sjm autoprod
Old 12-25-2012, 01:48 AM   #463
JusticePete
VIR Specialist
JusticePete's Avatar
Drives: Camaro Justice
God Bless Us, Everyone. Merry Christmas!
Old 12-25-2012, 02:06 AM   #464
Kronix
NJ/SoCal HT5 COTW 3/25/12
Kronix's Avatar
Drives: 2015 Z06/14 C7/08 Z06/07 Tahoe Z71
Same to you Pete & the Pedders Family!!!
Thanks for everything!!!
Built by Late Model Racecraft
Fastest C7 in Tri-State 10.13 @ 134mph
7/26/14 Corvette Challenge Raceway Park, E-Town, NJ
Kronix is offline   Reply With Quote
Old 12-26-2012, 04:16 PM   #465
Kronix
Kronix's Avatar
Got a nice Christmas present from Uncle Pete @ Pedders!
The R&D set of Camber plates used for the production camber plates coming out in January, and a Bad Ass Pedders NO BULL shirt! Pete & Deb, you guys ROCK!
Now to get them powder coated & installed......It's got end some day right???
Should have the car back from Cunningham Motorsports hopefully by Friday, as the cam & other goodies install went smooth. Can't wait to feel the REAL DEAL!!! Then be on the look out for pics & videos!
Special Out & Thanks to Ted Jannetty of Jannetty Racing for taking the time to call CMS and go over a few questions the guys had about one of his parts. I know it was very hectic right before the holidays and I appreciate Ted taking the time!
Old 12-28-2012, 11:32 AM   #466
Kronix
Kronix's Avatar
Have to report misinformation & it's good stuff, especially for my bros in the cold weather areas. Just got confirmation today:
Originally Posted by SolomonAKOO View Post
The mirrors look great!! Do they still have the defroster on them as well?
Originally Posted by AACstyle View Post
Yes, these mirrors are heated. If you already have heated mirrors you do not need to do anything, just plug them in. If you do not have the factory heated mirrors option you can jump power off the defroster to heat the mirrors. We are going to do a DIY once we get a Camaro in here without the heated option.
That's so AWESOME!!!!!!!
Old 12-28-2012, 11:46 AM   #467
TCAT
TCAT's Avatar
Drives: Has Wheels
The camber plates look bitchin man. Let us know how the R&D goes. Pete is one hell of a cool guy.
TCAT is offline   Reply With Quote
Old 12-28-2012, 01:05 PM   #468
SolomonAKOO
SolomonAKOO's Avatar
Drives: 2011 2SS/RS
Thanks brother!! That's awesome I'll have to make an investment then! Oh and I hope you and your family had a great Christmas! And also have a happy New Year!
1 7/8" TSP headers straight piped, Custom Tick Performance cam w/ supporting mods, 1" BMR springs and other BMR suspension mods. Tuned with HPtuners by Matt@FSP
SolomonAKOO is offline   Reply With Quote
Old 12-29-2012, 02:37 AM   #469
Kronix
Kronix's Avatar
Thanks T, I'm sending them to Specialized Coating in Huntington Beach to get powder coated next week. Pete's the F**king man!
I posted that for you brother, I knew you'd love to hear that you can use those mirrors. Thank you brother & I wish the same to you & your family!!!
Old 12-29-2012, 10:37 AM   #470
Kronix
Kronix's Avatar
Well, someone let the cat out of the bag and I'll fess up as to my latest purchase. I ordered the Hammerhead Stage 2 IRS coated with NitroPlate with DSS Carbon Driveshaft & 1400HP Half Shafts, shortly after the SEMA show. And once I decide on which slotted & cross drilled rotors & calipers I want, this will be the last piece of the engine/driveline modifications for me, besides some cosmetic stuff. I can honestly say I'm done, dear God I hope so!!! Can't believe I actually said that!
The Hammerhead Unit with Pedders bushings that are standard in the HH.
I got mine coated with NitroPlate, in Stealth Black. It's a ceramic coating that's satin black and withstands temps up to 1700 F & is highly resistant to gasoline and all other common “under-hood” chemicals. It's also highly chip resistant., so virtually bullet proof.
Before the NitroPlate is sprayed on my unit.
These were just released this month and they had a special on them before December 15th, and it was an offer I couldn't refuse! One of the many things I love about this unit is it comes standard with Pedders HD bushings & the optional Delrin rear bushing for higher HP cars. The 3 pieces together are as another member who bought the DSS Carbon driveshaft & 1400 HP shafts said they're works of art, and I can't agree more. Judge for yourself.
The Driveshaft Shop's (DSS) 3 3/8" Carbon Fiber Shaft weighs in at a whopping 15.5lbs and will come with a 30 spline end, not the typical 28.
