sjm autoprod
Old 12-23-2011, 06:59 AM   #1
Erik@lashway
Erik@lashway's Avatar
Drives: Camaros, Vettes, Trucks
Wink NEW! BMR Rear Lower Control Arms for lowered 5th gens!
Hot off the press and ready for shipment to your door!
Check them out on our site here:
http://www.lashwaymotorsports.com/bm...trol-arms.html
Correct lost camber adjustability, reduce suspension deflection, and increase rear cornering stability with a set of Lower Control Arms from BMR Suspension. Superior to the factory stamped steel arm, the BMR Control Arms are constructed from heavy duty 2” square tubing and internally-gusseted laser-cut mounting plates. The BMR Lower Control Arms (TCA028) feature low-deflection polyurethane bushings, reinforced sway bar mounts, and a shortened overall length to correct camber on lowered vehicles. Installation time is only 3-4 hours. Available in black hammertone or red powdercoat.
Notes :
Designed for lowered vehicles only. Use on OE height vehicles may not provide adequate camber adjustability.
Due to shortened length of these control arms, adjustable toe rods are necesarry when using this product.
When using on 2012 models it is necessary to use a 2010/2011 style rear sway bar and end links.
Features :
Pre-shortened to provide camber correction on lowered vehicles.
Greasable, low deflection internally fluted polyurethane bushings
Heavy duty 1/4" Sway bar end link mount
Internally gusseted outer mount and heavy duty 2" boxed steel construction
Clears 17" Weld Wheels
Fits most wheels 18" or larger
Lower "window" provides adjustable coil-over valving accessibility
Erik@lashway is offline   Reply With Quote
CAMARO WIKI Tran Wiki 55 03-28-2017 01:04 PM
BMR Launches New Product - 2010+ Camaro Rear Lower Control Arms (TCA028) BMR guy Suspension / Brakes / Chassis 33 08-31-2011 06:51 PM
BMR 1.4" drop springs, sway bars, pro bushing kit, trailing arms, toe rods install. SUX2BU Suspension / Brakes / Chassis 22 05-08-2011 07:27 PM
20"x11" Rear Wheels -clearance to lower control arm ADIO SS Wheels and Tires Talk Sponsored by The Tire Rack 4 11-21-2010 08:43 PM
Rear Lower Control Arms and Rear Toe Links for your 2010-2011 Camaro PFYC Suspension / Chassis / Brakes 0 11-15-2010 04:31 PM
