HURST
Old 12-04-2011, 11:01 PM   #1
Ricky11SS
Ricky11SS's Avatar
Drives: 2011 Camaro SS L99
Exclamation thinking in a cam
ok hello this is my first time posting...
i have an 11 ss and its tuned and its completley stock ( just the muffler delete and x pipe)
i want to put a cam but i dont kno which one and how much would it cost?...
any answer would help alot plz thank u
Ricky11SS is offline   Reply With Quote
Old 12-04-2011, 11:05 PM   #2
Erik@lashway
Erik@lashway's Avatar
Drives: Camaros, Vettes, Trucks
Hello there. Before the misinformed step in, shoot me a PM. We can help you choose the right camshaft for your specific goals!
Look forward to hearing from you soon!
Erik@Lashway
Erik@lashway is offline   Reply With Quote
Old 12-05-2011, 09:43 AM   #3
themossman
Apprehensive Optimist
themossman's Avatar
Drives: '10 SS/RS SIM
Erik@Lashway
That's a bold statement on this forum...might want to reconsider your 'marketing' approach.
Car is for sale --->http://www.camaro5.com/forums/showthread.php?t=158486
Current Summary:
Engine:Phase One-(All work by Vengeance Racing): Custom Cam, AR Headers, ported throttle body, ported intake, custom tune, dual valve springs, hardened push rods, under drive pulley, thermostat, Vararam CAI, C5R timing chain, Melling oil pump catch can, breather, MagnaFlow Sport Axle Back
Suspension: Pfadt Sport Sway Bars, Pfadt drop springs
Other: MGW Shifter, Custom Paint
my build journal ---->http://camaro5.com/forums/showthread.php?t=30057
themossman is offline   Reply With Quote
Old 12-05-2011, 10:40 AM   #4
Padre
Only drives on Sundays
Padre's Avatar
Drives: '16 2SS A8 NPP MRC NGray
What are your goals?
Padre
OLD HOTNESS: The "Heretic": '11 2SS/RS L99 A6 Black/Inferno. Build Journal, Videos
D1SC GT9 JBA-LT = 720/680 | 10.330 @ 133.61, 1.546 sixty... Camaro King at ECS V, Darlington.
NEW HOTNESS: '16 2SS A8 NPP MRC. Bone Stock, 1/8th: 8.051 @ 89.44, 1.919
Padre is offline   Reply With Quote
Old 12-05-2011, 12:19 PM   #5
steeleshark2
steeleshark2's Avatar
This is correct. You need to let people know what your end goal is first. This will vary with the cam specs.
Old 12-05-2011, 12:21 PM   #6
siriusdish
Drives: 2010 Camaro L99
If L99 VVT seams what to go with, from searching around on here... See U have a L99...
Headers!!! CAI!!!
2010 L99
vararam intake, Vmax TB,Vmax Intake,TSP VVT 3 Cam,TSP underdrive pulley,Yank 3600,TM Cooler,ARH 2", High Flow cats, X-pipe, GM Pro mufflers, RX Catch Can,160 stat, BMR Trailing,toe,Cradle insert, Diff. Bushings, End links, Spohn-LCA's (Touring)Wheel spacer's. 422 rwhp Mustang Dyno http://www.youtube.com/watch?v=AaFNAhCL7Os
siriusdish is offline   Reply With Quote
Old 12-05-2011, 01:43 PM   #7
brantley847
v It bites.
brantley847's Avatar
Drives: 2011 IBM 2SS/RS
Headers!!! CAI!!!
Gotta agree with dish... You may get all the volume and performance/power you need from headers, exhaust, CAI.. I took that step first and was so happy with the results, now don't get me wrong. Cam will be a next step for me..
