Caryle Racing
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > ZL1 Wheels/Tires
Old 12-09-2011, 04:59 AM   #1
1BADZL1
THE CAMARO KING
1BADZL1's Avatar
Drives: 2012 Camaro ZL1 on order #PZSD7S
Question Thinking Ahead: SSX Wheels and other tire and rim alts for ZL1 during cooler months
While I know there will be countless threads on this in the next several months, I would like to start bringing up questions now.
It may be that other future ZL1 owners would like to see what is available as this writing as well. Since this thread will be broad in general I would like to try to keep the focus organized if possible by questions and possible work around's for this upcoming "issue." I call this an "issue" because if your ZL1 is going to be driven 12 months out of a year like many will be, then this is an issue that has to be looked at subjectively.
I too, will research this in the next few months and will post any of my findings back to this thread as I realize not much research has been done on this subject as far as ZL1 is concerned. Maybe the research that has been done on vettes and SS models have been done, and we can use some of that helpful information here and try to apply that given information to the ZL1.
OK. Like I said, I know this thread will be broad as there will be many questions I will not have thought of at the time of this writing, so I will start with things off the top of my head, then we can go from there and bring up more questions as we go. Fair nuff?
Ok.... WTD.... right?
The Scenario is this. We have a new car that we will be limited to cold weather use under temps below 40 degrees with its current factory GY F1 super car tires.
The second scenario also this even compounds the issue of NOT having a spare tire. So we are going from needing/ having 4 tires and to a possibility
to a total of 4 more tires and even a 5th tire for a spare making it a total of
9 tires!
That brings in the possibility of you do not like changing and mounting a second set of tires every 4-6 months of the year to buying not only as second set of tires as backup but also a second set of rims as well, for a possibility of 9 rims!
Also deeper pockets!
Ok that above is the issue as I see it.
Possible solution's that I can see.
I myself like the idea of having both sets of rim combos. Both the SSX black rims and the polished 5 spokes. My car will be shipped with the polished 5 spokes so it would be easier for me to order the SSX rims and a additional set of all weather or cold weather tires for winter months. And a spare tire/rim of some sort as I am not sure I want to keep a full size 5 spoke wheel in my truck for a spare. So I am still needing to see spare tire options.
I like my first option. 1. With that said, does anyone know the part numbers
for the SSX wheel, and is the rim available from GM parts yet?
I have looked at the american racing web site. They have the ZL1 listed as a model, but they do not have any wheels listed as of this writing for ZL1.
2. Is the wheel and bolt pattern for ZL1 the same as an SS model?
I assume that it is the same.
Chevy for eons on fbody up from the first gen, to I know the 4th gen
was 5 x 4 3/4.
3. I understand that the bolt pattern for the 5th gen has changed. What is the correct bolt pattern for YM 12 ZL1?
Also the simple possibility of swapping the F1 tires from the get go may be a good idea and deal with the issue this way instead of buying an extra set of rims. Simply change the F1 tire out for your fave choice of tire and be done with it. Problem solved. I would think this would be the cheapest route as I am sure there are many C5 members that would help out with this idea.
4. What are some good all weather tires suitable for the ZL1 in ALL driving conditions and not just track/summer tires?
5. What is the current market value for the F1 tire that is shipped with ZL1?
Let us hear some good ideas. Pass on anything you have with part numbers, pics, links to good tire deals, pricing, saftey, etc.
Try to keep the thread on track my discussing the above with ZL1 specific information. I do know think this thread needs to be in the tire section as this is something each and every future ZL1 owner more than likely will have to think on in time, either now.... or in the future...
Subscribed.
2012 Camaro ZL1 Car Name: Bruce
ZL1, LSA, MN6/MG9, DSX, RTQ, VR,
Current Status:
2030
1000 Initial Order 11/11/2011 Chevyland
1100 Order accepted at dealer: 11/11/2011 - PZSD7S
2000 Order accepted by GM: 12/14/2011
3000 Accepted By Production Control: 00/00/2011 - TPW 00/00/2011
3100 Sequenced: 00/00/2011
3300 Scheduled For Production:0/0/2012
3400 Broadcast: 0/0/2012
3800 Produced: 0/0/2012
4000 Available To Ship: 0/0/2012
4200 Shipped: 0/0/2012
5000 Delivered To The Dealer: 0/0/2012
6000 Delivered To Customer:0/0/2012
1BADZL1 is offline   Reply With Quote
Old 12-09-2011, 08:00 AM   #2
SSMickey
SECC
SSMickey's Avatar
Drives: 2010 IBM 2SS
I have been thinking about this very subject today. I have looked on tire rack and the all season/winter selection is very limited. Few choices for the front and none for the rear, if you keep the factory size. From my research, the front tire diameter is .5 inch smaller than the rear. My initial thinking is to run a 285/35-20 all around for winter. I don't think the half inch differance will affect the speedometer, traction control calibrations too much. The tire I'm looking at is this one.
