Emblempros
Old 12-04-2011, 09:05 PM   #1
mikeSS
mikeSS's Avatar
Drives: 2015 c7
recommendations with my budget
budget is about 1500-2k. with a shop install
i 100% for want springs. the car is not a daily driver but is driven on Michigan roads which are bad. i don't mine the rough ride, but do not want drag setup.
my question is
would front/rear sways be a good thing with the springs ? i see so many other options like Trailing Arms also ?
thanks for help
Old 12-04-2011, 10:30 PM   #2
Info@PeddersUSA.com
Info@PeddersUSA.com's Avatar
Drives: 5th Gen Rental
You can get the Pedders Street 2 kit, add the sways to it, and you'd be about 1600, Install would put you over your budget, but not by much
Street 2 Kit
220032 Camaro Front Lowering Coils 2 Available
220033 Camaro Rear Lowering Coils 2 Available
EP1167 Zeta Differential Mounts 1 Available
EP1200 Camaro Rear Sub Frame Insert 1 Available
EP6578 Camaro Fnt Radius Rod Bush Ins 1 Available
PDUSACAMFULL Camaro Full Alignment Kit 1 Available
Solution B Sway Kit
423201210 Camaro Front Endlink - Pedders 1 Available
42601210 Camaro Rear Endlink - Pedders 1 Available
428020-27A Camaro Front Sway Bar 1 Available
429020-27A Camaro Rear Sway Bar 1 Available
I could also arrange for installation at one of our dealers near you if you wanted my help.
Info@PeddersUSA.com is offline   Reply With Quote
Old 12-05-2011, 01:00 AM   #3
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Springs and sways can easily be done in your garage. If you can't do the install, the Pfadt stage II is $600 and a decent shop should be able to install them in about 4hrs shop time. As Pete posted, the bushings are a great addition but it adds quite a bit to the install price.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 12-05-2011, 01:45 AM   #4
mikeSS
mikeSS's Avatar
Drives: 2015 c7
ya thats what i was thinking. the bushing were not really in the question because of install.
Old 12-05-2011, 01:49 AM   #5
mikeSS
mikeSS's Avatar
Drives: 2015 c7
Street 2 Kit
Solution B Sway Kit
thanks for info, what about just running sways plus springs?
Old 12-05-2011, 01:20 PM   #6
chrisp@lsrperformance.com
chrisp@lsrperformance.com's Avatar
Drives: 2010 yellow ss
my question is
thanks for help
We can get you this set up for less than your budget.
LSR Springs 793-8200
LSR front/rear sway bars 793-1052
LSR chrome moly control arms & toe links combo 793-4095
Energy suspension rear subframe bushing inserts 122-3-4168G
Give us a call. We can find a local dealer for you to do the install
chrisp@lsrperformance.com is offline   Reply With Quote
Old 12-05-2011, 05:08 PM   #7
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
For a daily driver with an aggressive stance and improved handling you should look at our Stage 2 package. Solidly in your budget, and offers a great balance. There is no better way to make your Camaro feel like it's dropped 400 pounds than installing one of our Sway bar packages. Bushings may not be absolutely necessary as you will love the improved handling after our Stage2 package.
Take a look at the video we made demonstrating the performance before and after the install. You can see the car moves from it's natural tendency to understeer to much more neutral... this transition makes the car much more fun to drive in all conditions!
Old 12-05-2011, 06:56 PM   #8
Info@PeddersUSA.com
it's doable, the Street 2 kit is discounted by 13% over the parts individually, so you save a bit doing them as a package.
The bushings will tighten up the feel of the car, if you want PM me and maybe i can work out a custom kit that might meet your needs better.
Old 12-05-2011, 10:47 PM   #9
Sawyer
Sawyer's Avatar
Drives: '13 5.0
Get a good set of coilovers. Go from there.
