ModBargains
Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust
Old 04-15-2009, 11:44 AM   #1
jsharp
NOW CAMMED & SUPERCHARGED
jsharp's Avatar
Drives: 2010 Camaro 2SS/RS Black w/ IOM
L99 Delete Whats involved?
I know alot of people that are ordering the L99 like the AFM. I am wanting to mod as I please with the automatic. So My question is can you officially delete the AFM by changing the cam and lifters and tune? I want to choose my own cam and mods and not be afm based mods all while having an automatic. I am one that would pay for the gas guzzler tax just to have an automatic ls3 like the corvette. Input please. Thanks
jsharp is offline   Reply With Quote
Old 04-15-2009, 11:53 AM   #2
Zabo
Screamin' Chicken!
Zabo's Avatar
Drives: '00 Trans Am, '13 Escape Ecoboost
A couple sockets and a box end and pull the whole motor..
In reality; reprogram/reflash the engine computer to remove the cylinder shutdown commands. Cams and Lifters are all VVT related. I'm keeping the VVT but reprogramming the computer to remove the AFM once I pick up my tuner program for my laptop.
I'm starting to think the the Hotrodders of today are going to move from wrenches and hoists to HDDs and Laptops..:/
2000 Pontiac Trans Am
!CAGS - CETA Blackout - WS6 Store Shortstick - Custom 'Bandit' Shift knob - 3" TSP Rumbler - AP Tips - 1 3/4" Pacesetter LTs - 3" Catted ORY - MSD Wires - NGK Plugs - !EGR - Prothane Motor and Transmission Mounts - Catch Can - BMR STB - 17" WS6 Speedlines - Volant CAI
Zabo is offline   Reply With Quote
Old 04-15-2009, 11:54 AM   #3
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
I beleive it can be turned off with a tune. I do not know about different cam since the lifters and valves are different from the LS3.
Scott@Bjorn3D is online now   Reply With Quote
Old 04-15-2009, 11:57 AM   #4
Zabo
Screamin' Chicken!
Zabo's Avatar
Yeah, the whole valve train, seats, etc are different in L99 heads. The core block is the same, but everything else is different.
Old 04-15-2009, 12:34 PM   #5
Vash
Drives: 00 Blazer
The perfect fix would be a way to add a manual override button. So that you could use both modes and your own choosing. Probably not possible if it's totally in the flash program.
Old 04-15-2009, 12:36 PM   #6
UCF w00t
Geek
UCF w00t's Avatar
Drives: IOM 2010 Camaro 2SS
Being a nerd, this excites me. I am amazed that HPTuners et al is soo much $$$ and there is no sort of open source alternative. Maybe I should get working on that....
UCF w00t is offline   Reply With Quote
Old 04-15-2009, 12:42 PM   #7
Vash
Drives: 00 Blazer
This computer is more modernized and has the better CAN protocol. Unless there is some other mechanism. What tells it to go into 4 cyl mode is the question? This engine is already out in SUV's right? Check on there forums if for intel.
Old 04-15-2009, 01:11 PM   #8
BowtieGuy
Enlightened
BowtieGuy's Avatar
Drives: Nothing Currently
You may want to use AFM friendly mods. There is alot that goes into this. This information from Service Information might help.
Cylinder Deactivation (Active Fuel Management) System Description
To provide maximum fuel economy under light load driving conditions, the engine control module (ECM) will command the cylinder deactivation system ON to deactivate engine cylinders 1, 7, 6, and 4, switching to a V4 mode. The engine will operate on 8 cylinders, or V8 mode, during engine starting, engine idling, and medium to heavy throttle applications.
When cylinder deactivation is commanded, the ECM will determine what cylinder is firing and begin deactivation on the next closest deactivated cylinder in firing order sequence. For example, if cylinder number 1 is on its combustion event when cylinder deactivation is commanded ON, the next cylinder in the firing order sequence that can be deactivated is cylinder number 7. If cylinder number 5 is on its combustion event when cylinder deactivation is commanded ON, then the next cylinder in the firing order sequence that can be deactivated is cylinder number 4.
Cylinder deactivation is accomplished by not allowing the intake and exhaust valves to open on the selected cylinders by using special valve lifters. The deactivation lifters contain spring loaded locking pins that connect the internal pin housing of the lifter to the outer housing.
