Old 12-16-2011, 02:30 PM   #1
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
1st 500 miles with Catch can results….
The can captured just over 1oz of oil from going into my TB and this was only in 500 miles. Very happy with my decision to purchase it! Thanks Tracy/RX!
FSP tuned: 377/389
Old 12-16-2011, 02:46 PM   #2
SC2150
Old 12-16-2011, 02:48 PM   #3
oso305
Shoot First. Ask Later.
Drives: Dark Knight
Can the oil catch can help with our motor problems?
Shoot First..Ask Question Laterr!
oso305 is offline   Reply With Quote
Old 12-16-2011, 02:50 PM   #4
nyrfan
Let's go Rangers!
nyrfan's Avatar
What are our motor problems? Are you talking about the "potential" timing chain issue, if so, no. For this check your oil regularly, FORGET the oil life monitor and change at 3K for standard oil, <5K for synthetic oil and chances are you'll be just fine! I'm running full synthetic and decided I'll be changing every 3-4K.
FSP tuned: 377/389
Old 12-16-2011, 02:52 PM   #5
oso305
Drives: Dark Knight
no for the oil starvation problem.
Old 12-16-2011, 02:53 PM   #6
nyrfan
Let's go Rangers!
nyrfan's Avatar
Same as above (which I have slightly edited) as they are pretty much tied together.
FSP tuned: 377/389
Old 12-16-2011, 03:02 PM   #7
oso305
Drives: Dark Knight
Old 12-17-2011, 12:06 AM   #8
The Blue Angel
The Blue Angel's Avatar
Drives: 2014 BRM 1SS/RS
nyrfan, with the installation of your RX oil catch can, do you feel like there is more torque and power? Cause I had one installed and have noticed the increases of both!!
2014 Blue Ray Metallic 1SS/RS
A Road Warrior
The Blue Angel is offline   Reply With Quote
Old 12-17-2011, 12:22 AM   #9
daveagogo1
TRI COUNTY TAMPA
daveagogo1's Avatar
Drives: 2011 1SS/RS VR/BLK A6
When did you install the can Andrew? The cooler temps we have had the last month is probably the reason your feeling more torque and power. I can't see a catch can adding anything in either of these departments.
Originally Posted by HufferSS View Post
Fast cars have rubber on the quarter panels...you sissies need to knock it off.
daveagogo1 is offline   Reply With Quote
Old 12-17-2011, 12:47 AM   #10
The Blue Angel
Two weeks ago. But after installation I have noticed those things!!
A Road Warrior
Elite Engineering Catch Cans Now Available At APEX Motorsports! Multiple Colors! Apex Motorsports V8 Bolt-Ons & Tunes 136 06-30-2011 06:24 AM
Just changed my oil at 500 miles... Croathlete Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 29 08-26-2009 06:56 PM
500 miles and my tires are already screwed up! bluecamaroguy Wheels and Tires Talk Sponsored by The Tire Rack 13 08-10-2009 08:45 PM
First 500 miles with 20942 destroyer4 5th Gen Camaro SS LS LT General Discussions 2 07-13-2009 01:53 AM
Where should I go to get oil changed after 500 miles? GoldFire Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 28 07-01-2009 07:21 PM
