HeadlightArmor
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 1st & 2nd Generation Camaros
Old 04-19-2009, 03:11 AM   #1
jtwoods4
Drives: 1967 RS
About to Purchase this 1967 RS. Comments?
I am considering purchasing this 1967 Rally Sport with supposedly the original Powerglide trans and 327 engine. The owners description is as follow's:
"This is a 1967 Camaro RS Coupe with ALL MATCHING #S motor, and trans. This is a real RS and not a clone or a tribute. The body is straight and solid and orignal no rust floors. The car has power steering-powerglide trans, and vintage air that comes through the orignal vents. The interior is excellant and it runs, drives and shifts like it should. The paint is shiney and slick, has a couple of small chips from driving but nothing that takes away from the car."
When I asked the owner about the transmission and engine he did not know how many miles they had on them. Or any rebiuld details. We called the previous owner who was a friend of his and he said he had the car restored by his mechanic a "few years" ago. However, he did not know much about the details of the restoration, he was not sure what was done to the engine and tranny. I was told that new brake lines, fron disc brakes had been installed. Other than that all I have to go on is what I saw. Looks like the front end was also rebiult and front and back shocks look new.
The car drives great, looks great, sounds great. The owner is asking 24,000 and will not go any lower.
I am concerned that the owner does not know any details about the car. I am concerned that what I see is a nice paint job with the undercarriage painted to cover up any rust that may be there. The engine and underside look old and oily.
Please take a look at these pics and let me know if anyone has feedback.
jtwoods4 is offline   Reply With Quote
Old 04-19-2009, 03:56 AM   #2
cyberbro
cyberbro's Avatar
Drives: Not a Camaro at this time
No full ambient lighting, forget it!
Looks good!
Order Status:
2000 8/27/15
3000 9/3/15
2000 9/22/15 (Order changed)
2016 2SS With Auto, NPP, MRC, Nav, Split 5 Spoke Bright Aluminum.
cyberbro is offline   Reply With Quote
Old 04-19-2009, 04:06 AM   #3
2SSJIM
2SSJIM's Avatar
Drives: 2012 CRT ZL1 #1400
Looks to me like it has a rear main or transmission main seal leak! For $24k, I would expect a lot more........ forget it and use the $24K and buy a 2010!
2SSJIM is offline   Reply With Quote
Old 04-19-2009, 04:21 AM   #4
Camaro68
Camaro68's Avatar
67 Camaro
If you can take that car to a body man, shop have them look at the Camaro for you a lot of people try and cover up a lot of rust, just like you said by painting.
It's good you noticed all of that, No doc are any clue on the original motor or trans ??? Check and see if you can find a trim tag. If you can look the numbers up on the internet you will find more info. Firewall, driverside trim tag. Looks like a great driver but there are some real great deals out there, if your going to pay the money, just do the reseach if that is what you want.
I agree with 2SSJim will end up costing a lot of $$$. it's up too you but a lot of other Camaros out there and yes you have the 2010 out there too
Hope this helps, btw welcome to the site. If there is any other questions let me know or PM me.
Old 04-19-2009, 07:45 AM   #5
Gibb
Drives: 1967 rs/ss 396 4speed
Any car that is covered in tar is for a reason
Gibb is offline   Reply With Quote
Old 04-19-2009, 07:50 AM   #6
Supermans
Camaro & Stang Enthusiast
Supermans's Avatar
Drives: 2011 Mustang 5.0 in Kona Blue
Save your money and get a 2010.. You'll get a much nicer ride that will be under warranty..
Bought my Camaro from Eric Hall(817) 421-7266
Supermans is offline   Reply With Quote
Old 04-19-2009, 08:32 AM   #7
Stingr69
'69 Owned Since '79
Stingr69's Avatar
It has some kind of leak some where. It does not cost much to fix if you do your own work. Easy fix if you have the tools.
The aluminum coil spring spacers inside the front springs would make me concerned. That is a bubba solution to sagging springs. Probably worn out.
The car looks pretty clean but it needs a thorough going over by someone who knows what you are looking at. The cost is not out of line if there are no major issues. Look HARD for any rust that has been covered over. That will be a deal breaker if you find a lot of it.
