BORLA
Old 04-21-2009, 07:29 AM   #99
Bell040
Bell040's Avatar
Drives: 2SS/RS - Black - GFX
what VINs are getting the new Brembo's and which ones are getting the weights?
Bell040 is offline   Reply With Quote
Old 04-21-2009, 07:33 AM   #100
mlee
www.CamaroFest7.com
mlee's Avatar
Drives: 2017 A10 ZL1
Whoooaaaa... Sure glad mine isn't in production yet. Sometimes it pays to be last
Old 04-21-2009, 07:34 AM   #101
Supermans
Camaro & Stang Enthusiast
Supermans's Avatar
Drives: 2011 Mustang 5.0 in Kona Blue
So far the first Camaro five member to receive a Camaro does not have the problem while two others do.
Gm is going to address this issue and wether or not those with these quick fix weights on the brakes will be getting the newer ones from Brembo that correct the problem to be installed by the dealer ofcourse.
Bought my Camaro from Eric Hall(817) 421-7266
Supermans is offline   Reply With Quote
Old 04-21-2009, 07:39 AM   #102
Bell040
Bell040's Avatar
so... can the guys that have the weights please post the last 4 numbers of thier VIN?
I am sure that there is a VIN cutoff
EDIT: #2937 does not have the weights .... cutoff is lower than 2937 .... hopefully lower than 1691
Old 04-21-2009, 07:52 AM   #103
Supermans
Supermans's Avatar
The answer from a new member that is in Canada and most likely a worker at the plant.
Originally Posted by camkid54 View Post
Gentlemen As far as the brake weights go I heard from a fellow in the GM plant, the brakes were squeeling and by weighting the calipers the squeel went away Brembo has, since then sent a new batch of calipers to correct this problem Hope this helps
If this is the case that some of the vehicles were given this quick fix and the cars shipped while Brembo fixed an issue and is now sending corrected Brembos...Then my opinion is that all of those people who received these brakes with weights on them should have them replaced with "brand new" fixed ones... Especially if it is confirmed to be a problem that has been fixed or is being fixed by Brembo.
No need to bitch and moan in this thread. This is the first minor problem/fix with the new Camaro's being shipped and it is not the end of the world.. Should it have been shipped like that? I personally wouldn't have if Brembo was able to ship a replacement part quickly enough and it seems they already have started shipping fixed ones since some of you don't have this problem.. At the very least GM should have informed the dealers of this problem so that they can inform the customer who just paid full price for a new Camaro.. Furthermore GM should have informed the dealer to inform the customer that Brembo would be sending the fixed ones to the dealer and that they decided to send the car sooner without delay since it was a minor problem.. If GM had taken these steps, nobody would be complaining and there would be no mystery and uproar in the forums..
Old 04-21-2009, 07:52 AM   #104
ROBZ 28
ROBZ 28's Avatar
Drives: 07 AVALANCHE,2000 ZX12R,MALIBU
Send a message via Yahoo to ROBZ 28
I believe its for anti vibration. Its still a crappy way of handling it.
ROBZ 28 is offline   Reply With Quote
Old 04-21-2009, 08:05 AM   #105
SNOOK
Drives: 1967 Camaro, 2010 Camaro SS
Mine (My wife's) is #1390
SNOOK is offline   Reply With Quote
Old 04-21-2009, 08:11 AM   #106
Beechdoctor
Beechdoctor's Avatar
Drives: 2010 2SS/RS
No way is this effective vibration mitigation....this has to be an assembly snafu!!
If this addition of wheel balance weights to the outside of the calipers is in fact being allowed by GM quality and engineering staff to be delivered this way, then we should also expect to find a pair of vice grips attaching the transmission to the cross member reinforced with JB Weld!! This takes on the appearance of a Band-Aid over a bullet wound.......or perhaps these are simply spare wheel weights for future wheel balancing!!!
I would like to hear for our friends representing GM on this sight to chime in, but I assume it is being "looked into" before any public explanation is offered through official channels. If this was intended and allowed to pass through by quality control engineering, then it raises serious concerns that marketing is overriding engineering and quality control and forcing these early cars out the door.
