Hines Performance (HPE)
5th Gen Camaro SS LS LT General Discussions General 5th generation Camaro topics not covered by other subforums.
Old 04-18-2009, 06:08 PM   #1
firehawk1
Drives: 1999 Firehawk,2007 ZO6,2010SS
Dealer Installed Options
I stopped at another Chevy dealer today in my quest to get as much information as possible before I place my order for my 2SS. They had a dealer brochure that listed some information about the Camaro that I wasn't aware of. They listed the following dealer installed options: Hurst shifter, competion exhaust system, and what looked like a cold air induction system. Does anyone know anything about these including the costs? Thanks.
firehawk1 is offline   Reply With Quote
Old 04-18-2009, 06:55 PM   #2
ShnOmac
ShnOmac's Avatar
Credit to Milk.....He does a Camaro good
Originally Posted by Milk 1027 View Post
I want to get all the known performance products for V8 in one thread to keep organized and make them easier to find.
V8 (LS3, L99)
Headers:
GMPP shorty headers:
http://www.gmperformanceparts.com/se...o_sitelet.html
$1000
part number: 92213295 http://www.gmperformanceparts.com/_r...09_Catalog.pdf page 164
Borla T-304 steel headers:
http://www.jegs.com/i/Borla/157/17249/10002/-1, http://store.summitracing.com/partde...5&autoview=sku
$915.99
Catback exhaust:
GMPP catback exhaust system:
with tips $950 part number: 92206992
without tips $750 part number: 92225672 http://www.gmperformanceparts.com/_r...09_Catalog.pdf page 164
GMPP Track Pack (off-road only):
part number: 92231570
Borla GM catback exhaust system + X pipe:
http://www.borla.com/applications/lo...X_pipe/140280/
part #140280
$1,449.99
http://www.borla.com/applications/lo...X_pipe/140281/
part #140281
$1486.99
Magnaflow Street Series:
http://www.magnaflow.com/02product/s...one=all&id=121 2.5 in. system, Dual Split Rear Exit.
part number: 16579
http://www.magnaflow.com/02product/s...one=all&id=123 2.5 in system, Axle-back, Dual split rear exit.
part number: 16581
Magnaflow Competition Series:
http://www.magnaflow.com/02product/s...one=all&id=122 2.5 in. system, Dual split rear exit.
part number: 16580
http://www.magnaflow.com/02product/s...one=all&id=124 2.5 in. system, Axle-back, Dual split reaer exit. part number: 16582
Air Intakes:
GMPP Air Intake:
$450 part number: 92212302 http://www.gmperformanceparts.com/_r...09_Catalog.pdf page 164
Suspension:
Pedders Suspension:
http://www.peddersusa.com/products/21
Camaro Street I
Camaro Front Radius Rod Bush, Item code: EP6577
Zeta Differential Mounts, Item code: EP1167
Zeta Rear eXtreme Sub-Frame Co, Item code: EP1169
price: $349.99 with package, $545.95 indidvidually
https://secure.merlinsoftware.com.au...&Level2=CAMARO
Sport Package
Zeta eXtreme Adjustable Sway Bar Kit, Item code: 429006ADJKIT
price: $699.99 with package, $891.15 individually
Camaro Street II
Zeta Front Left GSR Strut, Item code: 9464L
Zeta Front Right GSR Strut, Item code: 9464R
Zeta Front Sport Coil 634mm, X2, Item code: 2954
Zeta Rear GSR Shock, X2, Item code: 9295
Zeta Rear OE HD Rear, X2, Item code: 2957
price: $1,299.99 with package, $1582.42 individually
Camaro Track II
Zeta Front Control Arm Inner, Item code: EP6561
Zeta Rear Control Arm Lwr Out, Item code: EP7266
Zeta Rear eXtreme Sub-Frame Co, X2, Item code: EP1169
Zeta Rear Sport Coil 643mm, X2, Item code: 2955
Zeta Rear Toe Link Inner/outer, Item code: EP7267
Zeta Rear Trailing arm Inner, Item code: EP7265
Zeta Steering Rack/Pinion Mnt, Item code: EP2112
Zeta Upper Control Arm Rearwar, Item code: EP7263
price: $2,999.99 with package, $3,372.56 indidvidually
Eibach Springs:
http://eibach.com/cgi-bin/start.exe/eibach/index.html
Pro-Kit (performance lowering springs):
part number: 38144.140 http://eibach.com/cgi-bin/htmlos.exe...72939200009395
Sportline Kit (extreme lowering springs):
part number: 4.14438 http://eibach.com/cgi-bin/htmlos.exe...72939200009395
Anti-Roll-Kit (Both Front & Rear Bars):
part number: 38144.320 http://eibach.com/cgi-bin/htmlos.exe...72939200009395
Shifter
Hurst Short Throw Shifter: http://www.gmperformanceparts.com/se...o_sitelet.html
$300 part number: 92214388 http://www.gmperformanceparts.com/_r...09_Catalog.pdf page 164
Brake Systems
*1Baer Complete System (Pro-Plus):
http://www.baer.com/products/complete/pro-plus.php
6 piston calipers and 13” or 14” slotted, drilled and zinc washed, 2 piece rotors.
