Wretched Motorsports
Off-topic Discussions Discuss any off-topic subjects with other members.
Old 12-16-2011, 09:52 PM   #1
Jas29
Jas29's Avatar
Drives: nothing
Cold room on 2nd floor
Hey,
on the 2nd floor of my parents house there is one room thats very cold hoping u guys have some suggestions on how to warm
up the room i took a picture of the bottom of the room its fully insulated don't know about the other walls though
Uploaded with ImageShack.us
Jas29 is offline   Reply With Quote
Old 12-16-2011, 09:54 PM   #2
The Stig
Fireproof Moderator
The Stig's Avatar
Drives: a PBM camaro
does it have a heating vent in it? Is the vent covered up? You could always put a space heater in there
Stieger's BLACK Build Thread thanks for the sig Russ
Old 12-16-2011, 09:57 PM   #3
Jas29
Jas29's Avatar
Drives: nothing
there is a heat vent in the room and we are using a space heater its really cold in there compared to the rest of the house when the temps go into the negatives
I was thinking about using a vapour barrier to keep the cold air out
edit: will there be any downsides of doing this don't want moisture up there
Old 12-16-2011, 10:05 PM   #4
lakersftbl69
lakersftbl69's Avatar
Drives: 2010 camaro 1ss/rs
Got two lowes and buy one of those electric heaters for now maybe
ordered dec 15 2008 picked up on june 8 2009.
upgrades kooks 1 3/4" LTH w/ high flow cats, roto fab cai, corsa exhaust, rx catch can, hurst short throw shifter. stage 3 comp cam, 3.91 gears 445rwhp 410 rwtq all installed and dyno tuned from slowhawk performance.
lakersftbl69 is offline   Reply With Quote
Old 12-16-2011, 10:10 PM   #5
Jas29
Jas29's Avatar
Drives: nothing
i'm using a space heater now looking for a long term fix.
Old 12-16-2011, 10:20 PM   #6
Steve Dallas
Commits weekly crime
Steve Dallas's Avatar
Drives: 2012 Sonic LTZ 1.4 Turbo BTM
Best way to warm your room:
Had fun in the Blue Barchetta - Imperial Blue Metallic 2010 Camaro SS/RS with Ground Effects, Beige Interior, 6speed Manual.
I fire up the willing engine, responding with a roar. Tires spitting gravel I commit my weekly crime.
Steve Dallas is offline   Reply With Quote
Old 12-16-2011, 10:23 PM   #7
Sir Nuke
Master of All Things
Sir Nuke's Avatar
Drives: '10' Camaro 2LT/RS,'08' Caddy STS
go here and get one of these for your bed......, pick one.....any one.....and you'll be SET!!
http://www.camaro5.com/forums/showthread.php?t=171508
Old 12-16-2011, 10:30 PM   #8
Steve Dallas
That was my first thought. Shoulda stuck with it.
I was going for the humor angle though
Old 12-16-2011, 10:40 PM   #9
Bangarang
Bangarang's Avatar
Drives: 2010 Camaro 1LT SIM w/ Carbon Fiber
maybe check the attic for insulation above the room. it looks like it may have been a deck previously, in which case they may have just closed it in not worried about the change in temperature for some reason.
Bangarang is offline   Reply With Quote
Old 12-16-2011, 10:49 PM   #10
Jas29
Jas29's Avatar
Drives: nothing
lol thanks for the laughs guys to bad its my grandparents room and there is a deck beside it so i will go up there and check
Edit: the room also could have been an add on seeing as how one of the support poles is a foot away from the bottom of the stairs pretty sure that doesn't meet code
Old 12-16-2011, 11:29 PM   #11
Nessal
Drives: 2011 SS/RS
Call an exorcist.
