Old 04-19-2009, 11:52 AM   #1
08z51c6
Drives: 2016 Camaro SS - A8, MRC, NPP
2010 Camaro Wheel Info
My first post and hopefully a good one. Been lurking around the forum getting information about the new Camaro and thought I would pass on some that I found while doing my research.
The wheel spec info I found on Bigwheels.net:
Bolt Pattern: 5x120
Offset Range: 35 to 45
Wheel Size Range: 20x8.0 to 22x9.5
OEM Tire Size (Front): 245/45-20 (245x729 mm)
OEM Tire Size (Rear): 275/40-20 (275x728 mm)
Here is a link to the info and some wheels for the Camaro: http://www.bigwheels.net/?location=w...le=Camaro%20SS
Some wheels listed for the Camaro from Discount Tire: http://www.discounttiredirect.com/di...rw=&vid=016070
As more cars get made I'm sure there will be a better selection of wheels. Hopefully in 6 months I can add a new SS to my garage!!!
Jim
08z51c6 is offline   Reply With Quote
Old 04-19-2009, 12:04 PM   #2
08z51c6
http://www.tsw.com/img/montage_black...arge_white.jpg
My favorite one so far, would look killer on a Silver SS!!!
Old 04-19-2009, 12:16 PM   #3
Hesh
Hesh's Avatar
Drives: 2010 IOM Camaro Vin 34334
Cool thanks for the info on the offsets. There have been questions about that for some time now.
Hesh is offline   Reply With Quote
Old 04-19-2009, 12:52 PM   #4
Chemical
Chemical's Avatar
Drives: 2SS RS
Yeah thanks! When I purchase the car I'll probably have after market 22" ready to be installed so this information is crucial!
Thanks again
Chemical is offline   Reply With Quote
Old 04-19-2009, 01:31 PM   #5
Bentley78
Rice Cooker
Bentley78's Avatar
Drives: Avalanche Z/71, 2010 Camaro2SS
so you can't fit a 22x10 in the rear?? That would really suck if true.
Bentley78 is offline   Reply With Quote
Old 04-19-2009, 01:40 PM   #6
08z51c6
According to Bigwheels.net the widest rear wheel you can run is a 9.5 inch, however Discount Tire Direct has several 20 inch wheels that are 20X10. You might be able to fit it if you get the correct offset.
Old 04-19-2009, 02:13 PM   #7
Gentry78
HOOK'EM
Gentry78's Avatar
Drives: 97 c1500/92 olds
thanks for the info
Gentry78 is offline   Reply With Quote
Old 04-19-2009, 03:41 PM   #8
nUcLeArEnVoY
Oldbie that nobody knows
nUcLeArEnVoY's Avatar
Drives: 2011 1SS/RS M6
The only wheels available for the car so far from TireRack.com aren't half bad either. I still want my TTM's, though.
nUcLeArEnVoY is offline   Reply With Quote
Old 04-19-2009, 04:09 PM   #9
drivingincamaro
drivingincamaro's Avatar
Drives: 95 civic
will Breytons/these fit
drivingincamaro is offline   Reply With Quote
Old 04-19-2009, 06:11 PM   #10
TaylorRyanSS
COTW: 12/13/10
TaylorRyanSS's Avatar
Drives: 1969 Camaro
is it the same as the corvette?
Old 04-19-2009, 06:21 PM   #11
Hesh
Hesh's Avatar
No the wheels on the Camaro are not the same as the vette. They are 5x120.65, and the Camaro's are 5x120. Not alot of difference but there is a difference.
Old 04-19-2009, 07:22 PM   #12
TaylorRyanSS
COTW: 12/13/10
Drives: 1969 Camaro
ok so im kinda confused about the wheel terminology lol
for example I know that 305/35/22 means 305 mm width the 35 is the width from edge of the rim to edge of the tire and the 22 is the rim size
but what does this mean :
Bolt Pattern: 5x120
Old 04-19-2009, 08:19 PM   #13
08z51c6
Bolt Pattern: 5x120
Bolt Pattern : http://www.tirerack.com/wheels/tech/....jsp?techid=92
Offset : http://www.tirerack.com/wheels/tech/...jsp?techid=101
Hope this helps
Old 04-19-2009, 08:20 PM   #14
Rob@WretchedMS
Drives: His Wife Crazy
I would guess that they are 5x120 +48 since the GTO and G8 are both that spec, (i believe)
Since all 3 cars are Australian built or designed.
bottom line, someone needs to look on the inside of the wheel to see if it says P48 inside one of the spokes,
Rob@WretchedMS is offline   Reply With Quote
SEMA Camaro: Yellow Camaro Concept Tran Camaro Photos | Spyshots | Video | Media Gallery 45 09-01-2011 03:19 PM
Tom Henry Racing Announces a Special Edition 2010 Camaro! TAG UR IT 5th Gen Camaro SS LS LT General Discussions 72 04-30-2009 01:57 PM
Hennessey 2010 Chevrolet Camaro 705-HP!! (HPE700) Caliman93230 5th Gen Camaro SS LS LT General Discussions 172 04-01-2009 07:12 PM