The CF Shaft, pure work of art!
Billet Plates:
Carbon Ends:
The 1400HP Shafts:
Cage Comparison:
So what's a Hammerhead, besides a shark? Well once you start getting up there in horsepower, it can wreak havoc on a driveline. That horsepower will find the weak part of your system, and more often then not, it ends up being the rear differential of the vehicle. That's is what led The Driveshaft Shop and Hammerhead housings to partner together and build the Hammerhead, a 12 bolt independent rear suspension(IRS) for late model vehicles.
The Chevy Camaro Hammerhead IRS which they had on display at the SEMA show, will come available in three stages:
Bulletproof Stage 1
33 spline Eaton TrueTrac for normally aspirated cars. 3.42, 3.55, 3.73, 3.90, 4.10, 4.30, 4.56, and 4.88 ratios.
Bulletproof Stage 2, the unit I got with 3.90 gearing.
Optional 35 spline WaveTrac with lifetime warranty for supercharged and manual transmission applications.
Indestructible nodular iron casting also available for applications over 1000HP, I chose to go with the cast aluminum.
Indestructible Stage 3
Optional solid spool and 9310 alloy “Pro Gears” for racecars only, 4.11, 4.33, 4.56, 4.75, 4.88, and 5.00 ratios.
12 bolt IRS Hammerhead Benefits and features:
Contains 1400HP capable 30-spline axles.
Less horsepower loss than a 9″ Ford.
Large access to gear ratios, posi-units, and even racing spools
Cast aluminum, and available in nodular iron for extreme use.
So now it's just waiting for the Big, Brown Truck to swing by the crib!
Updates coming soon!
Old 12-29-2012, 10:41 AM   #471
Tribute
Tribute's Avatar
Drives: 2012 SLP ZL770 #17 (Hugger Orange)
Perhaps one of the most modded Camaros? Looking good man! I better see you at the track with this beast! If we can ever swing it we need to hit up a road course together, would be fun.
Tribute is offline   Reply With Quote
Old 12-29-2012, 10:47 AM   #472
TCAT
TCAT's Avatar
Drives: Has Wheels
Congrats John! You'll love all those new components. Take pics of the entire install. It will be a car you can beat on now without much worry about leaving shit all over the pavement, lol.
Old 12-29-2012, 11:00 AM   #473
Kronix
Kronix's Avatar
You were posting in my thread as I was posting i yours LOL!!!
You know it brother!
I hear that T!! But I'm more confident in saying it's almost done .............................Right?
Old 12-29-2012, 11:06 AM   #474
TCAT
TCAT's Avatar
Drives: Has Wheels
Haha, I know how you feel. Sometimes it's as if it never ends. I am close to calling it quits as well except for some fun small things, especially do it yourself (DIY) mods. I have other things I want to concentrate on, especially since I want to buy a house with my girlfriend, so saving money is key right now.
Old 12-29-2012, 11:07 AM   #475
pierre777
HT5 COTW 9/3/2012
pierre777's Avatar
Drives: Cyber Bullet
your car will become the strongest and super badass camaro ever seen , and no you will never be done , i've heard that one many times before .
Old 12-29-2012, 11:11 AM   #476
Kronix
Kronix's Avatar
Haha, I know how you feel. Sometimes it's as if it never ends. I am close to calling it quits as well except for some fun small things, especially do it yourself (DIY) mods. I have other things I want to concentrate on, especially since I want to move into a place with my girlfriend, so saving money is key right now.
Hey T, it's gotta help with the resale value if I pull the trigger on a C7 right?
LOL I said it before, I'll say it again my Brotha P, at least I ain't hooked on heroin or crack right? Then I'd have nothing to show for the $ the goes
car of the week, cunningham motorsports, magnuson supercharger, pedders, zlx
CAMARO WIKI Tran Wiki 55 03-28-2017 01:04 PM
SSMOKINHOT’S SINISTER SCARLETT (SS) [COTW 12/19/11] SSMOKINHOT Member Car Journals 232 05-07-2014 10:46 AM
Camaro SS Transformation (Bumblebee) Update Pic's Audrey2010Camaro Camaro Photos | Spyshots | Video | Media Gallery 10 12-13-2012 02:50 PM
Camaro SS Transformation (Bumblebee) Audrey2010Camaro Camaro Photos | Spyshots | Video | Media Gallery 35 07-14-2011 06:52 AM
Pedders Camaro Begins the Transformation to the Pedders Revolution Camaro Info@PeddersUSA.com Cosmetics and Lighting Modification Discussions 192 01-03-2011 04:02 PM
