SDPC
Old 12-14-2011, 04:50 PM   #1
austinjames
Account Suspend...Right
austinjames's Avatar
Drives: Synergy LS & Vulcan 1600cc
PS3 & Xbox360 & Subs in my Camaro PICS
Well I built a xbox360 padded shelf in my car a while back and Just had a subbox sitting in the trunk. It was sloppy and took up nearly all of the trunk. Also, to swtich xbox games I had to pull over and pop the trunk.
So, I decided to build a sub box and 2 padded shelves one for my PS3 and One for the xbox. Now, I can watch blurays in the car and then play GTA IV all day.
austinjames is offline   Reply With Quote
Old 12-14-2011, 04:59 PM   #2
Kevinshawnm
Biggz
Drives: 2010 Camaro 2SS L99 Rally Yellow
How are you keeping them cool?
Kevinshawnm is offline   Reply With Quote
Old 12-14-2011, 05:02 PM   #3
Sarah
Sarah's Avatar
Drives: Camaro LLT ABM
Exactly what i was thinking. That older xbox gets hotter faster than the slimmer versions. PS3 a little bit harder.
cod sucks*cough COUGH cough*
Sarah is offline   Reply With Quote
Old 12-14-2011, 05:05 PM   #4
Camaro_Corvette
36.58625, -121.7568
Camaro_Corvette's Avatar
Drives: Team 1LE
He must not plan on playing long. better have some added fans.
Old 12-14-2011, 05:06 PM   #5
lanzajr26
Drives: 2012 SS Inferno Orange
LOL, that's pretty cool, but I have no idea when I'd ever want to game in my Camaro. I barely have time to do it in my actual home!
lanzajr26 is offline   Reply With Quote
Old 12-14-2011, 05:08 PM   #6
austinjames
Yes there is a fan hooked to my power inverter behind the shelves, so when I flip the inverter switch the fan goes on .
Old 12-14-2011, 05:20 PM   #7
austinjames
Thanks, Its more for the passenger/s on long trips, and when I go to car shows.
Old 12-14-2011, 11:19 PM   #8
battlekat
battlekat's Avatar
Drives: the red dragon
looks great but wouldn't the speaker eventually rattle their internals apart? also, you should make a one piece frame so that you cover up the foam.
battlekat is offline   Reply With Quote
Old 12-14-2011, 11:23 PM   #9
FNG
Tampa Bay Camaros
FNG's Avatar
Drives: Rally Yellow 2012 ZL1
I'm thinking of something like that too... However you should consider some serious cooling back there. There doesn't look to be much clearance around the consoles either. Just the temp fluctuations of being in a trunk can cause the thermal paste to separate from the heatsink & processor.
FNG is offline   Reply With Quote
Old 12-15-2011, 12:31 AM   #10
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Drives: '15 STI, EB Expy,'10 2SS/RS M6, KB1
No disc scratching for the 360? If my 360 is bumped, I get concentric scratches on the disc and it is ruined. I know there are/were a few different optical drive manufacturers, maybe this could be the difference.
Nitrous Outlet Plate (progressive, fuel hose upgrade, remote opener, heater, filter, console switches), LNC2000, ARH 1 7/8" LTs/gutted cats/X pipe/mufflers, Jet Hot coated LTs, JRE SCT Tune, CAI, Scoop, Rx Catch Can, Gates heater hose relocation, Remote clutch & auto brake res, Metco loop, Momentum Tunnel Brace, TSW Nurb 18" 555 & 555R, Pfadt trailing arms & toe rods, Autometer wideband, Fesler Pillar Pod, LED strips (int), Lloyds floor & trunk mats, LED DRL/front turn & license plate, DRL harness, VLEDs tail lights, Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17 @ 112.6 stock
Badbubba is offline   Reply With Quote
Old 12-15-2011, 12:35 AM   #11
25thanniversary
25thanniversary's Avatar
Drives: 92 Camaro Convt RS,2011 Camaro RS
looks good
TEAM LLT
1992 Camaro Rs Convertible
2011 Camaro 1lt Rs
25thanniversary is offline   Reply With Quote
Old 12-15-2011, 01:08 AM   #12
austinjames
I was worried about the bass messing up the internals, So, thats why I made them two separate pieces
I have a fan that puts out a lot of air back behind the 2 consoles
No scratching in a 3 hr drive with the xbox on. Thats why the foam is there.
Originally Posted by 25thanniversary View Post
looks good
Thanks
Old 12-15-2011, 01:16 AM   #13
The Shadoww
Black on Black on Black
The Shadoww's Avatar
Drives: 2011 Camaro 1LS
Send a message via Skype™ to The Shadoww
You sir, are brilliant. I will be doing the same when i get a navi.
The Shadoww is offline   Reply With Quote
Old 12-15-2011, 01:23 AM   #14
austinjames
Thanks man.
If you decide to add either system, make sure your power inverter you buy is at least 800W AND hooked to the battery terminals with the rings (NOT crocodile clips)
Anything under 800W will not power either system, and if you use the crocodile clips on the battery terminals and not the rings you will see static lines on the screen.
CAMARO WIKI Tran Wiki 56 Today 12:04 PM
PEDDERS SUCCESSFULLY FITS 305s ON ALL 4 CORNERS! Info@PeddersUSA.com Suspension / Brakes / Chassis 467 06-11-2013 09:45 PM
Transcript of Camaro ZL1 Q&A Webchat with Chevrolet Tran Camaro ZL1 Forum - ZL1 Specific Topics 38 02-17-2012 12:45 AM
Im sure this has been asked before.. But forgive my innocence :) gmag21 Suspension / Brakes / Chassis 23 02-21-2010 10:29 PM
The DEFINITIVE EXPLANATION OF CAMARO SUSPENSION, ISSUES, AND UPGRADES Info@PeddersUSA.com Suspension / Brakes / Chassis 106 10-19-2009 06:08 PM