-Mark.
Old 04-19-2009, 08:46 AM   #8
djinva
Bow Tie Fan
djinva's Avatar
Drives: 16 Camaro 2SS
Most all of these cars have had the quarter panels replaced at some point, that is not a bad thing, you just need to be sure it was done correctly. That car would have orginally had a flat hood. It is a good looking car, if the paint is as slick as it appears I suspect the car will bring the money.
16 Camaro 2SS 6M
60 Impala LS power
03 Silverado Z-71
12 Harley Davidson Ultra Classic
Instagram: djinva88
djinva is offline   Reply With Quote
Old 04-19-2009, 01:22 PM   #9
jtwoods4
Drives: 1967 RS
-Mark.
Thanks for info. I am starting to get a little skeptical about this purchase because of the oil leak. Could be a "major" issue or a sign that this car is going to be a maintinence problem. I also agree with you guys in that why would the undercarriage be painted. If it was in good condition then why cover it in undercoat?
Old 04-19-2009, 01:41 PM   #10
Stingr69
'69 Owned Since '79
Stingr69's Avatar
Maintenance problem? That car is over 40 year old!
They ALL are going to require a good amount of maintenance when they get that old. As I said before, if you can do the work yourself you are fine. If not, you will have to find a good repair shop to keep up with it all. That oil leak might be nothing more than a missing bolt in the front of the block. It might be the front seal or even a valve cover gasket. Hard to say from here.
You probably should go for a newer car that won't need as much regular upkeep.
Another buyer will probably snatch it up pretty quickly if it is what it looks to be.
-Mark.
Old 04-19-2009, 02:50 PM   #11
Mac1
Drives: 2004 Malibu
As stated, that car is 43 yrs old and you will feel it when you drive it. Go with the 2010. That 24,000 would put a dent in the cost of a new one with a warranty. If you were twenty five would you marry someone sixty-five?
Mac1 is offline   Reply With Quote
Old 04-19-2009, 04:05 PM   #12
jtwoods4
Drives: 1967 RS
-Mark.
In my opinion the new camaro does not even come close to how cool the 60's models were. Just my opinion. When you say "newer" car do you mean a newer engine and trans on an original 60's Camaro?
Old 04-19-2009, 04:16 PM   #13
JerseyMonte
JerseyMonte's Avatar
Drives: 1972 Z28
Go for it!
Looks nice not a bad price for an original the one in the pic went for 25k it is a clone originaly a 6 cyl pg now a 383, m21, 373 12 bolt costs alot to clone one
JerseyMonte is offline   Reply With Quote
Old 04-19-2009, 04:33 PM   #14
Supercamaro64
Right, right.
Supercamaro64's Avatar
Drives: 79 Z28, 86 Camaro, 94 Burb 4x4
just go for it. i think it looks great, and any rust would be small, and out of sight, and an easy-ish fix. and the new camaros are AWESOME, but u cant beat a freakin' original. id take a '67 over a 2010 any day. and tht paint is amazing.
"You wanna lay the fate of the world on the kids camaro? Thats cool."
"When reporters asked what it was, one official stated, 'It's a small, vicious animal that eats Mustangs.'"
The Creampuff Fleet-
Supercamaro64 is offline   Reply With Quote
Possible to purchase Camaro LS with rear spoiler from RS? Skidmark 5th Gen Camaro SS LS LT General Discussions 14 05-13-2009 09:58 PM
rs ss??? CaptianSam Camaro Photos | Spyshots | Video | Media Gallery 17 10-15-2008 04:17 AM
Motortrend: 2010 V6 vs 1967 350 SS christianjax Camaro Photos | Spyshots | Video | Media Gallery 18 09-19-2008 06:25 PM
Camaro LS / LT / RS / SS specs and options! CamaroScotty 5th Gen Camaro SS LS LT General Discussions 119 09-02-2008 10:46 PM
Thoughts on Relative Pricing of the RS Package jmliptak Camaro Price | Ordering | Tracking | Dealers Discussions 22 07-28-2008 02:42 PM