http://www.tirerack.com/tires/tires....Z2XL&tab=Sizes
Since I'm going to hate to change tires twice a year and run the risk of damaging the rim and TPMS sensors, I'll just have to pop for 4 additional front wheels. Going to be interesting to get the pricing from GM on then. $$$$$$$$
Vengeance Stage II Cam, Halltech CAI, RX Catch Can, Full ARH Exhaust, QTP Cutouts, Powerbond 25% Underdrive, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
SSMickey is offline   Reply With Quote
Old 12-09-2011, 09:04 AM   #3
wilmaya
wilmaya's Avatar
Drives: 1970 Chevelle SS396/496
My thought is that all I need is a wheel package which would allow me to use the car on nice cold days. I won't take it out while there is snow on the ground or it is melting, If you know what I mean. These F1's are opening a can of worms for me. At least I have until next winter to think about this.
wilmaya is offline   Reply With Quote
Old 12-09-2011, 09:16 AM   #4
1BADZL1
THE CAMARO KING
1BADZL1's Avatar
Wink
Exactly. Thats why I want to try and get it out of the way now especially if I have the funds to do so now, then wait until next cold season...
I want it to be a complete non issue when the time comes...
Just the way I roll....
Current Status:
2030
Old 12-09-2011, 09:22 AM   #5
jmart53
jmart53's Avatar
Drives: 2012 Cruze LTZ RS
Front: 22798741 MSRP: $1038 each
Rear: 22798743 MSRP: $1041 each
I believe those are the part numbers and I don't believe they are available yet, as I am looking to get some for my SS, but need to make sure they will fit the SS model first.
Either I will buy some from a ZL1 owner who goes aftermarket for wheels or else repros or just OEM from GM for more $
jmart53 is offline   Reply With Quote
Old 12-09-2011, 09:23 AM   #6
1BADZL1
THE CAMARO KING
1BADZL1's Avatar
Wink
This appears to be the black SSX wheels...
Front: 22798741 MSRP: $1038 each Price: $784.30
Rear: 22798743 MSRP: $1041 each Price: $786.23
http://www.gmpartseast.com/parts/gm-22798741_wheel.html
Current Status:
2030
Old 12-09-2011, 09:34 AM   #7
The Stig
knows 2 facts about ducks
The Stig's Avatar
That's not horribly expensive.
Click to view my build thread
Old 12-09-2011, 09:37 AM   #8
htron50
htron50's Avatar
Drives: 2017 ZL1 Status "Thank You!"
Good find on a winter tire. $500 bucks x 4 + rims + sensors + chance of mishandling! $2000 ++ Looks like you have the tire ID'd. Now we need some rims. It's just money. (ha)
htron50 is offline   Reply With Quote
Old 12-09-2011, 09:39 AM   #9
htron50
htron50's Avatar
WHOLEEEEEE MCMUFFIN. Gotta be a cop car wheel of some sort!
Old 12-09-2011, 09:51 AM   #10
1BADZL1
THE CAMARO KING
1BADZL1's Avatar
SportContact 3 285/35 ZR20
$426
http://tinyurl.com/7fe8j89
Nitto 305/35 R20
$341.90
http://tinyurl.com/7db5462
Current Status:
2030
Old 12-09-2011, 09:52 AM   #11
Scarrzz
No Fear-No Limits- Camaro
Scarrzz's Avatar
Drives: '13 ZL1 or Suzuki Hayabusa
(I know, not quite on topic, but it had to be said.)
__________________________________
................................................The Faithful are Watching.
Scarrzz is offline   Reply With Quote
Old 12-09-2011, 09:55 AM   #12
1BADZL1
THE CAMARO KING
1BADZL1's Avatar
its times like these that are hard to keep the faith......
Carry on grasshopper....
Current Status:
2030
Old 12-09-2011, 10:03 AM   #13
Scarrzz
Scarrzz's Avatar
This is a cross-post quote. Shnomac suggested taking a look at these in the other tire/temp thread. Seemed relevant.
Originally Posted by ShnOmac View Post
Granted its on my G8 GT but I am running Continental extreme DWS's and have been very pleased with them. We routinely hover in the low teens during the cold months. Are you worried about snow or just cold weather performance?
http://www.conti-online.com/generato...ct_dws_en.html
They look like great cold weather tires, but I didn't see any 20" 305s.
Old 12-09-2011, 10:22 AM   #14
1BADZL1
THE CAMARO KING
1BADZL1's Avatar
Conti 285/35ZR20 100Z
$406.34
Unless I missed it somewhere... I do not see a conti for the rears...
Current Status:
2030
