Old 12-11-2011, 07:04 PM   #15
cjt037
boost+v6=me=:)
cjt037's Avatar
Drives: Turbo'd 6er
I understand the need of having a backup turbo. so no downtime on your car. but eaby is kinda fishy. but if its only a backup
http://www.camaro5.com/forums/showthread.php?t=185528
435.7 RWHP 405 RWTQ
JUST A LITTLE V6... Try me
cjt037 is offline   Reply With Quote
Old 12-11-2011, 07:32 PM   #16
Mach
Mach's Avatar
Drives: White M6 1LT RS
Do the V6 and V8 share the same stock exhaust?
Pfadt Sway Bars - FE3 Suspension - Barton Shifter - IdealG's Clutch Master Cylinder - Trifecta - Vmax TB - Vararam Intake - MACE 25mm Insulator - Plenum Insulator - Ported/Gasket Matched Intake Manifold - Rx Catchcan - AAC DRL's - 4 Pack Aux Gauges - Steering Controls - AAC Afterburners - DIY Led Sidemarkers - ZL1 Front End
Next mod: Done!
Mach is offline   Reply With Quote
Old 12-11-2011, 07:53 PM   #17
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 11 F150 EB/13 Sonic RS/15 Z06
Nope, different diameter at minimum. As for protecting the turbos, I had a local shop build a skid plate to protect the mid-mounted ones. I'm pretty sure you could do the same for the rear mounted ones, too. Just an idea.
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread
GretchenGotGrowl is offline   Reply With Quote
Old 12-11-2011, 08:07 PM   #18
Pt_killa
Pt_killa's Avatar
Drives: Black 2010 Camaro V6
Yea they are but since the maro is my only car and I couldn't get a loaner froma family member that week, I couldn't have any downtime since I need my car to get to work. If the maro was just my weekend warrior, it would've never got the ebay treatment lol! Oh the pt6765 I'm running now for the past 5 months is a craiglist used turbo, just gotta know what your looking at.
Engine bay mounted would be awesome but will require some movemnet of things in the engine bay.
(Sold Sept 2015) Stock 18" Heritage w/ BFG G-Force ZR tires / Blacked out bowties and tail lights / DIY Remote-Mount Turbo Kit (Precision 6776S .81ar ex. @ 6.5psi, Tial 38mm WG, Greddy Type-S BOV) / RX Catch Can / RX-FTI 3600 Stall / Blue Well Lights / Team LLT
Pt_killa is offline   Reply With Quote
Old 12-11-2011, 08:22 PM   #19
cjt037
boost+v6=me=:)
cjt037's Avatar
Drives: Turbo'd 6er
the rear mount intake is right above the turbo so a skid plate would stop alot of the air from going into the intake/ and cooling the turbo
435.7 RWHP 405 RWTQ
Old 12-11-2011, 08:24 PM   #20
GretchenGotGrowl
Doesn't have to be big, just enough to deflect stuff from hitting the turbo. You could also have the cut louvers in it.
Old 12-11-2011, 08:27 PM   #21
Macrackie
Macrackie's Avatar
Drives: 2011 Camaro LS Stripper model
Pretty sure the exhaust is the exchangable from v6 to v8 from anywhere behind the cats. V-8 was just half inch bigger dia. if memory serves me right. I know there is a old post of a guy running the cherry bomb cat back for a v8 on his v6. Sounded bad but it fit.
If there is someone out the looking to do a custom engine bay mount v6 turbo many parts of this kit would probably cross over very well. To boot we would have alittle more clearance to mount the turbo due to the lack of 2 cylinders.
Wish I just had the money to try it. Sure woud be fun to be the first engine bay mounted v6 turbo that works.
Macrackie is offline   Reply With Quote
Old 12-11-2011, 08:30 PM   #22
Mach
Mach's Avatar
Yes thats what I was thinking.. Plus its a good price w/o the tune!
Next mod: Done!
Old 12-15-2011, 07:11 PM   #23
Macrackie
Macrackie's Avatar
Bumping this just a bit. Maybe gretchen or tracy could chime in on this. My question is if 90% of these parts would fit what kind of problems would one run into with this kit by retro fitting to our 6. You two have the largest fi knowledge i know of.
Old 12-15-2011, 09:42 PM   #24
Kwarren
Kwarren's Avatar
Drives: 2010 Camaro 1lt
Check with SC2150 with rx performance. They were doing the supercharger and turbo builds I talked to him about it swell I want the turbo kit because people are just seeming to get better numbers from them rather than the supercharger. He said they would do a engine bay mounted turbo kit for a limited time.
Kwarren is offline   Reply With Quote
Old 12-15-2011, 10:02 PM   #25
blackTT600
Drives: 2011 2LT M6 SC
Im going to be at RX on saturday talking to Tracy. I as well want a engine bay turbo kit. I figure a larger single mounted where the air box is now. It gives you all the power + some thing to look at when you pop your hood.
blackTT600 is offline   Reply With Quote
Old 12-16-2011, 08:25 AM   #26
SC2150
We can build a system for the engine bay....just the heat issues are the main reason we do mid-mounts.
What do all the abbreviations mean? CrzyGamr2 5th Gen Camaro SS LS LT General Discussions 77 12-07-2012 05:34 AM
CEL - P1682 PSU SS Tuning / Diagnostics -- engine and transmission 4 09-29-2011 08:27 PM
Wildlife in engine bay jagan323 5th Gen Camaro SS LS LT General Discussions 56 02-07-2011 06:34 PM
The BEST Break for a new car. "very long" Darin Morgan General Automotive + Other Cars Discussion 346 02-04-2010 07:49 PM
Pfadt Race Engineering releases new Camaro V8 Engine Mounts PfadtRacing Suspension / Brakes / Chassis 6 01-15-2010 01:58 PM
