Old 12-24-2011, 12:52 PM   #43
Moreno Motorsports
Moreno Motorsports's Avatar
Drives: G5.R
Originally Posted by NYJETSFAN View Post
JMO, The engine looks a mess witout some kind of engine cover..
Hence the purpose for this thread!
Moreno Motorsports is offline
Old 12-25-2011, 03:03 PM   #44
zarenski
Drives: 2010 2ss
Nathon, where did you find the coil relocation brackets and the coil harness?
zarenski is offline
Old 12-25-2011, 08:22 PM   #45
Moreno Motorsports
Drives: G5.R
Originally Posted by zarenski View Post
Nathan, where did you find the coil relocation brackets and the coil harness?
From these guys http://www.ebay.com/itm/LS2-LS3-coil...258728&vxp=mtr
Speak with Brent, he was very helpful. kilo-9 is a member here that's already tackled the coil relocation. He didn't use an extension. So I'm going to go with his advice. Without his help, I would be chasing my tail! Once I complete the project, I'm going to do a DYI to take some of the guess work out along with a list of all the parts needed and part numbers.
Old 12-25-2011, 10:53 PM   #46
zarenski
Drives: 2010 2ss
Thanks Nathan. I found some other brackets. check them out. www.automotivedesigneng.com I kind of like these brackets. and theyre $25 cheaper. Im looking forward to the diy
zarenski is offline
Old 12-25-2011, 11:05 PM   #47
AngelSpeedFreak
Most hated in NM....
AngelSpeedFreak's Avatar
Drives: Sold the 6POINT2, went to a 50THZ06
A DIY write-up would be great. I would like to do this soon myself.
AngelSpeedFreak is offline
Old 12-25-2011, 11:13 PM   #48
GTAHVIT
Blessed
GTAHVIT's Avatar
Drives: 2013 Sonic RS MT
Subscribed
GTAHVIT is offline
Old 12-26-2011, 12:13 AM   #49
Moreno Motorsports
Drives: G5.R
Thanks Nathan. I found some other brackets. check them out. www.automotivedesigneng.com I kind of like these brackets. and they're $25 cheaper. I'm looking forward to the diy
Those are very nice. The only thing I see is they require 3 bolts and it's a PITA to drill into the frame rails.
Old 12-26-2011, 12:22 AM   #50
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: To many to list
I was looking on e-bay at your mounts did you see it said not for camaro coils, Have you tried to mount the coils on this new mount?
2SSRS@Gen5diy is offline
Old 12-26-2011, 09:35 AM   #51
brantley847
v It bites.
brantley847's Avatar
Drives: 2011 IBM 2SS/RS
...anyone aware if the rotofab radiator cover will fit the CAI intake?
2011 2SS/RS
Performance: 439 RWHP: 226/236 Comp Cam, Kooks 1-7/8, CAInc, Borla S type, Vmax TB, Rx Catch Can, Trans cooler, SLP 160 termo, Melling high volume, Eibach Springs/Sways 1" drop, Whiteline complete bushing kit.
brantley847 is offline
Old 12-26-2011, 10:31 AM   #52
Disco69
The Backbone!
Disco69's Avatar
Drives: '11 VR 2SS/RS M6, 01 Jeep TJ modded
x2
2011 Victory Red 2SS/RS
2001 Jeep TJ Wrangler Sahara
Disco69 is offline
Old 12-26-2011, 11:17 AM   #53
Moreno Motorsports
Drives: G5.R
They are local to me, so I just drove over. The only thing that's different for our cars is the spacer that separates the coils. Base on my coil pack parts # 12611424, he gave me the spacer that would fit. GM has at least three different coil parts # for our Camaro's. Parts # 12570616, 1257061 and 12611424. You need to make sure you confirm which one you have when ordering a set.
Old 12-26-2011, 08:56 PM   #54
Bevo
Drives: 2010 2SS
Yes it will
Texas Speed long tube headers, Texas Speed KAI, Street Scenes lower billet grill, Heritage grill, BMR 1" drop springs, Nitto tires, Texas Speed head/cam kit, Whipple supercharger, Roto-Fab washer bottle relocate, Katech coil relocate kit, GMPerformance valve covers, Weathertech floor liners, Metra dash kit, Pioneer touch screen
Bevo is offline
Old 12-26-2011, 09:20 PM   #55
ThePowderPro
Drives: 98 Procharged Z28
Powder coating the GM and FAST manifolds is no problem, we have been doing it for a few years now
Here's the manifold and engine cover album on our site if anyone wants to see some examples
http://www.thepowderpro.com/gallery/?level=album&id=5
PS we charge alot less than Peak does, I've actually had that conversation with them via PM on LS1tech about their pricing being a bit silly lol
ThePowderPro is offline
Old 12-27-2011, 10:04 PM   #56
Moreno Motorsports
Drives: G5.R
Well, here's a little update. Got a few more parts in and I had some time, so I figure I'd do a couple of seemingly easy tasks.
This is the relocation ground cable I ordered from http://Genuinedealz.com
The bolts are from http://store.yoastfabrication.com/se...e-Bolts/Detail
When I relocated the EVAC solenoid from off the cylinder head over by the fuse box, I was left with an empty hole. That's were the bolts come into play.
Looks a little more finished now.
I figured while I was at it, I might as well remove the other bolt that holds the ground cable and brackets. Keep in mind that once I relocate the ground cable to the drivers side, the only thing left will be the two bolt. I'm still waiting for the ARP bolts for the cable. In the meantime, if somebody just want to clean that section up, without relocating the cable, this might be an idea. Plus there's the added benefit that the car probably lost a few ounces in weight, LOL.
Here the finish product.
Quick tip: Bolts are in tight, so don't pull on the ranch so hard that when it comes lose, you end up smashing your hand, ouch! I think it might be helpful to do a DIY on "How to remove blood from your engine bay"
Here's the bolts I removed. For those interested getting rid of some weight, there might be a few ounces of saving there.
Roto-Fab | Engine Covers - S/C | Fuse Relay Cover | Radiator Cover | Billet Oil Cap+ AutoAgenda Exterior Parts & Accessories 14 02-06-2013 09:43 PM
New Texas Speed & Performance Engine Machining Center! Trevor @ Texas Speed Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 18 01-16-2013 04:46 PM
Hawk Performance Brake Pads part HB247Z.575 $85.00 Rogan USA - Florida 2 10-07-2011 01:10 PM
Acronyms? KEEP RT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 20 03-11-2011 09:57 PM
Great Read and Info on Oil Weight Banshee Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 11-23-2009 10:03 PM
