Old 12-19-2011, 04:24 PM   #1
kmcd
1,425 hp / supercharged
kmcd's Avatar
Drives: (2010 2SS/L99) (1999 Corvette)
Wink SHURE-FIRE METHOD TO CURE BRAKE SQUEAL
First, let me apologize for sitting on this thread so long. I actually did this fix about a year ago, but I've been too lazy to post up the photos and descriptions.
For all of you out there who have been frustrated by GM's failed attempts (caliper weights, roller-skate pads, etc.) to cure the annoying brake squeal that afflicts so many of our Camaros, I promise this will do the trick. It's inexpensive (about $30) and quick (two to three beers max). It's also easy, even for novice wrench turners. Do it once, do it right, and say good-bye to that embarrassing cacophony that emanates from your wheels every time you stop.
These are the only items you need to purchase:
1. Caliper Bolts (FRONT) - GM P/N 11570788 M14 x 2.0 x 56.5
2. Caliper Bolts (REAR) - GM P/N 11515781 M12 x 1.75 x 60
3. Permatex ULTRA DISC BRAKE CALIPER LUBE - Item #24110
Go ahead and pop the top on that first frosty beverage, and give me about thirty minutes to upload the rest of this stuff.
"If it's too loud...well, you know the rest."
kmcd is offline   Reply With Quote
Old 12-19-2011, 04:26 PM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
how long exactly have you been sitting on this information?
but anyways...
Click to view my build thread
Old 12-19-2011, 04:28 PM   #3
Nvincent4708
1st State Camaro
Nvincent4708's Avatar
Drives: 2014 1SS M6
I used disc brake quiet on the back of the pads and solved it on my ss not too long ago
Nvincent4708 is offline   Reply With Quote
Old 12-19-2011, 04:33 PM   #4
full of days
full of days's Avatar
Drives: Camaro GT
plus 1 - CRC makes some good stuff
Post Tenebras Lux
full of days is offline   Reply With Quote
Old 12-19-2011, 04:35 PM   #5
kmcd
kmcd's Avatar
Exclamation STEP ONE
Before we lift the wheels (I started at the rear), you might want to fabricate a couple of pads for your jack stands. I use regulation hockey pucks that I've impaled with 1-inch eye screws because they fit nicely in the box-beam slots. Just insert the eye, twist 90 degrees, and you have a nifty little pad that keeps the jack stand from scratching your frame.
Old 12-19-2011, 04:43 PM   #6
kmcd
kmcd's Avatar
Exclamation STEP TWO
Next take a stock regulation puck and place it in the cup of your floor jack. Slide the floor jack under the differential drag link and lift the rear wheels as shown. Don't forget to chock the front wheels before lifting the rears.
Insert the jack stands under the previously-installed pads and lower the the jack until the weight of the vehicle is evenly distributed across all three jack-points.
You may want to loosen the lug nuts with a braker bar (7/8 socket) before you lift the wheels off the deck, although this is not absolutely necessary with the rear wheels.
Old 12-19-2011, 04:49 PM   #7
The Stig
The Stig's Avatar
That's actually a pretty nifty trick to pad the jack stands
Old 12-19-2011, 05:00 PM   #8
kmcd
kmcd's Avatar
Exclamation STEP THREE
Remove the wheels and use a 1/8-inch punch to remove the pad retention pins. It may be necessary to relieve the tension by depressing the spring with your thumb as shown.
Old 12-19-2011, 05:05 PM   #9
kmcd
kmcd's Avatar
Exclamation STEP FOUR
With the pins and spring removed, place the punch in the brake-pad pin hole and work the pad aft until you can grasp it and pull it all the way out. Do this for both the inboard and outboard pads.
Old 12-19-2011, 05:14 PM   #10
kmcd
kmcd's Avatar
Exclamation STEP FIVE
Next use a braker-bar and ratchet (18mm socket) to loosen and remove the caliper-to-hub bolts and discard them. These are torque-to-yield bolts and should not be reused. If you're not willing to buy new bolts, you need to at least make sure you put fresh loctite on them when you re-install the calipers.
Pull the caliper from the rotor and rest it on top of the control arm as shown.
You may be wondering why we're bothering to pull the caliper? There are two reasons. First, we're going to lube the caliper in the area shown (this is where it makes contact with the hub assembly, and second, you can't slide the pads back into the caliper without removing a lot of the lube in the process. Therefore, we're going to preload the pads into the caliper before placing the caliper back on the rotor.
Old 12-19-2011, 05:33 PM   #11
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
I don't like to be the guy bringing a black cloud to a thread, but the Ultra Disc Brake Caliper Lube will not last anywhere near that long if the car is driven hard. I am actually surprised this isn't being used when customers drive into a GM Dealership. It is a standard practice at places like Rodgers Chevrolet.
Old 12-19-2011, 05:35 PM   #12
kmcd
kmcd's Avatar
Exclamation STEP SIX
Because we have two small pistons instead of one big one, They're easy to push back in, and don't require a "C" clamp or other special tool. You'll need to do this if you're replacing your pads with new ones (I went with Hawk ceramics).
You can use a block of wood and your thumb to walk the pistons back into the caliper. Don't forget to loosen the brake reservoir cap and place a towel around it to catch any overflow while you're pushing the pistons.
Old 12-19-2011, 05:38 PM   #13
kmcd
kmcd's Avatar
Patience, my good man. At least let me finish before you trash the thread.
Old 12-19-2011, 05:49 PM   #14
kmcd
kmcd's Avatar
Exclamation STEP SEVEN
Now comes the fun part. We're going to lube the hell out of everything - the backs of the pads, the pinholes, the pins and spring, and don't forget the caliper. Any place where metal meets metal and has the potential to vibrate, we're gonna' lube it. And lube it like we mean it. When you're finished lubing, it should look like a second grader did it.
I know JusticePete doesn't think this is going to work, but I've put 18,000 miles on this job in the last year, and my brakes are still quiet. And I drive it hard (at the track and on the street).
Hawk Performance Brake Pad "Updated" KILLER74Z28 Suspension / Brakes / Chassis 34 05-04-2016 12:11 PM
Hawk Performance Brake Pads part HB247Z.575 $85.00 Rogan USA - Florida 2 10-07-2011 01:10 PM
DBA Brake Rotors, Hawk Brake Pads, and Motul Fluids! AJ@ECSMotorsports Suspension / Chassis / Brakes 49 11-13-2010 04:57 PM
Horrible Brake Squeal Paperer Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 6 07-27-2009 01:35 PM
Brake upgrade 96CAMaro Wheels and Tires Talk Sponsored by The Tire Rack 28 06-03-2009 02:44 PM