Nessal is offline   Reply With Quote
Old 12-17-2011, 12:14 AM   #12
GnyaTek
GnyaTek's Avatar
Drives: 2011 SIM 2SS/RS Vert
Likely the room was an addition, as mentioned above. Insulation in the walls and ceiling may not be as robust as the rest of the house. Also, the vent probably was added on after the fact, so the air flow likely isn't as good as the rest of the floor (heat pump not designed to handle the extra square footage and/or ducting/air flow not designed to move the air efficiently to the addition). Since the room is extended out, it has outside exposure not only on one side, but likely three plus the floor itself, giving alot of area for heat transfer/loss to the outside. Thermostat controls are likely in another location on the second floor, one that doesn't lose heat as fast ... the heat shuts off when the temp is reached elsewhere, which isn't warm enough in that room, and then the room loses heat faster as well making it much colder.
One possible way to help mitigate ... close down the vents more through the rest of floor - rooms, hallways, and closets (1/2 way closed, or more later if the desired impact isn't met) but leave the vent in that room wide open. This should restrict the flow of heat somewhat to the rest of the floor and force more warm air flow into that room. The heat will run longer to warm the rest of the upstairs floor before the thermostat recognizes the shutoff temp also adding more heat to that room.
GnyaTek is offline   Reply With Quote
Old 12-17-2011, 12:22 AM   #13
Jas29
Jas29's Avatar
Drives: nothing
there is a a full bathroom in that room that makes me believe it is not a add on. the room that the thermostat is in is on top of the garage which is not heated. Also i opened the floor beneath the room up and it is fully insulated which makes me to believe the rest of the walls are I will go into the attic tom and check. The insulation has the number 28 on it could that be the R value?
i don't know much about theis kind of stuff trying to learn only 18 right now so sorry if these are dumb questions
Old 12-17-2011, 12:26 AM   #14
FenwickHockey65
General Motors Aficionado
FenwickHockey65's Avatar
Drives: Carbon Metallic 2003 GMC Envoy SLE
We have an addition built along the same lines as that. I just threw a space heater in there, warms it up pretty fast.
FenwickHockey65's GM Thread!
2013 GMC Terrain SLE
2003 GMC Envoy SLE
1998 GMC Sonoma SLS Extended Cab
Old 12-17-2011, 12:41 AM   #15
GnyaTek
GnyaTek's Avatar
the 28 probably indicates that it is R-28 insulation, which probably is about the right value for floor insulation for BC. Not sure what R-values would be recommended for walls and ceiling ... looks like if you were to add to an uninsulated attic you'd want R-49 to R-60 at a guess.
If adjusting the vent openings in the other rooms on the same floor doesn't help, the best thing would be to add a space heater (either a stand-alone one or a baseboard wall unit).
Old 12-17-2011, 01:14 AM   #16
Steve Dallas
On a more serious side, I have an oil-filled radiator. Works very well at pumping out the heat.
http://www.amazon.com/Delonghi-TRD07.../dp/B000A33B1C
Old 12-17-2011, 07:26 AM   #17
hotrodsally
The Legend Lives On
hotrodsally's Avatar
Drives: 2011 Camaro 2LT/RS SIM
Send a message via Yahoo to hotrodsally
When I was having my townhouse remodeled a few years ago, I became quite the HGTV addict.
On one show with Mike (the burly guy you don't wanna mess with), they featured a house with the same problem. It turned out that the duct work to the room (which was built over a garage) was uninsulated and running though an uninsulated crawl space over an unheated garage.
Their solution was to insulate the crawl space and wrap the duct work in insulation.
Hope you're warm soon. Good luck.
Viva Las Vegas!
hotrodsally is offline   Reply With Quote
Old 12-17-2011, 08:20 AM   #18
habunow1
habunow1's Avatar
Drives: Cyber Gray 1LT
You need to find where the heat lose is going and to do this you might want to get someone to come with a IR camera (shows temp difference) and go around the outside of the house and look for the temp differences. This is the best way to find if there is a gap which might not be insulated or needs vapor barrier. It cold air at the temp you are dealing with does not need much area and its not always easy to find. Proberly windows are where floor/roof and walls are meeting up. Hope this helps.
habunow1 is offline   Reply With Quote
Old 12-17-2011, 09:23 AM   #19
Iwantone2
Pinche Team Leader
Iwantone2's Avatar
Drives: CGM 1SS RS
Originally Posted by Nessal View Post
Call an exorcist.