The pin housing contains the lifter plunger and pushrod seat which interfaces with the pushrod. The outer housing contacts the camshaft lobe through a roller. During V8 mode, when all cylinders are active, the locking pins are pushed outward by spring force, locking the pin housing and outer housing together causing the lifter to function as a normal lifter. When cylinder deactivation is commanded ON, the locking pins are pushed inward with engine oil pressure directed from the valve lifter oil manifold (VLOM) assembly solenoids. When the lifter pin housing is unlocked from the outer housing, the pin housing will remain stationary, while the outer housing will move with the profile of the camshaft lobe, which results in the valve remaining closed. One VLOM solenoid controls both the intake and exhaust valves for each deactivating cylinder. There are 2 distinct oil passages going to each cylinder deactivation lifter bore, one for the hydraulic lash-adjusting feature of the lifter, and one for controlling the locking pins used for cylinder deactivation.
Although both intake and exhaust valve lifters are controlled by the same solenoid in the VLOM, the intake and exhaust valves do not become deactivated at the same time. Cylinder deactivation is timed so that the cylinder is on an intake event. During an intake event, the intake cam lobe is pushing the valve lifter upwards to open the intake valve against the force of the valve spring. The force exerted by the valve spring is acting on the side of the lifter locking pins, preventing them from moving until the intake valve has closed. When the intake valve lifter reaches the base circle of the camshaft lobe, the valve spring force is reduced, allowing the locking pins to move, deactivating the intake valve. However, when cylinder deactivation is commanded ON, the exhaust valve for the deactivated cylinder is in the closed position, allowing the locking pins on the valve lifter to move immediately, and deactivate the exhaust valve.
By deactivating the exhaust valve first, this allows the capture of a burnt air/fuel charge, or exhaust gas charge, in the combustion chamber. The capture of exhaust gases in the combustion chamber will contribute to a reduction in oil consumption, noise and vibration levels, and exhaust emissions when operating in V4 mode cylinder deactivation mode.
During the transition from V8 to V4 mode, the fuel injectors will be turned OFF on the deactivated cylinders. To help prevent spark plug fouling, the ignition system secondary voltage or spark is still present across the spark plug electrodes on the deactivated cylinders. If all enabling conditions are met and maintained for cylinder deactivation operation, the ECM calibrations will limit cylinder deactivation to a cycle time of 10 minutes in V4 mode, then return to V8 mode for 1 minute.
Switching between V8 and V4 modes is accomplished in less than 250 milliseconds, making the transitions seamless and transparent to the vehicle operator. The 250 milliseconds includes the time for the ECM to sequence the transitions, the response time for the VLOM solenoids to energize, and the time for the valve lifters to deactivate, all within 2 revolutions of the engine crankshaft.
Valve Lifter Oil Manifold (VLOM) Assembly
The cylinder deactivation system uses an electro-hydraulic actuator device called the valve lifter oil manifold (VLOM) assembly. The VLOM is bolted to the top of the engine valley, below the intake manifold assembly. The VLOM consists of 4 electrically operated normally closed solenoids. Each solenoid controls the application of engine oil pressure to the intake and exhaust valve lifters on the cylinders selected to deactivate. Engine oil pressure is routed to the VLOM assembly from an internal oil passage on the rear of the cylinder block.
All 4 VLOM solenoids are connected in parallel to a fused ignition 1 voltage circuit, supplied by the powertrain relay. The ground or control circuit for each solenoid is connected to a low side driver internal to the engine control module (ECM).
When all enabling conditions are met for cylinder deactivation, the ECM will ground each solenoid control circuit in firing order sequence, allowing current to flow through the solenoid windings. With the coil windings energized, the solenoid valve opens, redirecting engine oil pressure through the VLOM into 8 separate vertical passages in the engine lifter valley. The 8 vertical passages, 2 per cylinder, are connected to the valve lifter bores of the cylinders to be deactivated. When vehicle-operating conditions require a return to V8 mode, the ECM will turn OFF the control circuit for the solenoids, allowing the solenoid valves to close. With the solenoid valves closed, engine oil pressure in the control ports is exhausted through the body of the solenoids into the engine block lifter valley. The housing of the VLOM incorporates several bleeds in the oil passages to purge any air trapped in the VLOM or engine block.
To help control contamination to the hydraulic circuits, a small replaceable oil screen is located in the VLOM oil inlet passage, below the oil pressure sensor. The oil pressure sensor is a 3-wire sensor which provides oil pressure information to the ECM.
During service, use extreme care in keeping the VLOM assembly free of any contamination or foreign material.