2011 2SS/RS
Performance: 439 RWHP: 226/236 Comp Cam, Kooks 1-7/8, CAInc, Borla S type, Vmax TB, Rx Catch Can, Trans cooler, SLP 160 termo, Melling high volume, Eibach Springs/Sways 1" drop, Whiteline complete bushing kit.
brantley847 is offline   Reply With Quote
Old 12-05-2011, 01:52 PM   #8
Ricky11SS
Ricky11SS's Avatar
i just want power and a little bit of sound idk if that helps
Old 12-05-2011, 02:20 PM   #9
brantley847
v It bites.
try headers and intake first then... I am telling you, man. The volume and tone of a good exhaust system with headers will blow you away.
maybe your tuner will give you some type of discount for a return visit? The labor cost to install both of these is also cheaper.. and in many cases can be done yourself if you have a lift. I wouldn't trust myself with a cam install though...
Because you have an L99 (like I do) a VTT cam after labor can run you close to 2-3k, because you will most likely need to replace lifters etc... a conversion to an LS3/TUNE with labor could run you 3.5-5k.
The headers/exhaust will be cheaper and the sound may be all you need. If you don't think that is enough, then jump to the cam and you will get another boost of performance and sound...
I recommend checking out
Lashway Motorsports
Texas-Speed
MarylandSpeed
Ted Jannetty racing...
there are other great vendors here, but that is who I shop through... each of those guys can get you what you want very quickly and not completely break the bank. Again.. expect to drop 2-2.5k for headers, exhaust, intake and you could see 40-50 hp gains since you already have the tune...but closer to 3-4k just for the cam.
2011 2SS/RS
Old 12-05-2011, 02:20 PM   #10
gotroost
gotroost's Avatar
Drives: IOM 2SS RS
Check out the mods in my sig. Totally happy with the Jannetty setup. Still have the stock exhaust, but it is a bit louder with the headers/cats for normal driving. And it screams when you get on it! With the auto, you will have to do some extra mods to, but it should be worth it.
Mods: JRE 470 cam kit, Dynatech long tubes/hi-flo cats, SLP underdrive pulley, CAI intake/ADM scoop, Pfadt Stage 2 suspension, Hotchkiss strut tower brace, Proven Wicked tow hook and end links, DBA rotors, Melling oil pump, Katech timing chain/LS2 damper, some bloody knuckles, still in progress...
gotroost is offline   Reply With Quote
Old 12-05-2011, 03:35 PM   #11
madmaxx18
madmaxx18's Avatar
Drives: 07_tundra/08_zo6
Hey Hey Don't forget ADM Performance great quality of maintenance and awesome customer service!!!!!
madmaxx18 is offline   Reply With Quote
Old 12-05-2011, 04:26 PM   #12
Ricky11SS
Ricky11SS's Avatar
Lashway Motorsports
Texas-Speed
MarylandSpeed
thankxx man ive been checkin out some and they told me to go with a 222/232 cam and that should it
??? idk
Old 12-05-2011, 05:03 PM   #13
steeleshark2
You really need to talk to a cam guy. You would also want the DOD delete for the L99 while you are in there. Texas Speed has some great Kits with everything included. There are a lot of companies on this board that will be happy to help you out if you give them a call. Brantly847 has a good point. Headers, cai and tune goes a long ways!! I would try that first then decide if you want to get the cam. CAI and headers are pretty much required for a cam anyway to get the most out of it.
Old 12-05-2011, 06:20 PM   #14
siriusdish
With out the CAI and Headers, Sucking air threw a coffee straw and exhaling threw a coffee straw...
Call Texas Speed after U get the Air part figured out...
2010 L99
2011, cam
Cam basics CamaroSpike23 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 76 11-25-2015 11:42 AM
ULTIMATE CAM Specs/ Info thread for the LS3/ L99!! mike25 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 31 04-29-2014 11:09 AM
Vengeance Racing Cam Kit Plus!!! L99 Conversion!!! American Racing + Vararam Kevin@V V8 Bolt-Ons & Tunes 19 11-02-2011 08:40 AM
Vengeance Racing Stage 3 cam 1977and2010 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 21 08-22-2011 11:55 AM
LS7 Cam For Sale $100 + sh PRICE DROP + 4x 3 bolt cam sprocket for sale PICS ADDED! CAMAR0 V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 0 01-04-2011 12:17 PM
