drives: IOM
I thought this was supposed to be the perfect Camaro.Why would you need to upgrade?
wontsellit is offline   Reply With Quote
Old 12-05-2011, 11:31 PM   #8
oldfriend
Drives: Fiat 500 E
A set of 30'' front and 32 '' rears , how about that ?
Old 12-06-2011, 02:58 PM   #9
Scarrzz
No Fear-No Limits- Camaro
Scarrzz's Avatar
Drives: '13 ZL1 or Suzuki Hayabusa
I just threw up into my mouth.
__________________________________
................................................The Faithful are Watching.
Scarrzz is offline   Reply With Quote
Old 12-06-2011, 06:17 PM   #10
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
As far as power goes, I want to go stealth, so that means CAI and headers have to have CARB numbers; that pretty much eliminates all CAIs, so I will modify the OEM box if it seems necessary; I might replace the elbow with a solid metal or CF replacement tube like those sold by Lingenfelter or Hennessey. ARH just posted on theit CARB-pending shorties, so I'll be watching those. I'll eliminate any resonators and do the muffler mod' the 'Vette guys have been enjoying. I think I'll be upgrading the heat exchanger, too because I want to pulley-up boost to well into the mid-teens, and I don't want to run meth'. There's a lid spacer for 'Vs that I know of that I'll look into, though, ZL1's more efficient upper plenum might take care of that, to an extent anyways. That SuperChiller looks SWEET, too. If an H/E runs near the same, I might go that route instead, because it seems pretty effective. Down the road, I'll consider trying to hide a set of MAST splayed valve heads and LS9 cam
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/Kooks 1 7/8" LTs and 3" H-pipe/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WB/ Pioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 12-06-2011, 06:59 PM   #11
htron50
htron50's Avatar
Drives: 2017 ZL1 Status "Thank You!"
Catalytic Delete Issues
What are the problems with removing the cats? I am aware there are oxygen sensors fore and aft. I am in a state that does not do inspections. So thats not at issue.
What do you do about the oxygen sensors? What do you do to make up that space where it was removed from?
If you delete Cat converter, and have to retune, it may affect warranty.
What, how, and why?
Any info appreciated. I hate CATS anyway.
Sorry if I am uninformed on this.. but thanks!
htron50 is offline   Reply With Quote
Old 12-07-2011, 09:13 AM   #12
z28mass
z28 mass
z28mass's Avatar
Drives: 4 gen of camaros, 2012 ZL1 vin#1499
I am leaving mine alone. No updates for me. It will have plenty of power for me, if I wanted any mods I would keep my 2010 SS. Good luck to you people on your modifications.
z28mass is offline   Reply With Quote
Old 12-07-2011, 11:13 AM   #13
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
What, how, and why?
LB - removing cats' would require tuning to tell the PCM not to look for them anymore. The dealer, if they have to scan your PCM down the road, will send that PCM data, for warranty, to GM and they will see your reflash count is not what it's supposed to be and there could be a warranty situation (at least, that's my understanding, and I'm abbreviating a bit because I'm typing wit one hand, lol). I believe Solo has some aftermarket converters that aren't setting off the MIL indicator, so a retune may not be necessary. Eliminating cats' though, will turn the MIL ob, though :(
You need the cats' because the post-cat' O2 sensors are looking for different readings than the pre-cat' O2s, so you can't just leave them out because they will all will be reading the same and trip the MIL. You can eliminate them, so-to-speak, but GM can see how many reflashes you SHOULD have and if the counts don't jive, they're going to think you've had someone poking around in the PCM and if there is a warranty claim that is connected with that PCM, they might pull the plug. Sorry if this reads much like the prior paragraph but I needed to be more precise. Try those SOLO cats', or at least read-up on those in the LS3/L99 Section. The last I checked, they seemed to be doing the trick. It's also going depend on the design of ZL1's exhaust... Yet to be completely determined...
Old 12-07-2011, 05:43 PM   #14
KaotiK
KaotiK's Avatar
Drives: 2012 Camaro ZL1
Originally Posted by Sales@Hennessey View Post
Mickey,
Speak to you soon.
James
Wow, it's that easy to get a response from Hennessey!?! Im a big fan of Hennessey performance and have been following what you guys have been doing with the Cadillac CTS-V, most specifically the V700 upgrade.
My question is what kind of numbers are we looking at for the equivilent package (HPE-700) for the ZL1 seeing as how the base horsepower is already higher that the Caddy? Also do you guys have any Canadian dealers/installers for the HPE-700 package?
I am seriously debating having this package installed on my ZL1 either soon after it arrives or maybe the following summer! I guess that being said, is it best to do these types of performance mods right out of the gates, or wait one season till the motor is broke in?
Thanks for any info/help you can provide!
Cory
2012 ZL1 #478, BLACK, 6 SPD MANUAL, EXPOSED CARBON FIBER HOOD, BLACK 10 SPOKE WHEELS, SUNROOF, SUEDED APP. PACKAGE.
1000 Initial Order 11/29/2011Doug Marshall Chevrolet
1100 Order accepted at dealer: 11/29/2011 - QBFFHK
2000 Order accepted by GM: 01/24/2012
3000 Accepted By Production Control: 01/24/2012TPW - 03/05/2012
3100 Sequenced: 02/20/2012
3300 Scheduled For Production:02/20/2012
3400 Broadcast: 02/22/2012
3800 Produced: 03/07/2012
4000 Available To Ship: 03/07/2012
4200 Shipped: 04/05/2012
5000 Delivered To The Dealer: 04/13/2012
6000 Delivered To Customer: 04/19/2012
KaotiK is offline   Reply With Quote
Shno's House of Z Number 3 Camaro Z/28 Forum - Z/28 Specific Topics 17553 02-12-2018 03:59 PM
Little ZL1 GoldenBear Camaro ZL1 Forum - ZL1 Specific Topics 19 09-27-2011 09:38 PM
NEW Official Details on Camaro ZL1 -- 580hp / 556 lb-ft torque!! DarthNacho08 Camaro ZL1 Forum - ZL1 Specific Topics 420 09-27-2011 05:17 PM
Zl1 steering wheel upgrade formare Cosmetics and Lighting Modification Discussions 4 04-16-2011 03:40 PM
TR6060 upgrade for ZL1 ackeight V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 0 02-15-2011 12:58 PM
