Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust
Old 12-07-2011, 09:59 PM   #1
Agostino13
Agostino13's Avatar
Drives: 2010 Red 2SS/RS
Pic request Gmpp axle back connection
Need a picture of where the Gmpp axle back slides into the stock piping.
I sold my Gmpp axle back on eBay now buyer is trying to tell me it doesn't fit and he wants a return he believes it has to go over the stock piping I need a pic showing how it slides in to the stock piping. Also just to make sure the Gmpp axle back does fit the 2012 camaro ss the same as it did on my 2010 ss correct? Far as I know the 2010 axle backs fit 2011 and 2012 models
Agostino13 is offline   Reply With Quote
Old 12-07-2011, 10:19 PM   #2
siriusdish
Drives: Nothing "On the site for my Dad"
Let me look in my Pics.. I have a few..
2010 L99
vararam intake, Vmax TB,Vmax Intake,TSP VVT 3 Cam,TSP underdrive pulley,Yank 3600,TM Cooler, Thundervolt 10.4 mm wires,ARH 2", High Flow cats, X-pipe, GM Pro mufflers, RX Catch Can,160 stat, BMR Trailing,toe,Cradle insert, Diff. Bushings, End links, Spohn-LCA's (Touring)18" TSW Nitto Nt05r's (spacer's). 422 rwhp Mustang Dyno http://www.youtube.com/watch?v=AaFNAhCL7Os
Escort 9500ix
Disclaimer:This is my Dad's Car, I help him out from the site.
siriusdish is offline   Reply With Quote
Old 12-07-2011, 10:25 PM   #3
siriusdish
some
2010 L99
Escort 9500ix
Old 12-07-2011, 10:27 PM   #4
siriusdish
More, might be the same..
2010 L99
Escort 9500ix
Old 12-07-2011, 10:31 PM   #5
Agostino13
Agostino13's Avatar
Nice thanks those will work
Thank you
Old 12-07-2011, 10:33 PM   #6
siriusdish
No prob, no Leach here,lol
2010 L99
Escort 9500ix
Old 12-07-2011, 10:37 PM   #7
Agostino13
Agostino13's Avatar
One more question in these pics it kind of looks like the axle back pipe goes over the factory piping the Gmpp exhaust I had slide into my factory piping just want to make sure in the pics is that sliding into the factory pipe or is the factory pipe sliding into the axle back?
Old 12-07-2011, 10:40 PM   #8
siriusdish
The factory pipe is inside the GM mufflers I believe
2010 L99
Escort 9500ix
Old 12-07-2011, 10:42 PM   #9
siriusdish
Muffler
2010 L99
Escort 9500ix
Old 12-07-2011, 10:44 PM   #10
Agostino13
Agostino13's Avatar
That's weird I had the same mufflers and on my ls3 they slide into the piping
Old 12-08-2011, 12:08 AM   #11
axis
axis's Avatar
Drives: 2010 Black 2SS/RS A6
That doesn't make sense. If it slid inside the OEM pipe, you'd essentially be choking down the exhaust a little in that area. All axle backs i've seen have a flared end that goes OVER the OEM pipe that you cut.
Halltech Yellowjacket fed
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
JRE tuned
Aint nobody got time for that
Old 12-08-2011, 08:55 AM   #12
Agostino13
Agostino13's Avatar
I need to know if there is a difference between the 2010 ss camaro stock piping and a 2012 ss convertible stock piping I had the Gmpp axle back installed on my 2010. Mine slide into the stock piping I sold it on eBay now the guy wants a return saying it does not fit his 2012. I a bought this exhaust from Chevy they installed it on my 2010 it slide into the piping how does it not fit a 2012?
Old 12-08-2011, 09:18 AM   #13
bkscott
bkscott's Avatar
Drives: 2010 Camaro 2SS/RS
Ok is it possible that the exhaust on the 2012 is fractionally smaller to allow for the extra bracing underneath the car?
