JUICEDMOTORSPORTS
Old 12-08-2011, 05:07 PM   #1
DAL123
DAL123's Avatar
Drives: 2010 Camaro 2LT/RS/A6
Need Input and HopeFully Fix
I have been runnung my CNC poerted TB for a few weeks now and everything seems fin. Nice smooth take offs and seems peppier when giving it the gas while already driving. Well today I was behind Wal mart nice open parking lot and for the first ime. never tried it with the new Tb , from a dead stop I punched aned it and nothing but a massive BOG down, went nowhere till it picked up rpm and begane to take off. Car was in D ,Trac on. no power braking , just a clean punch and just nothing. I am running an A6 with a modified posi and 3:45's ,Fresh oil change , and naturally Vinces tune. Also got oil breather with clanside pcv pluged per SC150, I tried this when it was stock and could spin em. Please any input anybody?
Trifecta Tune, Vararam CAI,Self ported Intake Manifold,3/8 Black Iceolator,Rx Catch Can, W/Breather, V8 Rear Diff. 3:45s W/Posi Mod, Mrt V2.0 Axel Back, Magnaflow Resonated X-pipe, Street Scene Front Splitter.,V-Max Trottle Body., Eiback Sway Bars., Phadt End Links.,
DAL123 is offline   Reply With Quote
Old 12-08-2011, 05:30 PM   #2
cjt037
boost+v6=me=:)
cjt037's Avatar
Drives: Turbo'd 6er
Turn you track off try again
http://www.camaro5.com/forums/showthread.php?t=185528
435.7 RWHP 405 RWTQ
JUST A LITTLE V6... Try me
cjt037 is offline   Reply With Quote
Old 12-08-2011, 05:40 PM   #3
DAL123
DAL123's Avatar
Ok I will try that tomorow thanks.
Old 12-08-2011, 05:50 PM   #4
DAL123
DAL123's Avatar
You think that would make the engine bog right down? I mean like old carberator days..
Old 12-08-2011, 05:56 PM   #5
ORANGA2D
ORANGA2D's Avatar
Drives: 2011 IOM 2SS/RS M6
It will cut power to keep traction.
From the manual.
Traction Control
System (TCS)
The vehicle has a Traction Control
System (TCS) that limits wheel spin.
The system utilizes engine and
braking controls to control wheel
spin during acceleration at all driving
speeds for maximum driver control
regardless of conditions. When the
system senses impending wheel slip
during acceleration, it signals the
throttle control to reduce drive wheel
torque. Under extreme situations,
such as going from pavement to ice
during acceleration, the system
will selectively apply the brakes to
maintain control. The system may
be heard or felt while it is working,
but this is normal.
Hit the TCS button to turn the TCS off or Hold the TCS button down for about 7 seconds and that will turn everything off. And try again and see what happens.
ORANGA2D is offline   Reply With Quote
Old 12-08-2011, 05:59 PM   #6
DAL123
DAL123's Avatar
OK I can see that being a factor thanks ORANga2D
Old 12-08-2011, 06:03 PM   #7
ORANGA2D
ORANGA2D's Avatar
No problem, if after you try that and it still does it then you can look at other things. But I am pretty sure thats whats happening.
Old 12-08-2011, 08:13 PM   #8
chevy 3
NEcamaro5
chevy 3's Avatar
Drives: Black 2ss rs 1LE
Ive ruined many a cool moment by forgeting the traction controle is on.FRIG
chevy 3 is offline   Reply With Quote
Old 12-08-2011, 10:23 PM   #9
KMPrenger
KMPrenger's Avatar
With that SS rear end your definitely going to be putting more of a load on the engine because of the increased traction, but then again you are slightly lower geared so that helps your torque.
Anyways, I agree with the others....you should be able to nail it and go. Otherwise, if it still bogs down on you with TC off, try doing what most guys with autos do at the strip. Foot on brake, bring it up to about 1,100 rpm and then let er rip and see what happens. If she still bogging like crazy, then I might start worrying.
Old 12-08-2011, 10:30 PM   #10
OOLIE
OOLIE's Avatar
Drives: 2011 LS
if nothing else works you can try to reflash your computer tune and see if something is in the memory. I am guessing removing the nannies should work
OOLIE is offline   Reply With Quote
Old 12-09-2011, 04:14 PM   #11
DAL123
DAL123's Avatar
Ok It was the nannies worked great with all off. Thanks for all the input guys. Now I gotta worry about these weak timing chains on all the early 2010 V6's. GM Has 2 part #'s one for the original and one for the ne hevier duty they started to use. Why ca'nt the ones withe weak chains have them replaced under warranty..Why should we have to ruin our engines before they help fix???
Old 12-09-2011, 04:16 PM   #12
its a syn
B.O.D. 02/16/10
its a syn's Avatar
Drives: Longest things on Earth
its a syn is offline   Reply With Quote
