HeadlightArmor
Old 12-28-2011, 08:02 PM   #1
newagemuscle
Philippians 4:13
newagemuscle's Avatar
Drives: SLP Supercharged LS3
Header Question? Will my axle back negate my power?
Here's the scoop... I have the SLP LMII axle back and am looking to get some Kooks LT's. Am I wasting my time putting LT's on my car if I am running just an axle back? Does the axle back restrict the flow to where it is a waste of my money doing LT's with just an axle back. If I could go back I would have just done the cat-back, but whats done is done.
Is anyone else running LT's with just an axle back?
Thanks
newagemuscle is offline   Reply With Quote
Old 12-28-2011, 08:04 PM   #2
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
Send a message via AIM to jeffny09 Send a message via Yahoo to jeffny09
I'm not to sure, I did lts wit high flows and straight pipes ,
top 10 reason why real men drive stick.
10. A manual transmission is the ultimate in control
9. You can use automotive jargon and not sound like a total tool
8. You can't spell "manual" without "man"
7. Manual transmissions prove you can do more than one thing at a time
6. You can't drift in an auto
5. You can't pull fancy moves in an automatic
4. You get better fuel economy with a stick
3. You’ll never look like a chump if you can drive stick
2. Manual transmission cars are faster
1. Women like a guy who is good with his hands.
jeffny09 is offline   Reply With Quote
Old 12-28-2011, 08:07 PM   #3
newagemuscle
Philippians 4:13
I plan on doing the high flow cats also. I thought I had it figured out on what I wanted to do, but now after reading I wonder if I need to dump my axle back and get a full corsa cat-back too. I would love too do both, but $$$ adds up real quick between everything.
Old 12-28-2011, 08:09 PM   #4
Parag
Drives: 2010 camaro 2SS LS3
almost all axel back systems do absolutely nothing for power. headers will add power. the reason most people dont do what you are doing is because it is usually a waste to replace the front and the rear and leave the middle. they just get the whole system. there is no negation of power
Parag is offline   Reply With Quote
Old 12-28-2011, 08:13 PM   #5
tjbusa
Serious Sleeper
tjbusa's Avatar
Drives: 2010 CGM 2SS/RS M6
No matter what, they will out perform those stock boat anchors. So, no
Drive-by
Fact of Life:
After Monday and Tuesday
even the calendar reads...
W T F
tjbusa is offline   Reply With Quote
Old 12-28-2011, 09:19 PM   #6
alybudhwani
alybudhwani's Avatar
Drives: 2010 Camaro 2SS Aqua Metallic Blue
you should be fine. a lot of people get shorties and axlebacks, and leave everything stock and they still make some power. so im assuming you would gain a lot more power with lt headers
http://www.camaro5.com/forums/showthread.php?t=167460
check out my build
seriously though...
alybudhwani is offline   Reply With Quote
Old 12-28-2011, 09:22 PM   #7
Fireslayer
LT's give you preformace and sound. Everything else is just sound......and more money of course. Skip the cat back and save your money. LT's with your axle back may even be too loud for your taste. LT's with stock cat back and high flow cats are prefect for me. I get a bit of a deeper tone at idle and normal driving and a growling LS V8 when I put down the peddle.
Fireslayer is offline   Reply With Quote
Old 12-28-2011, 09:40 PM   #8
Smirnoff
Smirnoff's Avatar
Drives: Camaro SS
No problem!
Thanks
Several of us are running LT's with stock exhaust with no reduction in HP at all.....several threads on C5 validate through dyno testing that OEM exhaust flow(s) very well!
11.90's w/headers, CAI, custom tune, slicks/skinnys, shifter & 100+ Ethyl.
Smirnoff is offline   Reply With Quote
Old 12-28-2011, 11:30 PM   #9
newagemuscle
Philippians 4:13
By your sig it looks like you have exactly what I am looking to do... other than purhaps the Loudmouth II. I curently have the Rotofab too. What kind of numbers are yopu putting down with that setup?
Old 12-29-2011, 09:08 AM   #10
Smirnoff
Smirnoff's Avatar
Drives: Camaro SS
Currently at (RW) 417HP/411TQ - definitely a significant difference in acceleration/performance than stock!
Get your Kooks Jet-Hot coated, a small price to pay for the extra-value.....
Old 12-29-2011, 09:21 AM   #11
2010SSRSM6
2010SSRSM6's Avatar
There is only one axle-back that I've seen anyone say robbed them of power. Do a search to confirm, but I think it was one of flow masters kits. Please don't take this as fact because it's been a while since I read the thread.
I believe it was busyboi's car, but again not completely positive.
I'm running BBK LT's and a JBA axle-back. With a CAI and tune I put down 430/430 on a stingy dyno.
Old 12-29-2011, 10:45 AM   #12
v6sonoma
v6sonoma's Avatar
Drives: 2010 SS RS
Sounds more like a generous dyno.
9/26/09 Took delivery!
Old 12-30-2011, 01:14 PM   #13
sscamaro
sscamaro's Avatar
Drives: 2010 2SS, 2012 Silverado LTZ
I added the SLP LMII after I got it home from the dealer. A week later I installed Kooks LT headers/hi-flo cats. I didn't change the mid pipe. Kooks said I'd gain 5-10 hp with an X-pipe for $300 more. I couldn't see spending $300 for 5-10 HP. I had a dyno tune, a ported intake and aported TB after that. I got 424/rwhp. I think that is pretty good.
2010 2SS/RS Victory Red, MN6, 1-7/8 Kooks LT Headers, SLP Axle Back, Edelbrock E-Force S/C, ZL1 Fuel Pump, 72# Injectors, JRE fuel rail upgrade, Roto-Fab CAI, Elite Catch Can, Billet Hurst Shifter, DSS 1000HP axles, Spohn Trailing Arms, Toe Links, Lower Control Arms. Chrome Torq-Thrust wheels. 546/rwhp & 522/rwtq Tune by Jeremy Formato.
sscamaro is offline   Reply With Quote
Old 12-30-2011, 01:16 PM   #14
geaux_tigerss
geaux_tigerss's Avatar
Drives: 2014 GMC Sierra Denali
I recommend headers with corsa. It sounds incredible!
2011 2SS/RS M6 CGM Rotofab CAI, Kooks 1 7/8, Corsa (LS3)
geaux_tigerss is offline   Reply With Quote
Modifying for " Dummies" Dr Jkel Tuning / Diagnostics -- engine and transmission 209 06-18-2012 12:24 AM
NEW GROUP BUY- Solo Performance Axle Back with J pipes & Mach XL (L99) with J Pipes GOINGSOLO2 V8 Bolt-Ons & Tunes 130 12-20-2011 08:15 PM
Axle back question catmancan Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 05-29-2011 07:38 PM
For Sale 304 cat back $250 axle back only $200 storm83 V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 1 03-21-2011 10:49 AM
axle back deleted mufflers? lost power it seems camarossrs2150 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 63 06-14-2010 10:32 AM
