JDP Motorsports
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Members Classifieds - Parts for sale or wanted > Audio / Visual / Electronics/ Gauges / Nav
Old 12-21-2011, 07:02 PM   #1
meschwenk
meschwenk's Avatar
Drives: 2011 Camaro LS
F/S Alpine Amps
I have one Alpine Amp for sale now.
Alpine MRP-F300 SOLD
V-Power amplifiers deliver the sound quality that made Alpine famous. Highly efficient power supplies housed in sleek black casings guarantee that these amps stand out in performance and appearance. The thermal management system dissipates heat and saves power, so your V-Power amp will run reliably for years to come.
The MRP-F300 4-channel amplifier sends 50 watts RMS to each of your front and rear speakers, or switches to 2-channel mode to power a pair of subwoofers. You can also switch to 3-channel mode, then power a subwoofer with 150 watts RMS while the other two channels power a pair of full-range speakers.
High- and low-pass filters put you in command of the frequencies that reach your speakers, while the bass boost is armed with plenty of low-end punch. Preamp- and speaker-level inputs allow you to connect this amp in almost any vehicle. Let a V-Power amplifier transform the sound of your car's audio system.
Highlights:
  • 4-channel car amplifier
  • 50 watts RMS x 4 at 4 ohms (75 watts RMS x 4 at 2 ohms)
  • 150 watts RMS x 2 bridged output at 4 ohms (4-ohm stable in bridged mode)
  • 2-, 3-, or 4-channel output
  • variable high-pass/low-pass filters (50-400 Hz, 12 dB/octave)
  • selectable bass boost (12 dB at 50 Hz)
  • subsonic filter (15 Hz, 18 dB/octave for channels 3 & 4)
  • MOSFET power supply
  • CEA-2006 compliant
  • STAR Topology (minimizes internal noise and prevents ground interference)
  • speaker- and preamp-level inputs
  • gold-plated screw terminals
  • fuse rating: 25A x 2
  • 8-gauge power and ground leads recommended — wiring and hardware not included with amplifier
  • 10-11/16"W x 2-7/16"H x 9-9/16"D
Alpine MRP-M500
The Alpine MRP-M500 mono amplifier drives your subwoofer system with up to 500 watts RMS — enough to satisfy the hungriest bass setup. The low-pass filter puts you in command of the frequencies that reach your subs, while the variable bass boost is armed with plenty of low-end punch. A subsonic filter prevents wasted energy by eliminating ultra-low bass, putting all the power where you need it.
Highlights:
  • mono subwoofer car amplifier
  • 300 watts RMS x 1 at 4 ohms (500 watts RMS x 1 at 2 ohms)
  • variable low-pass filter (50-200 Hz, 24 dB/octave)
  • variable bass boost (0-12 dB at 50 Hz)
  • subsonic filter (15 Hz, 24 dB/octave)
  • Class D amp with MOSFET power supply
  • fuse rating: 30A x 2
Both are packed in their original boxes with all the hardware. New they run $200 each. Both are in like new condition so, I'm asking $100.Alpine MRP-F300 SOLD
meschwenk is offline   Reply With Quote
Old 12-26-2011, 04:16 PM   #2
meschwenk
meschwenk's Avatar
Bump One amp sold
Old 01-10-2012, 12:25 PM   #3
elwoodbdr
elwoodbdr's Avatar
Drives: 2010 camaro 2LT/Rally Yellow
still have the other?
elwoodbdr is offline   Reply With Quote
Old 01-10-2012, 12:26 PM   #4
elwoodbdr
elwoodbdr's Avatar
amp
sorry not paying attention, i needed the 4 channel
Old 01-16-2012, 05:30 PM   #5
meschwenk
meschwenk's Avatar
Still have the Alpine MRP-M500 for Sale.
Old 01-17-2012, 08:14 AM   #6
c_LoW29
Drives: 2011 2SS/RS, 2010 Mustang GT
Sent you a PM
c_LoW29 is offline   Reply With Quote
Old 01-19-2012, 04:55 PM   #7
c_LoW29
Alpine Camaro Unveiled at CES 2011 BWProductions Camaro Photos | Spyshots | Video | Media Gallery 84 01-01-2013 11:05 PM
