JDP Motorsports
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Garage / Tools Discussions
Old 03-13-2012, 11:04 PM   #15
IDEALG
Chevy's "Rumble" Best!
IDEALG's Avatar
Drives: 2015 ZL1 6 speed
Send a message via AIM to IDEALG
I have mohawk lifts they are probably the most expensive lifts on the market but they are built like brick shit houses and i wouldnt trust my life under any other lift.
IDEALG is offline   Reply With Quote
Old 03-14-2012, 09:17 PM   #16
Clustergear
Clustergear's Avatar
Drives: 68 Camaro, 2011 Conv.
I had posted this in another tread about lifts.
I put a 4 post lift in for service and extra parking, I went with a Ben Pak HD9 extra wide. With the extra wide it is 107" between posts I can park a flat deck car trailer under lift (most trailers are 102 wide at end of fenders) With the extra wide you can also drive a pickup truck on lift and not have get out of truck to push mirrors in so they don't hit the posts. Also bought the wheel kit I can push the lift around the garage with a car on it. Lift doesn't have to be bolted down and it very sturdy with either a camaro or a heavy Suburban on it. Another thing to think about is, do you have plans down the road of get pickup extended cab or crew cab. Order a lift that long enough to fit wheel base of what in your future. I welded up some steel to make cross braces that fit in to jack channel on lift, lay braces in than put plywood down and now have full flat deck to put motorcycles or any other junk on. Put it up in the air and now more floor space. I'm 5'8" and I can walk under with out ducking. Here's the place that had the best price. I also put put two 220 plugs on the ceiling so if I move lift it will work any where in garage.
http://www.asedeals.com/garage_lift.html
Clustergear is offline   Reply With Quote
Old 03-14-2012, 10:05 PM   #17
mws444
mws444's Avatar
Drives: 701 RWHP Lingenfelter/Pedders Beast
+1
They are also made in the good 'Ol USA! Anyone who can afford a Mowhawk owes it to themselves to go to their website to see all of the defferences beween them and the rest......amazing!
From a satfety standpoint they are head and sholders above the rest.
Lingenfelter forged balanced and blueprinted LS3, Maggie TVS 2300 LPE 9.5" Rearend 3.73,LPE dual disk clutch,10/14 rib belt drive,
MTI shifter,RPM Level VI,Corsa stainless cat back, Racing Brake Rotors, LPE calipers, LPE twin fuel pumps, American Racing long tube headers, GT9 cam Port and polished heads and an ADM majic tune.
701 RWHP,Fully Pedderized w/complete bushings and Sportsryder Supercar Remote resevior coilovers.
CCW 505t's Nitto Invo's and DR's
Beware of the LPE Brotherhood!
mws444 is offline   Reply With Quote
Old 06-17-2012, 08:53 PM   #18
4th Gen Camaro Addict
4th Gen Camaro Addict's Avatar
Drives: '02 Phase II ZL1/'97 30th Annv. SS
Lifts
I have a Bend-Pak 4 post 12,000 lb. lift with two 6,000 lb. rolling jacks. It should do anything that I'll ever need it to do.
4th Gen Camaro Addict is offline   Reply With Quote
Old 09-10-2012, 10:36 PM   #19
CEE
CEE's Avatar
Drives: 2002 WS6 T/A; 2013 Camaro 2SS
WOW! & WOW!
CEE is offline   Reply With Quote
Old 09-11-2012, 06:55 PM   #20
cornfield camaro
Drives: 2011 l99
I've had the same Mohawk for 21 yrs. and it's been lifting everything from loaded down 1 tons to Honda Civics without ONE single problem. To me, there are two kind of lifts. The first is bought by a guy in a suit who's trying to save money. The second is bought by the guy standing under it. Mohawk is bought by the guy under it.
cornfield camaro is offline   Reply With Quote
Old 09-11-2012, 07:05 PM   #21
Supermaro585HP
Drives: 2011 Camaro SS RS
I have a used car lot in Pittsburgh PA. and I just bought a new lift last year. I got it through Advance auto parts and love it. I paid $ 2300.00 installed. I give them alot of business and they gave me a good deal.. Check them out..
Supermaro585HP is offline   Reply With Quote
Old 09-12-2012, 02:50 PM   #22
ZooDad
ZooDad's Avatar
Drives: 2010 Camaro SS/RS
Garage Lift
OK, Got finished sooner than expected.
I have true 9' ceilings and a fairly tight opener system.
The MaxJax has a maximum lift of 48". Plenty for what I am doing.
I ran into some challenges along the way. Here are some photos of it.
I will most likely reroute the hoses up to the ceiling to get them off the floor and mount the pump/tank assembly on the wall.
Post up and questions / comments you have.
