| Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust |
Thread Tools |
#151 |
Dog Is My Copilot
Drives: 2011 2SS/RS LS3 Join Date: Jun 2009
I would take one out and figure out the thread size, pitch, and length...then order appropriately. You could also PM member MS3DALE and ask him what size they are...I believe he ordered polished titanium bolts for his.
#152 | ||
![]() ![]() ![]() ![]() ![]() Drives: G5R Join Date: Sep 2010
What Kilo-9 said. Just in case this is all new to you, it was to me when I first started this project. I didn't know much about "thread, pitch and how to measure.... so just in case..... Bolts have three measurements. "Diameter", either standard or metric. All the bolts I've replace are metric. "Pitch", thats the number of threads per millimeter and "Length". You can go to Home D, Ace, etc. By the way, I love Ace! They'll have a board with sockets (see pic below), all you do is screw your bolt to the appropriate socket, this will tell you the diameter and pitch. Example: 6MM X 1.5. ( 6MM is the diameter and the 1.5 is the pitch. On the board, it also has were you can measure for length. To determine the length, you want to measure from the bottom of the head to the tip. So you might have a bolt thats 6MM X 1.5 by 30 MM. Next you can call ARP and have them give you a parts number for that size bolt. With the parts number, I call Summit and get a price. They sell individual and packs of five. If you need three of the same, it might be cheaper to buy the five pack. One thing I like about Summit is that if you have to return something, they include a postage paid return label with each of their orders. Also, you have the two types of heads, Hex and 12 points, every bolt I've gotten have been 12 points. I think they look nicer. Hope that helps Oh, thanks for the compliment. It makes taking the time to post on here gratifying. I appreciate that. ![]()
#153 | |
"I know some folks will put a breather on the valve cover and just do away with the line. But I spoke with Patrick at Vararam, he gave me a thirty minute explanation on how the car loses power when you do that. Also the Katech valve covers don't come with a oil deflectors/baffels, so you'd have oil spilling all over the place. The name of this thread "Project Cleaning the Clutter in Our Engine Bay" would take a whole new meaning, LOL. Even if I could use a breather, once see what I'm doing with the covers, you'll see why I wouldn't want to. Stay tune for that." Here's what I meant by the last statement on my previous post. Because both valve cover are interchangeable, I'm running what would be the passenger side cover on the driver side. This moves the oil fill cap to the drivers rear side. Giving a cleaner look to the front of the engine. So even if I could run a breather, I wouldn't want to stick it back there. Since part of what influencing my decisions is keeping the compartment as clean and simple as possible. Unfortunately, sometimes what seems simple is LOL. Also, By inverting the cover, I can now run the hose from the valve to the intake out the rear. instead up front.
#154 |
The factory finish on the cylinder head has a bunch of swirls and scratches. Unfortunately,
![]() So, I took 2000 grit paper and ...... ![]() I taped up the area ![]() And after some effort.... the heads is still moist from the wet sending inn this picture but it looks really nice now. ![]() Here's a quick preview of what I'll be posting more details on tomorrow. Just to tired to spend an hour uploaded and elaborate now.
#155 |
HT5 COTW 1/21/13
Drives: 2010 Camaro Inferno 2SS RS 6M Join Date: Apr 2011
#156 | |
ACE5 (Atlanta Group)
Drives: "Black Ice" Join Date: Sep 2010
You have inspired me to get started on mine. KILO-9 ... would love to see detailed pics of your work. Do you have these anywhere? I searched. I spent all day yesterday on the passenger side engine wire harness. I'm close to finishing it and then I'll start on the driver's side. I'll post pics when I am done with the first side. Just sayin...lots of cutting, soldering, and heat-shrinking. I bought the new holley LS valve covers over a month ago that angle the coils. I'll paint up the coil packs later (don't want to scratch them while I'm still doing everything else.) I wish I would have seen the relocation first. Oh well, maybe later. Also KILO-9...about your LSR strut tower caps...Is there something special required to get them to work with the pedders? I thought that I read somewhere that they had to fabricate a tool or something, but I can't find it again.
Honored to be Camaro of the Week:
[COTW 5/2/11] 2011 Two-Tone White/Black SS/RS Convertible See our Atlanta Social Group or home page: ACE5.org |
#157 |
So I'm looking at relocating the evac solenoid. I'll need a new line from the evac line coming from the tank, and I'll need a new line going to the throttle body, or in my case the supercharger. What did you guys use as far as tubing and fittings? I'm going with the braided covering and want to use black anodized clamps/fittings where possible. Any help would be appreciated.
