BeckyD@RodgersChevrolet
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 1st & 2nd Generation Camaros > 1st & 2nd Gen Marketplace
Old 12-26-2011, 02:34 PM   #1
Xplosive Performance
Drives: 240sx SR20DET,240sx w/LS6, 09-ZO6
Send a message via AIM to Xplosive Performance
1967 – 1969 Camaro/Firebird Coil-Over by QA1
1967 – 1969 Camaro/Firebird Coil-Over Conversion System 1st Generation F-Body Single Adjustable Front Pro Coil System
BrandQA1 Precision Products
Manufacturer's Part NumberGS401-10350A
Part TypeCoil-Over Kits
Product LineQA1 Pro Coil-Over Systems
XP Motorsports Part NumberGS401-10350A
UPC806990062000
Suspension Height Adjustment0.0-2.0 in. lowered front
Coil-Over Kit PositionFront
Recommended Front-End Weight1,701-1,900 lbs.
Shocks IncludedYes
Adjustable ValvingYes
Internal DesignTwin-tube
Gas ChargedNo
Number of Valving Selections18
Extended Length (in)12.8 in.
Collapsed Length (in)9.0 in.
Threaded Adjustment Range3.000 in.
Upper MountStud
Lower MountBar pin
Shock Body MaterialAluminum
Shock Body FinishClear anodized
Bushing MaterialPolyurethane
Bushing ColorBlack
Coil-Over Springs IncludedYes
Spring Rate (lbs/in)350 lbs./in.
Spring FinishSilver powdercoated
Crossmember IncludedNo
Adjustable Mounting Bracket IncludedNo
Hardware IncludedYes
Welding RequiredNo
QuantitySold as a kit.
NotesSingle adjustable coil-overs, designed to fit applications with small block engines. Shocks are remote ready, they can be used with the QA1 two or four channel remote adjustable system.
These QA1 Pro coil-over systems are engineered from the ground up to offer unmatched performance over stock suspension setups. Pro coil-over systems utilize adjustable and non-adjustable coil-over shocks and springs, designed specifically for replacing the factory shocks and springs. This combination offers ride height adjustment and variable position valving adjustment (where applicable) for performance not found in other kits. Choose these QA1 Pro coil-over systems for your next suspension upgrade.
QA1 offers its Pro Coil System with single adjustable shocks for the daily driver. Compression and rebound adjustment is made easy with one easy-to-reach knob for simultaneous adjustment. With 18 valving options, you’re able to fine tune your suspension for the ride you’re looking for.
  • Made in the U.S.A
  • Easy, Bolt-In Installation
  • Coil-Over
  • Ride Height Adjustable
  • Lightweight Aluminum
  • Remote Ready
  • 100% Dyno Tested and Serialized
  • Rebuildable and Revalveable by the QA1 Factory or QA1 Authorized Service Centers
Xplosive Performance is offline   Reply With Quote
Old 03-27-2012, 07:32 PM   #2
aquablueL99
Jackson's COTW
aquablueL99's Avatar
Drives: 1968 Camaro & 2010 Camaro 2SS
UPC806990062000
Shocks IncludedYes
Gas ChargedNo
Upper MountStud
Lower MountBar pin
Bushing ColorBlack
Welding RequiredNo
  • Made in the U.S.A
  • Coil-Over
  • Remote Ready
I will vouch for QA1 Pro suspension. I have it on my 68' Camaro. I works so well and you can simply dial-in the ride and the height you want. Nice product...
aquablueL99 is online now   Reply With Quote
Z28 Fan... kudzu74 Camaro Z/28 Forum - Z/28 Specific Topics 47 09-06-2011 12:26 AM
2011 Camaro to come in HYDRO BLUE & OLYMPIC WHITE Rickie Camaro Photos | Spyshots | Video | Media Gallery 108 05-27-2010 12:22 AM
The Comaro Betrayed Chevy djljm Off-topic Discussions 36 11-28-2009 08:38 PM
1967 - 1969 2.5" Chambered Exhaust Thunder 1st & 2nd Generation Camaros 8 04-16-2009 07:36 AM