As Delivered
Unpackaged
Measuring and squaring the pillars
Directions are clear, no less than 4" thick concrete. Should not be a problem. First hole 4.0" Drilled with rotary hammer 5/8" first then 7/8" for the anchor. Using the sacrificial bolt and nut, you drive the anchor in.
Got all 5 holes drilled, but 2 anchors would not set. Removed them and measured again..... 3.5" and 3.25"... Ah crud... A call to Danmar and got the news, pour footings 4'x4'x12" Yep that's alot of mud.
To the rental and back with a saw.
Thank goodness for young help.
Nice "Little Hole" under the SS
Full Load of Mud
One of two big holes getting filled
Filled and finished
Marking for new holes.
Wife's Altima on the lift rotating tires and changing oil. Installation went smooth.
View from the rear of the SS. It is at full height.
Here I am sitting beneath the SS. There are solid bars that insert in the pillars. It prevents the cross support from descending.
View from rear sitting beneath.
And finally here it is all tucked away.
Unfortunately the SS has not been inside for a several months.
The garage has been invaded by this.....
Sorry for the lousy photo - Phone and sun glare).
ZooDad
ZooDad is offline   Reply With Quote
Old 09-13-2012, 11:12 PM   #23
Nick S
Nick S's Avatar
Drives: 2013 Camaro 1LE
I have been talking to a local guy that has been installing lifts for over 25 years. He said the main thing to look for is to make sure any lift you are buying is ALI certified. That means it has been third party tested to verify that it can and will hold the weight that it is rated at. I saw a video somewhere of a lift that was not ALI certified and it crumbled at way less than the load rating on it. If I can find the video I'll post a link.
I've been looking at the Challenger lifts (www.challengerlifts.com) and the rotary revolution lifts. I'm more of a 2-post lift fan for general service work purposes but I have also been considering a 4-post lift for parking and storage to get one of the camaro up in the air to free up garage space.
Nick S is offline   Reply With Quote
Old 02-02-2013, 05:53 PM   #24
MrGs SS
MrGs SS's Avatar
Drives: 2013 Black SS/RS
Originally Posted by 2L82RUN View Post
I just built a garage and had a BendPak 2 post 10k lb lift installed. Garage was built to accommodate the lift. Ceiling is 12' 4" high.
I will trade you my wife and girlfriend for your garage.. pm me if interested..
2013 2SS Black~ L99
Performance Mods-CAI intake, APEX washer bottle relocate and scoop, Ported TB. SLP 160 degree stat, Norris Catch-can, Pfadt Tri-Y headers, BMR F/R sway bars and Arms, Corsa cat back exhaust.
Appearance Mods-Blackout kit (markers, tail lights), black tail light bezels, black chrome trunk lettering, LSR billet engine dress-up kit, sub box. Billet tensioner pulley and thermostat housing (Billetcustom), Heritage grille.
Tuned by Matt @ Florida Speed and Power
379/388 Mustang dyno
MrGs SS is offline   Reply With Quote
Old 02-18-2013, 10:00 PM   #25
2L82RUN
Drives: ABM SS/RS
Already have a wife and unable to support another or a girlfriend. I think you'd win big time on that deal!!!
This is a time lapse of the first major use my new garage/lift got. Total rear end work on my SS. Diff bushings, 1400hp axles, trailing arms, toe rod arms, and carbon fiber driveshaft!!
2L82RUN is offline   Reply With Quote
Old 02-19-2013, 07:38 AM   #26
mws444
mws444's Avatar
Think two forklifts...one each side and 1/2" steel construction and foremost no cables!
Old 04-07-2013, 09:19 AM   #27
jjwvette
jjwvette's Avatar
Drives: Corvette StingRay
I have a Eagle lift.
I started this project in 2007
Heres where I am now in 2013 and still not finished
jjwvette is offline   Reply With Quote
Old 12-12-2013, 09:10 AM   #28
moondog933
www.worthequipment.com made right there in Mansfield Tx. I bought a 2 post 10,000lb clear floor lift and it picks up my 1 ton easily...very good price and built in the USA.
moondog933 is offline   Reply With Quote
Shop Lifts-Need Advice Dr Jkel Garage / Tools Discussions 88 11-14-2011 08:12 AM
public car lifts? GMFarmer USA - NY / NJ / PA 4 03-01-2011 07:09 PM
Study: Detroit lifts quality but Toyota still king AJC General Automotive + Other Cars Discussion 8 06-24-2009 09:32 AM
lifts Jamie Mac Off-topic Discussions 4 04-10-2009 10:02 PM
Press embargo lifts in 2 weeks... performance test result predictions Fireball 5th Gen Camaro SS LS LT General Discussions 7 03-06-2009 12:29 PM