#158 |
![]() Drives: 2010 Camaro 1SS/RS 6 Speed Join Date: Jan 2012
Thanks for all the detailed pics and explanations. It is taking you more time to do this project because of you stopping to ttake pics and writing down your steps here.
Just so you know, we really appreciate the time you have spent to try and help us out. Thank you for everything. |
#159 | |
I used to be Stieger....
#160 |
Definitely a big thanks for doing this thread!
Here is what I did yesterday and finished this morning. The driver's side is still left to do. I have cut and spliced/soldered every wire, used shrink tubing and braided sheathing. Still need to relocate evac solenoid, paint coil packs, and get new coil pack bolts.
#161 |
#162 |
![]() ![]() Drives: camaro ss-05chopper-13-street glide Join Date: Apr 2010
looks great....
any chance you have a list of what it would take to reproduce the water line set-up you have in this pics Last edited by bmbbl be; 01-22-2012 at 06:16 PM. |
#163 |
Account Suspend...Right
Drives: Synergy LS & Vulcan 1600cc Join Date: Apr 2011
wow
#164 |
Looks great
#165 |
Looking awesome Nathan, question. Whose valve covers are those? I feel like you've already posted this but not sure.
#166 |
![]() Drives: Summit White 2011 2SS/RS Join Date: Feb 2011
#167 |
![]() Drives: 2013 IOM ZL1, 2010 ABM SS Join Date: Feb 2011
I also perfected powder coating plastic intakes I was in the coating business for 13 years I only charged $175 they are extremely easy to coat but my company grew too big so I really don't do too many car parts anymore
Sold! 2010 ABM 2SS RS. Corsa CB and more mods to come!
#168 |
Dog Is My Copilot
572HP, nothing special is required to install the LSR strut tower caps with the Pedders. Just swap the rubber ring over from the stock plates and install them as normal. You just can't use the little center caps because of the adjustment knobs.
#169 | |||
Thanks again guys
Mike only charges $200, not $300.
#170 | |||
For the black braided line and fittings, I used XRP http://www.xrp.com/ You can call them and get a local distributor in your area to supply with with what you need. Quote:
due to some other stuff that interferes. I'm might have to rethink the whole deal.Quote:
#171 | |
That looks killer....... we need more pictures!
#172 |
Nathan (and 572HP), I want to "clean up" some of my wiring harnesses like you guys did. However, I am not relocating anything, or repositioning anything, I just want to take off the crappy factory electrical tape and wrap it up in the braided sheathing (I'm assuming it is the "painless wiring" braided wire wrap on Summit). I like how you guys used the shrink wrap to secure the ends of the sheathing. My question is, is there any way to do that (use the heat shrink) without cutting the wires. I'm pretty sure that heat shrink tubing is not going fit over some of those big connectors to slide it in position before heating it up. Or is there a way to "de-pin" the connectors? I really just don't want to cut any wires. I suppose if the heat shrink won't work, I could just use zip-ties, but it wouldn't look as nice. Can you give me any tips???
Oh, and that MTI cross-over vapor tube looks killer, I think I might go that route too!!! |
#173 | |
![]() ![]() ![]() ![]() ![]() Drives: 2012 zl1 Join Date: May 2009
![]() For those interested, our radiator cover fits with the Hennessey intake...
#174 | |
![]() Drives: 2010 Summit White Camaro SS/RS Join Date: Dec 2010
PM so we don't clutter!
#175 | |
![]() Drives: cts-v Join Date: Dec 2011
And Nathan, man you got guts cutting that hose in the kitchen, razor blading that granite countertop and putting a vise in there!!!! Things are lookin good though!
| Thread Tools | |
| Roto-Fab | Engine Covers - S/C | Fuse Relay Cover | Radiator Cover | Billet Oil Cap+ | AutoAgenda | Exterior Parts & Accessories | 14 | 02-06-2013 08:43 PM |
| New Texas Speed & Performance Engine Machining Center! | Trevor @ Texas Speed | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 18 | 01-16-2013 03:46 PM |
| Hawk Performance Brake Pads part HB247Z.575 $85.00 | Rogan | USA - Florida | 2 | 10-07-2011 12:10 PM |
| Acronyms? | KEEP RT | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 20 | 03-11-2011 08:57 PM |
| Great Read and Info on Oil Weight | Banshee | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 1 | 11-23-2009 09:03 PM |
