Old 12-28-2011, 07:02 PM   #1
CamaroCruzin
CamaroCruzin's Avatar
Drives: 2010 1SS/RS
Question for those with Borla exhausts
I recently spoke with a very respected and trusted shop owner in our area about installing a an axle-back Borla Type S kit for my 2010 SS. He said he'd do it but pointed out that he has had some trouble with Borla exhausts because they never seem to fit right without some adjustments being made on his part. Otherwise the pipes can be uneven or not level with each other... just wanted to know if any members with Borla exhausts had any issues like this?
Also he has never installed them on a Camaro, closest vehicle was a Corvette. But he always has issues with Borla on other vehicles. Thanks
CamaroCruzin is offline   Reply With Quote
Old 12-28-2011, 07:09 PM   #2
molsonbrador
molsonbrador's Avatar
Drives: 2010 Camaro SS, 99 Silverado
Find another shop. I did my own and didn't have a problem.
molsonbrador is offline   Reply With Quote
Old 12-28-2011, 09:25 PM   #3
alybudhwani
alybudhwani's Avatar
Drives: 2010 Camaro 2SS Aqua Metallic Blue
yeah find another shop, i installed my borla atak axleback with no problems.
http://www.camaro5.com/forums/showthread.php?t=167460
check out my build
seriously though...
alybudhwani is offline   Reply With Quote
Old 12-28-2011, 09:28 PM   #4
simonmcnasty
The Juggernaught
simonmcnasty's Avatar
Drives: 2010 IBM 2SS/RS
agreed, find another shop...installed a few myself on vettes and never had a problem
2010 IBM 2SS RS / LG G6X3 Cam / 1 7/8" Kooks headers / Hi-Flo Cats / ADM Cold air / Magnaflow 3" exhaust / UD Pulley / Sam Miller Tune / SAE 481RWHP 441RWTQ / Eibach Pro-kit / Eibach front and rear sway bars / Elite Catch Can / DRL Harness and AAC Plasma bulbs
simonmcnasty is offline   Reply With Quote
Old 12-28-2011, 09:39 PM   #5
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
Old 12-28-2011, 09:43 PM   #6
1Camaro2SS
1Camaro2SS's Avatar
Drives: 2010 2SS/RS L99
Installed my own as well, no problems. I have a catback.
432 RWHP 391 RWTQ 12.37 1/4 mile on stock tires
1Camaro2SS is offline   Reply With Quote
Old 12-28-2011, 10:29 PM   #7
CamaroCruzin
Drives: 2010 1SS/RS
So I guess I should find another shop huh? Haha ok sounds like I'll look around some more. Heck I might just take it to the dealership n have them do it. Thanks for your help guys.
Old 12-29-2011, 09:07 AM   #8
BigBlock427
ConceptZer0
Drives: 68 427 Camaro, 11 2SS/RS, 13 ZL1
^ I would not do that... dealerships will overcharge you a ton... I did my Atak cat back on my car and it was a breeze. For an axel back the job should take you about 45 mins.
I would just do it your self and get the enjoyment of working on your car. If not a local muffler shop could do the install way cheaper then any dealer.
BigBlock427 is offline   Reply With Quote
Old 12-29-2011, 12:02 PM   #9
Switchback700
Drives: 2010 2SS IBM L99
M6 or A6?
Switchback700 is offline   Reply With Quote
Old 12-29-2011, 03:45 PM   #10
CamaroCruzin
Drives: 2010 1SS/RS
Ya I would liketo do it myself but have an issue because I dont have ramps or a jack low enough to get underneath the car.
Switchback it is an A6... Also one more thing, I read that you would have to cut the OEM pipe if installing an axle back, I was under the assumption that being an axleback it was just a bolt on. Did you have to cut anything?
Old 12-29-2011, 04:14 PM   #11
fourmz
Fourmz
fourmz's Avatar
Drives: 2010 2SS/RS 1968 Firebird 1994 Z28
My S type axle back went in with no problem.
Black-in-Black/Blue out 2010 2SS/RS LS-3 -Magnacharger TVS2300,OD cog belt drive, 3.4" pulley, Janetty smooth idle blower cam,ID-850 injectors,ZL1 fuel pump,MSD boost a pump, ADM FPCM Janetty custom tune,Doug Thorley long tube headers, Corsa catback,C.A.I. Intake, Roto-Fab Big Gulp Scoop, Monster LT1/SC Clutch assembly,Eibach pro kit plus, BMR cradle/diff bushings, Barton Shifter,JRE 3.91 Eaton Tru-Trac rear diff,Barton Short Throw SHifter, Boss 339 20" wheels,Painted heritage grille, Sparks Restoration Inverted blue/black SS emblems, Seibon BB carbon fiber hood, ZL1 front bumper conversion.
fourmz is offline   Reply With Quote
Old 12-29-2011, 04:16 PM   #12
n116ebo
n116
n116ebo's Avatar
Drives: 2010 2SS YELLOW TRANSFORMER AUTO
I have the borla s axleback on my camaro and you have to cut the oem mufflers off, the borla instructions will tell how and where. If you are installing the cat back borla setup it is a bolt on set up. Happy motoring.
n116ebo is offline   Reply With Quote
Old 12-29-2011, 05:40 PM   #13
Switchback700
Axle back you have to get the sawzall out.... also, the Borla is going to make your AFM very noticable and annoying.... if you are willing to tune the AFM off (lose warranty), no problem, but if you are trying to MOD and keep your warranty you REALLY want to do some research on AFM and aftermarket exhaust options for an L99 with AFM still activated.... look at Solo with a "J' pipe to control the aweful 4 cylinder exhaust issues you will experience. I learned the hard way... which may be the same path you are on... let us know and we can help you save some $$$$....
Old 12-29-2011, 06:26 PM   #14
molsonbrador
Drive up on a couple bricks or wood. Jack will go under then. Oh yea, measure twice...cut once.
Borla ATAK Exhaust Sale southerncarparts V8 Bolt-Ons & Tunes 107 03-23-2016 11:04 PM
APEX Motorsports is the newest Borla Performance Warehouse Distributor! Apex Motorsports V8 Bolt-Ons & Tunes 90 04-13-2011 05:12 PM
Borla Stinger Question nalinc23 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 8 02-08-2010 01:39 PM
BORLA question jnm2003 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 12-18-2009 12:33 PM
