Centerforce Clutches
Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust
Old 04-26-2012, 12:31 PM   #926
572HP
ACE5 (Atlanta Group)
572HP's Avatar
Drives: "Black Ice"
Originally Posted by EZ SPEED View Post
What coolant overflow tank did you use...I need to change mine out to something smaller than the factory one...I need the space for some other stuff.
BilletSpecialties (8.75" tank)
I had to make up a bracket out of aluminum (but you could use steel). I mounted the new bracket to the pinch weld on top of the frame. I know...a picture would help.
Originally Posted by SS4PK View Post
572,
That looks great. Is your car so fast you don't need windsheild wipers, or did you just not put them back on yet?
Probably not legal without them...but I am leaving them off, as well as the plastic piece that mounts to the hood. I'll leave the wipers in the trunk in the odd case that my planning doesn't work out so well. I don't plan on driving the car in the rain.
Originally Posted by Kronix View Post
@572HP that bay looks great!!
Can you tell me where you got the black bolts & washers & sizes for your strut tower brace?
Thanks Kronix,
The bolts are ARP 12-pt, and are M8 x 30mm. 6 of them are needed. The 5-pack is part 671-1003 for the black. Polished are available, but a different part number. I also used their chamfered washer: part 200-8688. These washers aren't a perfect fit on the M8 bolt, but they are close.
Honored to be Camaro of the Week:
[COTW 5/2/11] 2011 Two-Tone White/Black SS/RS Convertible
See our Atlanta Social Group or home page: ACE5.org
572HP is offline   Reply With Quote
Old 04-26-2012, 09:20 PM   #927
Nathan Moreno
Nathan Moreno's Avatar
Drives: G5R
Okay, just finished the passenger side. Went by my local powder coater today to look at some options. I thinking I'll powder coat the oil pan, timing chain cover, motor mounts, heat shield that goes mounted to the starter and the valley plate in the same finish powder coated finish.
Got my paint supplies to paint the engine and bay today also. So I moving one step at a time.
Before....
After......
Nathan Moreno is offline   Reply With Quote
Old 04-27-2012, 01:12 AM   #928
LC
MAUDERFAUKER
LC's Avatar
Drives: SW 2SS x2
Are you blocking those by hand?
Mad patience skills...
LC is offline   Reply With Quote
Old 04-27-2012, 11:54 AM   #929
bmbbl be
bmbbl be's Avatar
Drives: camaro ss-05chopper-13-street glide
nathan i commend you for taking on such a project but you might as well look into removing drivetrain and painting underneath like ezspeed did !
bmbbl be is offline   Reply With Quote
Old 04-27-2012, 04:03 PM   #930
Nathan Moreno
Drives: G5R
Jitterbug and by hand........ your right on the patience part...... not to sure about the skill, lol
Thanks, I am pulling the trans along with the sub and painting the entire bay in a satin gray. I'm also looking to powder coat the sub in a textured gun metal gray. My local powder coated has a 20 foot oven. I would do the floor pan but I don't have a two post lift. So that might be a future project. At least thats the plan for now, LOL. Next month should be exiting!
I also purchase a mig welder and I'm going to fill all the holes in the engine bay along with some of the seems.
As of right now, I'm looking to pull the heads this weekend, deburing them and sending them to Lingenfelter for some of their magic.
Wish me luck because I have never done any of this before, so I'm going to need it!
Old 04-29-2012, 03:15 PM   #931
Nathan Moreno
Drives: G5R
Got the heads off and was cleaning them some before I send them to Lingenfelter for some of their magic.
I figure I post this shot of the runner as a comparison for when I get the back.
Here's a pic of the rough casting.
And hers after a ton of work, LOL
Notice the red circle and the heads thats been smoothed. The factory casting was squared till I rounded it off to match the others. That only took two minutes..... sure, LOL
Here's a before......
And after but not finished ........
That's it for now. Another friends birth day party. To many parties. I'm going to have to get rid of some friends, they are infringing on my project, LOL
By the way, I need some new addicts..... I mean recruits! Starting to get lonely now that NC-V, Indy, Roctrux, 572HP and PaulSS have all finished their cars. :(
Old 04-29-2012, 03:36 PM   #932
Synner
Drives: 2011 2SS/RS M6
Started smoothing the water pump but going to take me quite a while. The sand casting is horrible. Probably need to do a brushed finish because the surface has tons of imperfections. Would grind all the way through the pump trying to get rid of them all.
Synner is online now   Reply With Quote
Old 04-29-2012, 03:46 PM   #933
572HP
572HP's Avatar
Drives: "Black Ice"
Originally Posted by Nathan Moreno View Post
By the way, I need some new addicts..... I mean recruits! Starting to get lonely now that Indy, Roctrux, 572HP and PaulSS have all finished their cars. :(
+1
Need more to watch.
Old 04-29-2012, 04:11 PM   #934
Nathan Moreno
Drives: G5R
Believe me, I know what you meqan about rough casting!
Originally Posted by 572HP View Post
+1
Need more to watch.
I'm getting a lot of PM's from other guys that are starting on their projects. So we should have more team members soon.
Old 04-29-2012, 04:21 PM   #935
RocTrux
RocTrux's Avatar
Drives: Summit White 2011 2SS/RS
Oh I'm not done yet, there are other parts of the car to mod too. I just installed a Pedders 27mm rear sway bar and end links the other day that I got from a C5 member. I'v got another piece of under hood bling on the way and some LED lights. I think I have found where to get the intake bolts that will match the ones I used for the throttle body, then I will paint or powder coat the intake along with a few other tweaks, changes and additions I'll be making so I will be here for a while.