This
Old 12-17-2011, 09:35 AM   #20
formare
Suspension by Pedders
formare's Avatar
Drives: Synergy Edition 13.71@102 1.95 60'
All goOd thoughts so far - perhaps also check the exterior windows to ensure they are not leaking lots of air. Also, take the electric outlets faceplates off and see if air is coming through - many times they are not insulated properly.
My first Love. She was called "Miss Carriage" (still cry when I think about her)
383, Muncie 4 speed, custom linkage mated to hurst short throw shifter.
formare is offline   Reply With Quote
Old 12-17-2011, 09:46 AM   #21
its a syn
B.O.D. 02/16/10
its a syn's Avatar
Drives: 2010 Synergy Green SE
does it have a return air duct? if not your heat may be collecting at the ceiling causing a very noticible heat inversion in that room. A ceiling fan set on low will help circulate the heat which may all be at the ceiling to get forced down into the cold air at the bottom of the room. I know sounds crazy to add a fan to get heat. We have a house w/o a basement and every winter we switch the rotation on our ceiling fans to mix the heat better in the house as we can get 10-15 degree diff in top to bottom in some rooms when real cold.
its a syn is offline   Reply With Quote
Old 12-19-2011, 09:20 AM   #22
Ivas
el Ruco
Drives: 2010 Camaro SS (now runnin' TENS )
Every older house has a "cold room". In ours, it's where we put unwanted guests. After a shivering night in there they wanna' go home, hurrah!
Ivas is offline   Reply With Quote
Old 12-19-2011, 09:25 AM   #23
INtha305
Drives: 2010 camaro lt
The supply vent in the room may not be getting the proper CFMs. Could be the way the duct work was done.. To fix the problem it may be as simple as relocating the flex that feeds that room To a different location on the trunk line in your attic... Call a company over and have someone take a look at it. Maybe the flex feeding that room is collapsed or damaged. Could be a few things
INtha305 is offline   Reply With Quote
Old 12-19-2011, 10:21 AM   #24
justa25thTA
justa25thTA's Avatar
Drives: 2011 Camaro SS/RS LS3
I"ve got an IR camera that I have used to locate missing insulation. Take a thermometer around to the different rooms and measure the air temperature coming out of the vents and see how consistant it is.
Yeah, I'll get around to it...
justa25thTA is offline   Reply With Quote
Old 12-19-2011, 10:25 AM   #25
garcmol
garcmol's Avatar
There's no radiant barrier. You'd see an improvement in heat retention if you pulled down the rest of the ceiling material and installed something like this between the ceiling material and the insulation:
Just like it can be used in an attic to keep those high temps out of the house, it can be used to trap that heat in the room. You've got air swirling around under the floor. Block that air from entering your insulation and you eliminate opposing forces (hot/cold air).
COLD AIR INDUCTIONS INSTALL/REVIEW 1969to2010 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 76 06-07-2010 08:52 AM
333 Ways to get kicked out of Walmart (just funny- do not try this at home) Abygale Off-topic Discussions 47 04-28-2010 01:20 AM
Fastlane Pipeline Cold Air Intake at Phastek Performance Jason@Phastek Performance V8 Bolt-Ons & Tunes 0 01-29-2010 02:47 PM
K&N's Short Ram vs. Cold Air System SamSS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 14 01-18-2010 07:35 AM
LMR CAI vs Cold Air Induction Inc TEST with RESULTS!! Late Model Racecraft Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 64 01-13-2010 02:33 AM