Cylinder deactivation may be inhibited for many reasons including the following:
• Engine coolant temperature out of range for cylinder activation
• Engine vacuum out of range
• Brake booster vacuum out of range
• Transmission gear incorrect or shift in progress
• Accelerator pedal out of range or rate of pedal application to fast
• Engine oil pressure and temperature out of range
• Engine speed of range
• Vehicle speed out of range
• Minimum time in V8 mode not met
• Maximum V4 mode time exceeded
• Decel fuel cutoff active
• Reduced engine power active
• Torque management active
• Catalytic converter over temperature protection active
• Piston protection active, knock detected
• Cylinder deactivation solenoid
If you believe it is your right to speak freely no matter the content, relevance, or intelligence of statement, then it is my duty to the powers that be to set you straight.
People have to talk about something just to keep their voice boxes in working order. So they'll have good voice boxes in case there's ever anything really meaningful to say.
Kurt Vonnegut
BowtieGuy is offline   Reply With Quote
Old 04-15-2009, 03:05 PM   #9
SemperFi
U.S. Marine Corps
SemperFi's Avatar
Drives: 2009 Ducati Streetfighter
Yeahh.. Unless you really really REAALLLY know your shit, Itd probably be smart to use AFM enabled mods. Or I foresee a LOT of reliability probs, maintenance time and costs.. :(
Texas Residents: Join the Texas social group!
Semper Fi!
SemperFi is offline   Reply With Quote
Old 04-15-2009, 04:02 PM   #10
detroitboy
Pinholic
detroitboy's Avatar
Drives: 11 Silverado, 08 Shelby GT500 Conv.
All of the above is exactly why I went with the LS3! Thats a whole lotta things to break later on in life.
Almost had a 2SS/RS, IOM, orange accent interior, 6 speed manual, sunroof & polished wheels
ordered 01/19/07
3000 - 2/27/09
3400 - 3/27/09
3800 - 4/17/09 (built and lost in the vortex)
ship date ??????? (I gave up and got a GT500)
5/11/09 - order cancelled
5/27/09 - vehicle arrived at dealership for whoever bought it after me
detroitboy is offline   Reply With Quote
Old 04-15-2009, 04:05 PM   #11
SemperFi
U.S. Marine Corps
SemperFi's Avatar
Ehh. I tend to enjoy the auto. When shit starts takin a leak, which wont be for a while knowing GM engine quality, Ill just put a newer engine in. Maybe even that new diesel people are talkin about.
Semper Fi!
Old 04-15-2009, 04:16 PM   #12
Zabo
Screamin' Chicken!
Zabo's Avatar
Hmm, maybe it could be as easy as pulling the Deac Solenoid.. :/
Old 04-15-2009, 04:21 PM   #13
BowtieGuy
Enlightened
BowtieGuy's Avatar
Not Likely.
Kurt Vonnegut
Old 04-15-2009, 04:34 PM   #14
Zabo
Screamin' Chicken!
Zabo's Avatar
Yeah..but then Oil would be everywhere.. didn't read that. -_-
Old 04-15-2009, 04:59 PM   #15
mlee
H-Town Camaro Club
mlee's Avatar
Drives: Number Twenty-Three
Or a Flux Capacitor...
mlee is online now   Reply With Quote
Old 04-17-2009, 05:40 PM   #16
Gib
Gib's Avatar
Drives: 2010 2SS/RS, RJT 04 Silverado
This has been covered in great detail in past post. I am having a speed shop remove the AFM and completly re-build the top end with all the good SStuff, new heads, cam and all the bolt on's...Do it right & get-r done!
GIBS SS
Gib is offline   Reply With Quote
Old 04-17-2009, 05:51 PM   #17
Keedy
Should have waited...
Keedy's Avatar
Drives: 2004 Mazda RX8
And the geek shall inherit the earth.
Bwahahahahahahahahhahahahaha!!!
Hahaha!!!!
Bwahahahahahahaha! =D
hah!
Keedy is offline   Reply With Quote
Old 04-17-2009, 11:07 PM   #18
GeorgeInNePa
Plastic Cuttin' Badass
Drives: '08 G8GT 6.0
Unless the L99 is completely different from the L76 (I don't think it is), to get rid of the AFM you need to change:
valley pan
Cam (if you are changing to a 3 bolt cam you'll need a timing chain and gear set, along with the bolts or just the upper sprocket if you want to reuse the chain)
LS2 timing chain dampner (many of the L76s had broken dampners on disassembly)
lifters
lifter buckets
valve springs (and related items-locks, retainers, seals, etc)
push rods
LS3 PCV hose and block off for the rear driver side valve cover tube
2 head gaskets
new balancer bolt (stock is a TTY bolt)
new tune that turns off the AFM and tune for the new cam
That's if you want to physically get rid of the AFM. If you just want it shut off, you have have the tune changed to do that.