RocTrux is offline   Reply With Quote
Old 04-29-2012, 05:33 PM   #936
bmbbl be
bmbbl be's Avatar
i'm holding out for a chrome one that is mechanical and not electric. i thought about working on the stock one but i decided it wasnt worth it
Old 04-29-2012, 08:01 PM   #937
Synner
I was going to as well but got impatient. Since I was doing some other buffing I figured I might as well since the pump is the biggest piece on the front of the engine that needs attention. I'll do the pump, tensioner, and steering pump bracket and then see how things look. Maybe the pulleys themselves are next but I'd rather put the cash towards a cam.
Old 04-30-2012, 08:19 AM   #938
EZ SPEED
SIXXSPD
EZ SPEED's Avatar
Drives: 2010 Camaro SS
Yep, add me to the "finished" list ...well at least till winter...then it will be time to tear back into it again..LOL
EZ SPEED is online now   Reply With Quote
Old 04-30-2012, 08:50 AM   #939
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
Sounds like a candidate for powder coating.
Done for this season, come November, I will have to decide how I want to proceed. I can tell you it won't be as extreme as some others.
The Few, The Proud, The Aqua Blue Metallics 709 of 3903 New England Camaro5 . My Camaro Journal
Heritage Grill, Cold Air Inductions Intake, Elite Engineering Catch Can, BMR 1" Lowering Springs, Sway Bars and End Links, Clear Image Jet Hot Ceramic Coated headers and High Flow Cats, Hurst Billet 2 Shifter, LSR Billet Strut Washers, DynoMax Axle Back Exhaust, JANNETTY MAGIC!
Old 04-30-2012, 09:05 AM   #940
Nathan Moreno
Drives: G5R
Okay, updated list:
EZSPEED: Done till winter
572HP: Done till winter
PaulSS: Done till winter
Kyle aka NC-V: Al most done with current project (except for AC lines)
Synner: Work in progress
Roctrux: Work in progress
Blbbl be: Almost done? (I'm thinking .....got to be with as much work as you've done)
Indy: Done for now, LOL
Nathan: I'm updating my projected time to 4 months base on everything I have going. I can put about 10 hours a week into it.
I'll update the list if I left anybody out.
Old 04-30-2012, 09:09 AM   #941
Synner
I don't want to open up the seals on the pump, they're pressed in and they never seem to last as long once they start getting messed with. Otherwise I'd agree.
Old 04-30-2012, 10:08 AM   #942
bmbbl be
bmbbl be's Avatar
Okay, updated list:
almost done car is at livernois getting supercharger installed ....then i'll be about 90% finished,,,,
Old 04-30-2012, 10:23 AM   #943
The Stig
I used to be Stieger....
The Stig's Avatar
Drives: a PBM camaro
I really want to start this project. Though I feel that once I start I'll end up like Nathan and having to do everything. Maybe I'll just start with some SS braided hoses.
Stieger's BLACK Build Thread thanks for the sig Russ
Old 04-30-2012, 10:33 AM   #944
Nathan Moreno
Drives: G5R
Okay, updated list:
Waiting List:
Stieger:
Old 04-30-2012, 08:43 PM   #945
SS4PK
SS4PK's Avatar
Drives: 2010SS
Beginning soon, gathering pieces now. Other things going on for the next few weeks. Nothing as extreme as you crazy people but cool nonetheless.
Her Hot Rod.
SS4PK is offline   Reply With Quote
Old 05-01-2012, 05:45 AM   #946
572HP
572HP's Avatar
Drives: "Black Ice"
That's a safe start. Just get started! We need more addicts.
Old 05-01-2012, 08:35 AM   #947
PAUL SS
PAUL SS's Avatar
I started with a heater hose relo and went a bit further than that, but you can do many of these mods in less than a day and many are independent of each other so you can really do a little at a time.
Old 05-01-2012, 10:56 AM   #948
The Stig
The Stig's Avatar
Okay, updated list:
Waiting List:
Stieger:
give me a few weeks and I'll officially join the list
Old 05-01-2012, 07:59 PM   #949
Zman12
Zman12's Avatar
Drives: 2010 Camaro 2SS
I would love to start this project, maybe this winter. I may start a little at a time. I am sure that's what everyone says.
Whipple,custom cam,CAI,Kooks,Pedders and PFADT 626RWHP 549TQ ..
Zman12 is offline   Reply With Quote
Old 05-01-2012, 08:08 PM   #950
SS4PK
SS4PK's Avatar
Drives: 2010SS
Al right I need to know where to get the evap quick connects like Techafx has on their hoses. I need the 90 degrees variety. I'm going to keep the quick connects on flexible fuel line and not go with SS braided AN fittings. I guess they are the same as the fuel line quick connects. I can't seem to find them on the web, and I usually don't have luck on the GM partswharehouse website without part numbers. Who can help a brother out with a lead.
thanks
Her Hot Rod.
Roto-Fab | Engine Covers - S/C | Fuse Relay Cover | Radiator Cover | Billet Oil Cap+ AutoAgenda Exterior Parts & Accessories 14 02-06-2013 08:43 PM
New Texas Speed & Performance Engine Machining Center! Trevor @ Texas Speed Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 18 01-16-2013 03:46 PM
Hawk Performance Brake Pads part HB247Z.575 $85.00 Rogan USA - Florida 2 10-07-2011 12:10 PM
Acronyms? KEEP RT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 20 03-11-2011 08:57 PM
Great Read and Info on Oil Weight Banshee Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 11-23-2009 09:03 PM