*Will fit under 18 inch wheels.
Price: $1820.95 for complete front system, same for rear system.
Tune
*5Tune Time Performance:
http://www.tunetimeperformance.com/z...ain_page=index
Costum dyno tunes
Packages
*5MAST Motor Sports 2010 Camaro Track Packages:
http://www.mastmotorsports.com/page....ackages&id=117
Fast - Stage I Stage Strip Package
"525 Flywheel HP"
• Mast L99 VVT Phaser series cam for auto trans. Camaro SS
• Mast LS3 Single Bolt series cam for manual trans. Camaro SS
• Mast premium nitrided valve springs
• Brings your Camaro alive with a nice noticeable lopey idle
Options and Upgrades
• EFI Live AutoCal Module with Mast Motorsports Calibration
• Muscle Rods long tube headers
• Muscle Rods exhaust systems
• Mast Black Label high flow fuel rails
• Mast Black Label roller rocker arms
Mast Motorsports recommends that every cam install using stock controller is accompanied by a calibration tune using HP Tuners, EFI Live, or equivalent software. Calibration is available from Mast Motorsports.
http://www.mastmotorsports.com/page....ackages&id=114
FASTER - Stage II Track Package
"545 Flywheel HP"
• Provides a more aggressive idle and the power to get you down the track quicker
Options & Upgrades
http://www.mastmotorsports.com/page....ackages&id=115
FASTEST - Stage III 12 Deg Competition
• Mast Black Label LS3/L99/L92 cylinder heads (rocker arms not included)
• The same gains as Stage II with the addition of Mast Motorsports Black Label LS3/L99/L92 cylinder heads for the ultimate in 2010 Camaro performance (cylinder head flow data and horsepower ratings coming soon)
Options & Upgrades
http://www.mastmotorsports.com/page....ackages&id=116
Forced Induction
Turbo
*7Aerocharger:
http://hiperturbo.readyhosting.com/store/product24.html
coming soon.....
more to come..............
Coming soon!!:
*3Kenne Bell Superchargers
SLP Performance parts
LPE Performance parts
Harrop Superchargers........ performance parts?
Pfadt suspension parts
*3Magnuson/magnacharger
Kooks headers
American Racing headers
STS Turbo??
Procharger
Corsa Exhaust
*4Varam
*4MGW
*4Spin Tech
*2SSBC
Vortech
K&N
ADM Performance
*6AEM intakes
WARNING: Prices are subject to change. Check here for dealer prices on GMP parts. http://www.gm.oeaccessories.com/Home/
P.S. If anyone finds other upgrades for the Camaro please post the link and I'll edit this post.
P.P.S.: Now adding info for superchargers and turbochargers.
I NEED HELP FROM MORE KNOWLEDGABLE PEOPLE ON THIS SUBJECT!!!
Credit:
*1: XanthosV6
*2: FoxMarketingCars
*3: blackedout010
*4: POWERFREAK
*5: Matt TuneTime
*6: Ken AEM
*7: VictoryRed08
ShnOmac is offline   Reply With Quote
Old 04-18-2009, 07:01 PM   #3
ShnOmac
ShnOmac's Avatar
and more info.....
Old 04-18-2009, 07:08 PM   #4
ShnOmac
ShnOmac's Avatar
and even more.....
More info.....
Old 04-18-2009, 07:14 PM   #5
Milk 1027
Camaro➎ moderator
Milk 1027's Avatar
Drives: 2010 1SS/RS IBM
thanks shnomac.
the link to the threads with all the performance info is in my sig.
for other accesories, search for camaroscotty threads.
Old 04-18-2009, 07:17 PM   #6
CamaroScotty
Drives: Your new SLP Camaro!
Send a message via Yahoo to CamaroScotty
Of course, keep in mind my parts guy Dave Hiller offers a discount on all the GM parts, and you don't have to bend over and take it on excessive shipping charges!
Contact him for YOUR FORUM price. Details in Sig
CamaroScotty is offline   Reply With Quote
2010 CAMARO PRICE COMPLETE LIST -- OPTIONS + ACCESSORIES (MSRP, Invoice, Employee) Embalmer Camaro Price | Ordering | Tracking | Dealers Discussions 366 03-25-2013 12:46 AM
Dealer installed TVS2300 supercharger should be OEM OPTION. Especially if Z28 dead. TT C6 Forced Induction - V8 14 03-31-2009 10:05 AM
Dealer Installed Stripes HUGE MISTAKE!! RPO_Z28 5th Gen Camaro SS LS LT General Discussions 81 01-21-2009 12:22 PM
HELP plz ! is this dealer telling me stories ? HeavyRightFooT Camaro Price | Ordering | Tracking | Dealers Discussions 12 01-13-2009 06:11 AM
Which stripes are dealer or factory installed? 350 HRSS Camaro Price | Ordering | Tracking | Dealers Discussions 11 10-17-2008 11:23 AM
