SDPC
Old 12-28-2011, 03:23 PM   #1
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Question X-PIPE LOCATION..
Hello Camaro family, I have a question for you performance techs and the exhaust pros, I was at my dealership yesterday talking to my mech about my car and he showed me a 2010 SS L99 car that h3e installed a supercharger setup on, he had the car up on a lift to install a Hotchkis subframe connectors and swaybars and it had the GM performance exhaust on it and I noticed that the X-pipe was located behind the tranny tunnel brace and before the axles??? I asked why it was there and he said that is where it belongs.Before I installed mine I asked on here and was sent a pic of the proper location for it and it was before the tunnel brace where the big resonator was..What's up with that ??Does he have his in the wrong place? Or is this where it goes for supercharged aps..Thanks..Just curious..
Old 12-28-2011, 03:45 PM   #2
scythezo6
Virologist in the making
scythezo6's Avatar
Drives: 2010 VR SS/RS LS3
My Xpipe is where the H-pipe used to be.
Old 12-28-2011, 03:51 PM   #3
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Before the tunnel brace right??
Old 12-28-2011, 03:51 PM   #4
BLACK10
BLACK10's Avatar
It should be as close to the headers or exhaust manifolds as possible. Yet another Dealer tech that does'nt know sh*t........
Where do they find these guys?
Old 12-28-2011, 03:52 PM   #5
BLACK10
BLACK10's Avatar
Yes, before the tunnel brace
Old 12-28-2011, 04:00 PM   #6
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
That's what I was thinking and have read on here as to the location of it for best scavenging of the exhaust pulses. I didn't say anything to him about it, just shook my head in disbelief.. Just goes to show ya that some of these guys don't know what the F thay are talking about.And they are out there everywhere, just beware.. He's not working on my car..
Old 12-28-2011, 05:28 PM   #7
14pilot
Original Bumblebee Owner
14pilot's Avatar
Drives: 265hp ZX-14, 500hp Silverado, V-ROD
WRONG !!! WRONG !!! WRONG !!!
On a stock or bolt-on car (stock cam) the X-Pipe goes 73 inches behind the end of the stock cast iron manifolds, or...
...with headers, 73 inches behind the end of the primary tubes.
Also, both 36 1/2 inches AND 146 inches back will also work just fine too. Its about math, not myth...
There is no "Place" that is goes. Where it ends up depends on many factors, cam, headers, etc...
If that dealer car in question has long tube headers on it, the X-Pipe would be moved back from the stock location to be in the correct position. So many opinions, so many don't know $h!t.
#5 - 2010 2SS/RS MN6 ABM #142-Silver Rallys-GFX / Med Titanium
My previous Camaros:
#4 - 1994 Z/28 6M Black over Arctic White / Graphite-Red Inserts - traded
#3 - 1981 Z/28 Bright Blue Metallic / Black - sold
#2 - 1970.5 RS Mulsanne Blue / Blue - endo crashed it and parted it out
#1 - 1967 RS Butternut Yellow w/ Black Bumblebee Stripe-RPO D91 / Parchment-Black - sold
14pilot is offline   Reply With Quote
Old 12-28-2011, 05:42 PM   #8
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Does not have LT's on it. Stock exhaust manifolds..
Old 12-28-2011, 05:47 PM   #9
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Care to explain ?? Cause now everyone elses advice is wrong..
Old 12-28-2011, 05:49 PM   #10
14pilot
14pilot's Avatar
Ok, so if this car has a stock cam too, then the X-Pipe location is found by measuring directly down the imagined centerline of the exhaust pipe.
It would work fine at 36 1/2 inches back, EXCEPT the transmission would be in the way. So keep measuring back down to either 73 or 146 inches from the manifold/exhaust pipe joint.
If they put a cam in it (doubtful) then its a different measurement based on that cam.
Measurement from end of manifold (or primaries on LT headers) to the center of the X-Pipe
Old 12-28-2011, 05:57 PM   #11
14pilot
14pilot's Avatar
Yes, they are wrong.
The location is calculated using all the engine specs, focused on the cam timing. The calculation results in locations that determined in inches from the ends of the manifolds. The length is a tuned length based on the engine's exhaust harmonics.
As for the factory H-Pipe location, it is correct for a stock engine.
Old 12-28-2011, 06:09 PM   #12
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
OK, thanks for the explaination, so with this being explained I need to move mine back to where his is depending on the measurement ? And if I move it will there be any noticable difference in the sound or the performance of the car? I think I see what you are saying.Thanks.
Old 12-28-2011, 08:39 PM   #13
14pilot
14pilot's Avatar
If you are staying stock with the cam and you keep the stock cast iron exhaust manifolds, put the X-Pipe at 73 inches back. This will be about right where the stock H-pipe is at. If you put on long tube headers, then measure 73 inches back from the end of the primary tubes. This is also the same point as the front of the collectors (where the primaries join the forward part of the collectors). If you are going to cam the car, PM me the cam specs so I can calc where the X-pipe goes. For instance, if you were to cam the car with a cam that peaked at 6,400RPM, then the X-pipe would go 68 inches back instead of 73 inches back. If you then stroke the engine to 416c.i. then the X-pipe moves again.
Point is there is not a place on the car for the X-pipe, there is a measurement back based on what you are running under the hood.
You can use thin inexpensive striping tape to measure down the centerline of the exhaust pipes. Best to clean the pipe first. If you are careful, you can also use a steel measuring tape and sharpie to measure your way down the pipe. Just remember to imagine the pipe's centerline, start at the end of the manifold, end at the center of the X-pipe.
The correct location won't change sound much if any, but it will give the best performance. Good luck.
Old 12-28-2011, 11:46 PM   #14
alybudhwani
alybudhwani's Avatar
Drives: 2010 Camaro 2SS Aqua Metallic Blue
thanks for the info 14pilot, this helped me a lot!!!
http://www.camaro5.com/forums/showthread.php?t=167460
check out my build
seriously though...
alybudhwani is offline   Reply With Quote
When are 2" headers necessary? jasycz28 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 50 08-30-2016 02:39 PM
E85 TUNE RESULT!! bmorecam Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 327 10-13-2011 06:22 PM
DIY catch can for $27 and a little time... shines Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 17 09-22-2011 07:30 PM
CAI cold air induction with E-Force gearhead440 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 9 08-16-2011 08:16 AM
Next project - X pipe and 2.5 pipe, need advice BaylorCamaro Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 6 08-31-2010 08:31 AM