Either way, I still want one, but WTF GM?????
Beechdoctor is offline   Reply With Quote
Old 04-21-2009, 08:17 AM   #107
Hylton
Hylton's Avatar
Drives: fanboys and ass kissers crazy.
Originally Posted by delius View Post
OMG...FINALLY...THE CHICK MAGNET HAS BEEN DISCOVERED
Props bro!
Hylton is offline   Reply With Quote
Old 04-21-2009, 08:19 AM   #108
avol2
2G1FT1EWXA9104709
avol2's Avatar
Drives: 2010 Camaro 2SS/RS SIM
Originally Posted by Hylton View Post
Props bro!
uhhhhhhh WOW.. I hope they don't add it to my car!!!!
My 2010 2SS/RS SIM, LS3 was ordered on 10/13/08 and delivered on 5/9/09!
Julie
aka aVOL2 (because I ride a VOLusia Too)
avol2 is offline   Reply With Quote
Old 04-21-2009, 08:24 AM   #109
ROBZ 28
ROBZ 28's Avatar
I WORK FOR A GM DEALER AND NOT THAT I LOOK AT EVERY CALIPER BUT I'VE NEVER SEEN THAT BEFORE. I HAVE SEEN SOME CRAZY THINGS IN THE AFTERMARKET THOUGH.
Old 04-21-2009, 08:29 AM   #110
Ltdodge
Ltdodge's Avatar
Drives: 2008 Z06
on my srt charger, we had the same problem of brakes squeeling and rotors warping...the outcome was that the brakes did not get up to temperature (since these brakes are high performance) causing the squeeling and warping of the rotors. there was a TSP to fix that and all rotors were replaced with slotted ones.
one thing though these brembo pads will be dust monsters!!!! you will be cleaning your wheels every two days.
i went with ceramic pads that elimated most of the squeeling and dust, but sacrificed stopping distance.... if you track your car, you would want to put the original pads back on since they are much better.
changing out the pads are a piece of cake.....remove the two studs and pads fall out.....(if they are the same brembo brakes as the srt, which they look similar)
Ltdodge is offline   Reply With Quote
Old 04-21-2009, 08:41 AM   #111
Danno
Danno's Avatar
Drives: 1993 Trans Am, 2007 Acadia
Richard's car not having them may be because his higher VIN, but then again, his is a 1SS with an AT and Davis and Snook's cars are both 2SS/MT cars, so I guess it's possible that either the 2SS package or the change in tranny is responsible too?
Camkid54's answer sounds the most plausible to me, though it would be nice to get some verification.
US Navy retired submariner.
previous cars, starting with my first.
1970 Nova
1967 RS/SS Camaro
1969 Chevelle
1970.5 Camaro
A long, undistinguished line of sedans, SUV's, and minivans.
Danno is offline   Reply With Quote
Old 04-21-2009, 08:42 AM   #112
Muscle Master
SS Lightning
Muscle Master's Avatar
Drives: An SRT8
So where is spike when you need him ....
The first rule of modding something that's not American is to not try to compete with modded V8 cars that are American. Really, they can run insane power with little investment. It's not even a fair fight.
Camaro 2SS RS, IBM, White Rally Stripes, custom fuel door: Status: going to the dealer: soon
Muscle Master is offline   Reply With Quote
Question: Cars only driven by one wheel? JMROD General Automotive + Other Cars Discussion 17 08-29-2010 04:04 PM
I need Camaros for an up coming event Jim Injun Ear USA - Southcentral 8 03-05-2010 05:07 PM
2SS Silver Ice Metallic at ATL Car SHow Cmurf_SS Camaro Photos | Spyshots | Video | Media Gallery 40 11-09-2009 09:38 PM
Saw 2 Camaros today... Cyberfan 5th Gen Camaro SS LS LT General Discussions 2 03-14-2009 06:43 PM
Current wheel & design,just an observation nitrokid Wheels and Tires Talk Sponsored by The Tire Rack 5 07-25-2008 12:33 PM