'08 Black on Black G8GT--> 12.166 @ 113.13, 1.723-60'<-before the gears...
FasterProms Tune, Ported TB/Intake - HSRK - Vararam - SLP 25% UD Pulley - ARH 1 3/4" Longtubes - Pypes Violators - Yank 3200 Converter - PCM4Less Trans Cooler - DashHawk - All Pedders Bushings, Xa Coil-Overs - Spohn Arms - Billet Prototypes Catch Can - Skinnies on GTO rims - ET Streets on F Body Rims - SJM LineLoc - 3.70gears/Harrop TrueTrac
Coming Soon: Ported Heads/Cam/DoD Delete
GeorgeInNePa is offline   Reply With Quote
Old 04-17-2009, 11:10 PM   #19
Vash
Drives: 00 Blazer
Now that's some nice info thx. I was thinking someone out there had already taken an in depth look at the engine on other platforms.
Old 04-17-2009, 11:32 PM   #20
GeorgeInNePa
There aren't a whole lot of differences between the L76 and the L99
There's a 12 cubic inch difference. The L99 has the cam phaser as well as AFM. I'm not sure, but I think the L99 gets the sodium filled intake valves like the LS3. The L76 has the same heads as the L99 and the LS3, but gets solid intake valves.
The intakes and throttle bodies are the same. The LS3 gets a forged crank, the L76 is cast, I'm not sure about the L99.
Old 04-18-2009, 12:52 AM   #21
Zabo
Screamin' Chicken!
Zabo's Avatar
O_O
HELL YEAH FIREWORK VALVES!!!!
Trust me, if you don't know what I'm talking about..cut one open from behind a blast screen.
Old 04-18-2009, 01:06 AM   #22
Vash
Drives: 00 Blazer
Bah I bet it's Melamine not Salt!
Well I doubt it would be that easy. But if there is a signal ground or pos that controls the mode might be able to just put a switch on it. Like it should be already from the factory without the Fedzilla in your car's bidnaz.
Old 04-18-2009, 01:33 AM   #23
Grape Ape
Drives: 96 Bronco w/ a 5 speed
There are at least 4, as the ECM carefully deactivates each one (during either the power or compression stroke, I forget which).
I would like it if switching the transmission to manual mode would disable the AFM. But that is enough switch for me since I'm pretty sure that the ECM will be able to moderate the AFM for better mileage than the driver could.
Grape Ape is offline   Reply With Quote
Old 04-19-2009, 12:44 PM   #24
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
The valves are closed after the powerstroke, to trap the exhaust gasses.
Quote: In 2014 the camaro will have ... a twin turbo v6 ... around 350 to 360HP
No. Let me repeat that. No. FbodFather
Camaro5 Fest III Information
Camaro5 Fest III pre-registration
DGthe3 is online now   Reply With Quote
Old 04-19-2009, 03:53 PM   #25
gunslinger
Drives: 1998 Z28 M6
From the Service Book above:
"The pin housing contains the lifter plunger and pushrod seat which interfaces with the pushrod. The outer housing contacts the camshaft lobe through a roller. During V8 mode, when all cylinders are active, the locking pins are pushed outward by spring force, locking the pin housing and outer housing together causing the lifter to function as a normal lifter. When cylinder deactivation is commanded ON, the locking pins are pushed inward with engine oil pressure directed from the valve lifter oil manifold (VLOM) assembly solenoids."
The lifters sound like the weak part of the AFM system.
The VVT, on the other hand looks awesome!
GTR: Get Transmission Replaced
gunslinger is offline   Reply With Quote
LS3 vs L99? SGOS252382 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 34 09-18-2010 03:55 PM
Which transmission will the L99 have? mega V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 19 01-08-2009 07:53 PM
Tuning LS3 vs L99 Evilangel Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 17 10-30-2008 10:22 AM
L99 engine specifications Tran Wiki 0 10-19-2008 11:40 AM
L99 discussion The_Blur Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 85 07-25-2008 02:07 PM
