Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums -
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - > Other Generations > 3rd Generation Camaros
Old 12-07-2011, 09:08 PM   #1
Drives: 1997 z28 six speed
need help with my z28 87 lt1 camaro six speed
when i go from from low rpms and try to floor it it feels like im not getting enough air flow (power) till it clears up on higher rpms and i also notice when i get on it at the same time the shifter vibrates till it clears up it happens in any gear from lower rpms to higher rpms any idea what this is already changed all of the brakes from calipers and rotors to brake pads and break lines also changed out ignition wires spark plugs fuel and air filter...i think it might be the cat which has all of those things in it that proll got stuck all around it? and when air flow comes through its not flowing through properly somehow? any ideas can someone elaborate please???????
Z28allday is offline   Reply With Quote
Old 12-08-2011, 02:49 AM   #2
Iroc-Z <3'r
MAC's Avatar
Drives: '87 5.7L Iroc-Z
Posts: 392 would be most helpful for you with this issue. Theres many people that deal with third gen camaros and LS/LT swaps over there. good luck!
"Camaro Z/28 is back. Gentlemen, Don't even bother to start your engines."
MAC is offline   Reply With Quote
5th Gen Suspension -- The Book JusticePete Suspension / Brakes / Chassis 151 05-07-2015 05:52 PM
PEDDERS SUCCESSFULLY FITS 305s ON ALL 4 CORNERS! Suspension / Brakes / Chassis 467 06-11-2013 09:45 PM
