Emblempros
Old 12-28-2011, 02:18 PM   #1
1985airborne
One Slow Automatic
1985airborne's Avatar
Drives: 2017 GS 2010 CAMARO SS
Jet Mass flow Sensor???
Has anybody used one and will this throw a CEL with headers and a CAI and Catback exahuast? One of my buddies was asking me about it and I didnt know so I thought Id ask you guys...
650HP 725TQ 2010 CAMARO SS STOCK 2017 GRAND SPORT
1985airborne is offline   Reply With Quote
Old 12-28-2011, 03:08 PM   #2
Synner
Drives: not stock
Its crap and a waste of money. A sensor is a sensor; they don't make power. Although theirs tend to fail more often or not be calibrated as well as GM's.
Old 12-28-2011, 03:14 PM   #3
SSOOCH
Camaro SL,UTs
SSOOCH's Avatar
Snake oil.
Old 12-28-2011, 06:12 PM   #4
SC2150
DON'T!!!!!
Old 12-28-2011, 09:58 PM   #5
dshep214
dshep214's Avatar
Drives: 2011 Camaro 2ssRS Ls3
wow i was considering this too after people told me they felt more power with it but i guess not now
dshep214 is offline   Reply With Quote
Old 12-28-2011, 10:54 PM   #6
JDP Tech
JDP Tech's Avatar
Drives: 2010 CGM Camaro 2SS/RS 429 LSX/F1X
The only mass airflow sensor mod anybody should do is check to make sure you have the better GM one, then replace it with a good GM one if needed.
As has been discussed several times, you can check by looking at the stamped identification number/letters on the sensor body. You want a letter followed by two numbers, of any combination.
There's a picture and close-up of the spot in the second picture here:
http://www.jdpmotorsports.com/brands...ensor-15865791
And even then, for most people, it won't make much of a difference, unless you have a Vararam, supercharger, or a custom tune.
Other than that, keep it stock!
- Jeremy
JDP Tech is offline   Reply With Quote
Old 12-29-2011, 01:06 AM   #7
1985airborne
One Slow Automatic
Ok Guys thanks for the insight!!! I WILL NOT BUY!!!
Old 12-29-2011, 06:51 AM   #8
cplabaunza
cplabaunza's Avatar
Drives: 2010 Chevrolet Camaro 2SS/RS
What about the MAF's from Granatelli Motor Sports?
http://www.granatellimotorsports.com...parent=33&pg=1
*Cyber Grey Metallic 2012 Chevrolet Volt
*Black 2010 Victory Cross Country
*Black 2008 Chevrolet Corvette 1LT/NPP/Z51/M6
*Black 2007 Dodge Charger SRT8
*Black 2005 Yamaha R6 (Raven color)
*Black 2010 Chevrolet Camaro 2SS/RS/M6 (SOLD)
*Black 2003 Dodge Neon SRT4 (SOLD)
*Inca Gold 2002 Chrysler Prowler(SOLD)
cplabaunza is offline   Reply With Quote
Old 12-29-2011, 07:53 AM   #9
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Not sure what Granatelli did to "calibrate" their MAF's but all the MAF does is measure the air coming into the engine. As long as the stock one is reading properly, there's no need to swap it out. A MAF that guarantees a increase in anything is just changing the resistor values to "trick" the PCM. Ones i've seen in the past have lowered the temp value to make the PCM give more timing. This is a bad thing since it could potentially do harm to your engine.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 12-29-2011, 02:03 PM   #10
JDP Tech
JDP Tech's Avatar
Exactly. Just like those $10 "performance chips" you see on eBay, they fool the computer to run differently than it should. You may notice a difference, but not worth the risk IMHO.
- Jeremy
Old 01-01-2012, 08:21 AM   #11
11TexaSS
11TexaSS's Avatar
Drives: 2011RedJewel, FI
Well there it is! Question answered!
11TexaSS is offline   Reply With Quote
Old 01-01-2012, 03:06 PM   #12
axis
Search Ninja
axis's Avatar
Originally Posted by Granatelli View Post
Granatelli works in concert with GM, Delphi and Hitachi. Our meters offer more dynamic range. The Jet Meter is a stock meter with a decal.
If your car has no more than exhaust and a cold air you most likely don't need a meter.
More dynamic range? Are you saying that your MAF has a higher topend reading?
Halltech CF 102 fed
Old 01-01-2012, 03:34 PM   #13
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
+1 on explaining your dynamic readings please.
Old 01-01-2012, 06:18 PM   #14
nycoupe11
Drives: 2011 2ss/rs Summit White
I wouldn't mess with it unless you really need to.. Check you sensor just to make sure you don't have a "weak" sensor. I thought that it's a letter followed by a number.. It's a letter by 2 numbers? Because then I have a weak one as mine is just one number
2011 2ss/RS Summit White / Grey and Black Interior. TSP VVT-2 Cam, ARH heads and Exhaust, CAI, Ported Throttle Body, Plasti Dipped tailight bezels and rims. AAC interior lighting. Tuned by East Coast Supercharging.
nycoupe11 is offline   Reply With Quote
Jet Mass Air Flow Sensor Mike2ss V8 Bolt-Ons & Tunes 3 12-16-2009 06:36 PM
JET Powr-Flo Mass Airflow Sensor trudawg660 Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 15 12-02-2009 06:39 PM
Great Read and Info on Oil Weight Banshee Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 11-23-2009 10:03 PM
Mass Air Flow Sensor Rod10269 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 1 10-17-2009 07:18 PM
New Aftermarket Parts - Clutches and Mass Air Flow Sensors Bewenched 5th Gen Camaro SS LS LT General Discussions 0 07-22-2009 03:42 PM