2013 Mustang GT Black M6
Sawyer is offline   Reply With Quote
Old 12-05-2011, 10:48 PM   #10
grundere1
grundere1's Avatar
Drives: 2013 Ford Explorer Sport Twin Turbo
Coilovers would be your best, get sways later in my opinion
LOOKING TO GET ANOTHER CAMARO Need to get back in the game.
grundere1 is offline   Reply With Quote
Old 12-06-2011, 10:28 AM   #11
axis
Search Ninja
axis's Avatar
I think you have that backwards. Sways are the bigger bang for better handling.
Halltech CF 102 fed
Old 12-06-2011, 10:32 AM   #12
Info@PeddersUSA.com
i'd have to disagree, for most the lowering of the COG along with the higher rates of the springs and the damping will be a bigger improvement over just sways, since most will not achieve the level of cornering to have the sways be a larger advantage.
Both are good though i would be likely to put the sub frame bushings high up on the list too.
Old 12-06-2011, 11:10 AM   #13
2010SSRSM6
2010SSRSM6's Avatar
There is a vendor on here selling Toe rod's and end links for $395 shipped to your door. You can pick up a set of springs and sway's for $500. Install time should be about 4 hours for all of it (@ $80 per hour = $320) You are looking at $1215 total.
I have one of Eibach's first kits for the Camaro and the ride is fairly stiff. If you are wanting a soft ride, you need to look at Coil Overs, not springs where most are for a cosmetic drop and not a softer ride. Plus, with drop springs, your keeping your factory struts in place and they are not working as intended anymore.
I'm upgrading to Coil Overs as soon as it makes sense from a $$$ standpoint. I've got $15k in go fast goodies to add first.
GL Mike
Old 12-06-2011, 11:57 PM   #14
JusticePete
VIR Specialist
JusticePete's Avatar
Drives: Camaro Justice
You are near one of the Best Chevrolet Dealers in the Country that are also Pedders Specialists Rodgers Chevrolet. Becky supports C5 and is THE person to see for a new or used Camaro. Gerry is the Service Director and LOVES doing special Camaro projects, especially Pedders.
BeckyD@RodgersChevrolet
(866) 468-5067
As far as quality, you can't do any better than Pedders. Don't take my word for it. Look at what Chevrolet did at SEMA this year. They had 22 cars in the Chevy 100the Year SEMA Celebration. 17 of those were on Pedders. I have a deal with GM. I buy GM cars. GM buys Pedders parts. Chevrolet showed 5 Camaros. two were on MRC and three were on Pedders. If you have seen a Camaro Pace Car on track at an INDY or NASCAR race you were watching a production Pace Car on Pedders suspension. Just like SEMA all those Pace cars were on Pedders parts GM purchased. The same is true for the Leno Camaro, Dale Jr's....
Contact Becky and talk to her about her Camaro Pace Car on a Pedders GMPP Pace Car Pedders Package. It is a bit higher than your budget, but the value is incredible. Becky is awesome. Tell her you would like first hand experience with a Pedderised Camaro. She has two of them. One on lowering coils and one on a Pace Car Package. One test drive will be all you need to determine which works best for you.
Caution: Test driving any Pedderised vehicle can be dangerous. Pedderised vehicles have been known to induce suspension envy and sleepless nights filled with longing. Before test-driving any Pedderised vehicle, check with your banking and accounting professionals. Pedderised vehicles are known to induce credit card bills and reduced bank balances. There is no antidote. Only genuine Pedders can cure Suspension Envy.
@@need cash for mods: fs: budget headunit, various amps, & subs!@@ theothermike Audio / Visual / Electronics/ Gauges / Nav 0 10-17-2011 07:57 AM
OBD-II Reader Recommendations? Don57 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 4 10-03-2010 05:30 AM
17 or 18 inch wheel recommendations for drag Dentyneice Wheels and Tires Talk Sponsored by The Tire Rack 5 06-12-2010 09:05 PM
Budget ackeight 5th Gen Camaro SS LS LT General Discussions 8 05-03-2010 03:45 PM
Opinions/Ideas for a friend on a budget :chevy: boomskeet Wheels and Tires Talk Sponsored by The Tire Rack 6 04-15-2010 02:09 AM
