| Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust |
Thread Tools |
#51 |
![]() Drives: 2010 Camaro 1SS/RS Join Date: Jan 2011
Ok thanks Mike!!
TSP Cam 231/236 112 LSA,TSP UD,Fast 102 w/Ported TB,AirAid CAI,1 7/8 catted Stainless Power LT,3 IN MBRP 3 in Exhaust/180*,Spohn LTA's,Toe Links, Drag Bar,Diff bushings,Hurst shifter,Hendrix/DSS 1400HP Axles,Nitto NT555R's,Lethal Performance Custon Tune 480 RWHP 454 RWTQ!! Best run so far is 11.94@121 LPE 3.91's Coming soon NW 102, and DSS DS, then car should be complete!!!
#52 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 aqua blue SS/RS M6 Join Date: Feb 2010
That car definitly makes me happy I went with the ls3 M6! How awesome is that shifting and launch! When I see cars that fast slaming gears it just makes it that much cooler
#53 |
![]() ![]() Drives: 2005 C6 Join Date: Apr 2011
Thanks for the props guys.
#54 |
#55 |
Awesome car, I love that idle. Which way was the cam advanced for this application? Why does a car like this not have a steady idle (it sounds like a horse with staggered footfalls)?
It said a custom 4.1 gear set, are the 1st and 2nd gear "closer" together which is why he shifted so fast through those? Or is it because at low speeds the power of the engine can accelerate through the rpm range quicker? I'm trying to self teach myself everything, not that I'd be able to do to an engine for years probably. Aside from a college, where could I learn the specifics on how to do something like this? Also, since he has 515rwhp, the number would be larger if taken straight from the engine right? I know a lot of people like to state engine HP. For example my 2011 v6 is listed at 312, but the Dyno numbers are like 250? So if he were to actually compare his number to people who use engine hp, he should add ~15% correct? = ~75 in my head. |
#56 | |
Thanks for the props masonwader, that idle is due to the longer than stock duration and increased overlap valve timing and is much desired, music to my ears kind of sound. The cam is installed at "0" since it's a custom cam and all the advance is done in the way it was ground.With 4.10s the engine revs quicker so yes first and second gear come up fast. You can learn this from reading about it on the forums (not all you read is true though) but the best place to learn is to try things on your own car. Yes, 515 RWHP is about 15% higher at the crank so roughly 592 BHP. HTH, Julio |
#57 |
#58 |
![]() ![]() Drives: 2010 M6 2SS Join Date: Mar 2011
My heads and cam should be arriving at my house today...my intake is already there...I can not wait!!!
I didn't go with your package...but I have nothing but good things to say about how your stuff runs...I just hope I can keep up!!!
2010 Camaro SS M6. Heads/Cam/Intake/Headers/Exhaust |
#59 |
![]() ![]() ![]() ![]() ![]() Drives: Black 2010 1SS M6 Join Date: Nov 2009
What did you go with?
Performance Mods: PRC 250cc Aftermarket Casting Cylinder Heads, G6X3 Cam, Fast 102 Intake, Nick Williams 102 TB,Stainless Works 2" Long Tubes, Flowmaster AT Cat-Back, C.A.I. CAI/ADM Scoop, SLP UD Pulley, PFADT Springs/Sways/Rear Trailing Arms, Pedders Subframe Bushings, Energy Differential Mounts, Spohn Toe Links, BMR 2-Point STB, LSR Tunnel Brace, Hurst Short Throw, COR Velocity V3 Wheels, 305/35/20 Nitto NT555R's
Finishline Performance Install and Dyno Tune-505 RWHP 464 RWTQ |
#60 |
I'll post a new thread when I start getting it together...I don't want to take over Cartek's thread.
#61 |
Good luck Mike.
#62 |
#63 |
#64 |
CorkTulsa.com
Drives: 2010 2SS BLK, 2013 2SS CRT Join Date: Feb 2010
Awesome build guys! I think we need to talk head work with you! :-) Looks like a sweet upgrade! My pistons are already fly'd and my cam is quite healthy. would do nice with a ported TB Fast 102 and ur heads.. YEEEEEUH!!! :-)
#65 | |
Julio |
#66 |
![]() ![]() Drives: 2010 camaro Join Date: Jun 2009
Congratulations to Cartek on another hard running combination.
By the way, THAT'S A NICE VARARAM RAM AIR SYSTEM YOU HAVE ON THERE! VR Tech |
#67 |
VR tech
Call us Monday, Its time for you to break 130MPH !
We have just the prototype parts for you to do it with. VaraRam Tech |
#68 |
#69 |
#70 |
Can't wait to try the new VR Patrick, sounds like there is more in it.
#71 |
TRI-COUNTY CAMARO... FTW!
Drives: 2010 Camaro 2SS M6 Cyber Grey Join Date: May 2010
Launch at 4500!!!!! Damn!!!!
CAI inc. cold air intake, LG G6x3 cam, Patriot Gold Extreme Dual springs, Titanium retainers and locks, LG SuperPro 1 7/8 Long Tube headers with full 3" exhaust, DynoMax VT mufflers, SLP 4" tips, Moroso catch can, Race Ready electronic exhaust cut outs, Full painted Razzi body kit, Headlight Armor Smoke taillight and marker blackouts, T-Rex aluminum upper and lower grille, Polished aluminum front and rear bowties. Professionally installed and Dyno Tuned by HorsePower Sales, Pompano Beach FL.
#72 |
![]() Drives: 2010 camaro ss Join Date: Feb 2012
Congrats on the run. What aol does the car have done to it just headers cam heads and gears. Show them mustangs how its done.
Texas speeds 1 7/8 longtube headers and full exhaust vararam air intake. Lethal racings night fury cam and yank 3400 stall. Dyno tuned by lethal racing 465 rwhp 434 rwtq.
#73 |
NOW CAMMED & SUPERCHARGED
Drives: 2010 Camaro 2SS/RS Black w/ IOM Join Date: Oct 2008
Wat would this head cam package do on a maggie car?
Livernois Motorsports: Maggie 2300 7psi, Livernois 2C cam/L99 to LS3 Conversion, Ported TB, Rotofab w/adm race scoop, adm trans cooler,Kooks headers no cats, Kooks 3" exhaust. METCO breather. Precision 2400 Vigilante TC. Eibach Lowering Springs & Swaybars. BMR Trailing arms, BMR Rear Cradle Bushings, BMR Toe Rods, BMR Differential bushings. Vossen CV3 20's w/ 305 Nitto 555R@25psi. Zl1 front bumper. OE Zl1 Hood and matte black insert. 556RWHP/500RWTQ L99
#74 |
#75 |
| Thread Tools | |
