Old 12-16-2011, 08:51 PM   #1
CTUnlimited
Drives: 2010 2LT Auto
High oil pressure?
Hey guys i posted up before about an oil leak. Now I havent had the time to drive it and also im scared too. At idle my oil pressure gauge stays maxed at 70 psi. I've read this can be normal on a cold start, but it never did this until after I installed my intake and catch can. Also At first i had the catch can installed wrong and leaked a lot of oil from the cap and possibly a valve cover. It doesnt SEEM to be leaking anymore, but i havent had the chance to drive it enough to tell for sure. But after correcting the install, i started having this problem with the oil pressure. Checked to make sure the sending unit is plugged in and it is. Oil level is normal. I'm just curious if any of you guys know any reasons for this? I'm at a loss and am scared to drive it now...
CTUnlimited is offline   Reply With Quote
Old 12-16-2011, 09:15 PM   #2
mydreamcar
My Dream Car
mydreamcar's Avatar
Drives: 2011 SIM LS3 1SS
after start up yes. 70psi is the norm but after the car warms up at idle that oil pressure should be around 25-28psi. just to make sure are the rest of the gauges working fine ie battery, tranny temp. oil temp or are they also reading high
CAI intake/ADM Scoop/Stainless Power Headers/Dynatech cat back exhaust/Vitesse Throttle Control/ Ported Throttle Body/QTP Electric Cutouts/ 3.91 gears and janetty rear posi/ Tuned by Janetty racing
mydreamcar is offline   Reply With Quote
Old 12-16-2011, 09:21 PM   #3
spyderbuddy
spyderbuddy's Avatar
When cold mine reads 70 psi also, I have the Vararam and RX catch can also. When it warms up it runs 50 at 2000 rpm, at idle about 30.
Gen5 DIY Frameless Mirror, ABL Dash Lighting an My link Navigation, Blacked out Rear Bowtie, all Sylvania led Turn Signals, Ceramic Window Tint By Nicks, MBRP Exhaust tips, GEN5 DIY Virginia Legal DRL Harness, Painted Brake Calipers, Vittesse Throttle Controller, Heritage Grill, Diode Dynamics Led Lighting, Manual Shifter Boot, Paddle Shifters, CNC Throttle Body, Trifecta Tune, Vararam Cold Air Intake, RX Catch Can & Breather, Trunk Black out and Side Grills, Chevorlet door Sills.
Old 12-16-2011, 10:07 PM   #4
CTUnlimited
Ok well thats good to know. I guess ill take her for a drive and see. I dont remember it being that high at start up before, but it also wasnt really winter weather yet either. thanks guys!
Old 12-17-2011, 08:01 AM   #5
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
yes they are all correct 70 is normal until warmed up. I have some photos at different speeds and rpm's that I would love to post. However, I thin I may have lost my C drive on my laptop. Waiting to get it into the doctor later today (Neighbor is an IT manager). I do have backups just waiting to see what we find first.
UPDATE: Doctor has cured the patient.
PSI at IDLE when WARM
Name:  psi at idle and warm.jpg
PSI at 41 MPH
Name:  psi at 41.jpg
PSI at 70 MPH
Name:  psi at 70.jpg
Old 12-19-2011, 01:07 PM   #6
FDNY-L107
FDNY-L107's Avatar
Drives: 2011 Camaro LS V6
Normal......what he said ^^^^^^^^^^^^^^^^^^^^^
Black 2011 Camaro LS M6
- Nitro Dave's NOS Plate System - 100 shot
- Hochkis Front & Rear Comp Sway Bars & End Links, SS Struts & Shocks, Eibach Springs
- BMR Sub-Frame & Tunnel Brace, BMR Rear Toe Rods, Rear Control Arms, GM Strut Bar Brace
- BBK LT Headers w/Kook's 2.5" Cat-Back Exhaust
- Forgeline DE3S Wheels NT05 Tires
- RS 4-gauge pod/RS leather console lid, Leather Steering Wheel, MTI Shifter
- Cold Air Induction CAI w/VMAX Ported TB & Ported+Powdercoated Intake Manifold, SLP UD Pulley, RX Catch can & Breather, RX Black-Iceolator, Port-matched heads
- Braille 17 Battery
- Trifecta Tune
FDNY-L107 is offline   Reply With Quote
Old 12-20-2011, 10:21 PM   #7
CTUnlimited
Still haven't driven it because all the rain but i did open up the garage and start her up for awhile to see. After warming up for awhile my oil pressure went down to a normal reading at idle. So i feel fairly safe. All this stuff about low oil and engine failures has me paranoid. Especially after i leaked all that oil when i installed the catch can wrong. Still waiting for a real drive to see if there are any leak still too.
Old 12-20-2011, 10:28 PM   #8
spyderbuddy
Yep, as long as that oil temp is down oil press is up. Got to wait till oil temp is around 200 before checking the pressure.
Old 10-01-2012, 10:35 AM   #9
rocknRllr
rocknRllr's Avatar
Drives: 2013 2LT Crystal Red Metallic
Oil pressure
Had my break in oil changed two weeks ago and went with a full synthetic oil. ( I have a 2013 2LT/RS (V-6) However, don't know if my oil pressure is OK, when I left home this Am to work the needle was all the way over on 70 psi for about 7-10 miles and then bounced back up to about 38 at 65 mph. I also notice that if I'm going at around 45-50 and give it a little gas it goes all the way over to 70 and then bounces back. Does this seem normal? My engine temp warm as around 190-195.
rocknRllr is offline   Reply With Quote
Old 10-01-2012, 11:28 AM   #10
rtcat600man
yes, normal
A Look at GM's Oil Life Monitoring System franknbeans Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 166 05-23-2014 07:31 PM
My V6 oil change experience convert Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 38 04-08-2014 05:15 PM
Can we use the catchcan made for the G8? HaZe_X Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 16 05-05-2010 11:35 AM
New Camo shots of a Camaro bballr4567 Camaro ZL1 Forum - ZL1 Specific Topics 150 02-18-2010 01:13 PM
