Old 12-06-2011, 03:16 PM   #1
jtzako
Drives: 2010 IBM Camaro SS
Cant get the TPMS to relearn
I cant seem to get the TPMS on my swap out rims/tires to work. They are take-offs from another SS with stock tires.
I tried the process in the manual to relearn, it starts the relearn process but wont detect tire pressure changes (up or down) to get them learned.
Any ideas? Can I visually determine if these take-offs still have the TPMS equipment on them?
2010 Camaro SS Imperial Blue | CAI Inc, CAI | Solo Hi Flow Cats | X-Pipe | Backup Camera | PDIM
jtzako is offline   Reply With Quote
Old 12-06-2011, 03:19 PM   #2
az2ss
HMFIC
az2ss's Avatar
Drives: 2016 1SS
pretty sure the only way to visually tell if the wheels have the sensors is taking the tire off and looking at the inside of the rim
az2ss is offline   Reply With Quote
Old 12-06-2011, 03:44 PM   #3
camaro104
camaro104's Avatar
Drives: 2017 Nightfall 50th Annivers Camaro
Send a message via AIM to camaro104
Real easy to do, hit the switch to read tire sensors reset, the horn will blow i think is 2 times, start from the left front wheel and let the are out until the horn blow once then go to the right front and repeat, then the right rear wheel, then the left rear wheel. The horn will blow every time you let the air out at a certain point each time it does go to the next wheel. After you do all four wheels fill the tire back up to about 32 to 36 lbs of pressure.
camaro104 is offline   Reply With Quote
Old 12-06-2011, 04:20 PM   #4
jtzako
Problem is, it is not blowing the horn while I let air out. I tried a few times. Even tried putting air back in to see if it would go.
Old 12-06-2011, 09:11 PM   #5
rb
rb's Avatar
Drives: silver '11 2SS LS3
When I did mine, it seemed like it took too long (about 20 - 30 seconds while bleeding air out) for the computer to sense the pressure change and honk the horn. I probably dropped the pressure by 6 - 8 psi. At first I thought it wasn't working, but it did finally work okay, I just needed to be more patient.
rb is offline   Reply With Quote
gm tpms reset tools cheap camaro1 Wheels and Tires Talk Sponsored by The Tire Rack 13 11-24-2017 02:32 PM
TPMS relearn tool Flashpoint135 Wheels and Tires Talk Sponsored by The Tire Rack 60 06-13-2014 11:44 AM
2011 SS Tire relearn TPMS JKEP44 5th Gen Camaro SS LS LT General Discussions 34 05-18-2011 07:32 PM
Cant get my SS to relearn TPMS Sensors Jeanius Wheels and Tires Talk Sponsored by The Tire Rack 82 03-20-2011 08:24 PM
Help!!! TPMS install onto TSW Nurburgrings Avalnch Wheels and Tires Talk Sponsored by The Tire Rack 13 03-09-2011 06:44 PM