94 Firebird Formula (Drowned 08/30/05)
2010 IBM 2SS/RS 6M Arrived 3/25/10.
ADM CAI, Borla Type S Cat Back, VMAX Ported TB, LG Short Throw Shifter, Hotchkis Max Chassis Brace, BC Racing Coilovers, Hotchkis Sway Bars, Whiteline Cradle Bushings,Forgestar F14's 20x9/11,Nitto Invos.
bkscott is offline   Reply With Quote
Old 12-08-2011, 10:30 AM   #14
axis
axis's Avatar
Here is the pic that YOU posted in your sale. It clearly shows it goes OVER the stock exhaust tubing.
JRE tuned
Old 12-08-2011, 10:45 AM   #15
Saint Alban
Saint Alban's Avatar
Drives: '10 Black V6 2LT RS
Send a message via AIM to Saint Alban
From this pic, it definitely goes over the stock pipes. Ive never seen an axle back that slides inside. But if the buyer is saying it doesn't fit inside, then it must fit outside, right? What's the problem?
Saint Alban is offline   Reply With Quote
Old 12-08-2011, 10:54 AM   #16
Agostino13
Agostino13's Avatar
The buyer says it doesn't fit over the stock piping but I know for a fact when it was on my ad it slide inside the piping I know that may sound weird but that is how the dealer installed it according to the buyer his stock piping is 2.5 in the axle back pipe is 2.2 inch does it not make sense that it would slide into the stock piping
Old 12-08-2011, 11:00 AM   #17
Saint Alban
Well, if that pic is the same mufflers, it is the biggest reason that it makes no sense. Those slits at the end is for the pipe to expand and fit over the stock pipes.
If they fit those inside your pipes, they did something wrong.
**oh yea, and if his piping is 2.5, it's a V6. I think the V8's are larger. I don't know what either of you have. Maybe that's the problem?
Old 12-08-2011, 11:05 AM   #18
Synner
Drives: 2011 2SS/RS M6
Most likely if its been installed before the ends will be pinched a bit and not slide over easily. I had the same issue with a used system and took a few pieces to midas. They stretched them back out with their bender machine and didn't charge me anything.
Old 12-08-2011, 12:26 PM   #19
Agostino13
Agostino13's Avatar
He has a v8 my piping on my v8 is also 2.5 in I'm confused as to why the dealer installed this on my car and slid it inside my exhaust if it's suppose to go over it.
Also If the slits are made to expand would a shop be able to expand it enough to get it to go over the 2.5 stock piping?
Old 12-08-2011, 12:31 PM   #20
Saint Alban
They should, yea. As Synner mentioned, they can be opened up again. When I was putting my exhaust on (MRT), the ends looked to be the same size and wouldn't slide on. They just had to be opened up more.
Old 12-08-2011, 12:37 PM   #21
BLACK10
POWER TECH
BLACK10's Avatar
The buyer is just an idiot
Old 12-08-2011, 12:44 PM   #22
The Stig
I used to be Stieger....
The Stig's Avatar
Drives: a PBM camaro
Does the buyer have a vert? Because the vert and coupe have different exhaust systems due to the vert's reinforcements.
Stieger's BLACK Build Thread thanks for the sig Russ
Old 12-08-2011, 01:38 PM   #23
Agostino13
Agostino13's Avatar
Yes he has a convertible but as far as I know they don't make different axle backs for convertibles. If they do then I'll have no choice but to refund him. Does anyone know if the ss axle backs fit the ss convertibles?
Old 12-08-2011, 01:40 PM   #24
The Stig
The Stig's Avatar
But in your ebay add, did you say that it fit the 2012 convertible? Or did the buyer assume that it would fit? If the buyer assumed that it would fit that's his fault.
Old 12-08-2011, 01:49 PM   #25
Synner
+1
FOR SALE BBK Ceramic Coated Headers and GMPP Axle Back Exhaust + 20" Chromed SS rims simon.w V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 10 09-02-2011 12:30 PM
For Sale 304 cat back $250 axle back only $200 storm83 V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 1 03-21-2011 09:49 AM
Cat back vs. Axle back Cherry Bomb bigwayne3000 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 15 10-06-2010 12:04 PM
MagnaFlow Axle Back w/ Mufflers - Install and Review (now with drone!) themossman Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 29 07-12-2010 09:56 AM
FS: new gmpp axle back! Malice V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 4 03-19-2010 04:21 PM
