Cold Air Inductions
Old 12-28-2011, 09:32 PM   #1
MileMAN402
RIP JoePa
MileMAN402's Avatar
Drives: 2010 2SS/RS & 2001 Audi S4
HELP! What are these bearings from??
Ok so I was changing my oil tonight and I pulled the magnetic drain plug out and these were stuck on the end. I have a Jannetty installed cam package so I'm gonna call them in the morning but SHOULD I BE WORRIED??
Thanks guys.
MileMAN402 is offline   Reply With Quote
Old 12-28-2011, 09:52 PM   #2
blazzin1
blazzin1's Avatar
Drives: 2016 2SS (A8)
I have no idea where they came from, but yes, I would be VERY concerned!!!! In fact, I wouldn't start your engine until you find out where they came from.
blazzin1 is offline   Reply With Quote
Old 12-28-2011, 09:54 PM   #3
simonmcnasty
The Juggernaught
simonmcnasty's Avatar
Drives: 2010 IBM 2SS/RS
They look like needle bearings from rocker arms
2010 IBM 2SS RS / LG G6X3 Cam / 1 7/8" Kooks headers / Hi-Flo Cats / ADM Cold air / Magnaflow 3" exhaust / UD Pulley / Sam Miller Tune / SAE 481RWHP 441RWTQ / Eibach Pro-kit / Eibach front and rear sway bars / Elite Catch Can / DRL Harness and AAC Plasma bulbs
simonmcnasty is offline   Reply With Quote
Old 12-28-2011, 10:04 PM   #4
sschevybear11
sschevybear11's Avatar
Drives: 2011 Black 1SS
BINGO. Teardown time.
2011 Black 1SS M6 12.75@110.91 bone stock
Now: Coated Dynatech LT's/!Cats/Hurst Shifter/Roto-fab/SLP SS badges/JRE 415HP Tune, Scoop & Washer Relocation Bottle,Hurst Stunner 20X9 Wheels, Moroso Catch Can, ASP pulley, Magnaflow X-pipe, GTO remote clutch reservoir
1989 Silver 5.0 Mustang LX Coupe
1999 Pewter Tahoe LT
2011 Blue Camry SE
sschevybear11 is offline   Reply With Quote
Old 12-28-2011, 10:04 PM   #5
jrpimp00
jrpimp00's Avatar
Drives: '10 Black/IOM Camaro SS/RS
This^^^^^^ Dont try to start it, but take the valve covers off and inspect the rockers
2010 Camaro 2SS/RS Black/IOM //// 1998 Pontiac Trans AM 819 RWHP @ 12 PSI (Turbo)
jrpimp00 is offline   Reply With Quote
Old 12-28-2011, 10:19 PM   #6
MileMAN402
RIP JoePa
MileMAN402's Avatar
Thanks a lot guys. Weird part is I have about 4500 miles on the cam and valve train upgrade and not a single noise or problem. Or is this something that I might not notice until it completely goes? I would have expected a lot more bearings from the rocker arms?
Old 12-28-2011, 10:23 PM   #7
MileMAN402
RIP JoePa
MileMAN402's Avatar
Do you think these stray ones could have fallen out of the old rockers when they did the trunion upgrade?
Old 12-28-2011, 10:28 PM   #8
BOSS_HOSS
BOSS_HOSS's Avatar
Drives: 2010 Camaro SS
Sounds like I have the same Jannetty cam package...I've had no problems whatsoever and just ordered a magnetic drain plug. I would say since the trunion upgrade would be done on a press/vice that these are not from the stock rocker bearings. Though when you are pressing out the stock ones those needles go everywhere. I'm very curious what Ted has to say.
2010 2SS/RS 1 7/8" Long Tube American Racing Headers w/high flow cats, Borla S-Type Catback Exhaust, Roto-Fab CAI, VMAX Ported Throttle Body, MGW Shifter, JRE 445 Street Cam Package tuned via SCT, Pedders Street 1 Kit.
BOSS_HOSS is offline   Reply With Quote
Old 12-28-2011, 10:30 PM   #9
MileMAN402
RIP JoePa
MileMAN402's Avatar
Yeah I have the 470 but the only difference is the cam. I'm gonna call Ted in the morning.
Old 12-28-2011, 10:46 PM   #10
Darth_Emma
Psssssssssshhhhhhhhhhhhh!
Darth_Emma's Avatar
Drives: under contruction
I just had the trunion upgrade done to my rockers...
Thank goodness for magnetic plugs!
Old 12-29-2011, 11:45 AM   #11
DietCoke
Slow Turtle
DietCoke's Avatar
Drives: 2011 1SS
Send a message via AIM to DietCoke
Those are 110% rocker arm needles. Pull yours and get the trunion upgrade.
DietCoke is offline   Reply With Quote
Old 12-29-2011, 11:50 AM   #12
Darth_Emma
Darth_Emma's Avatar
I think he said he had the trunion upgrade...
Old 12-29-2011, 11:50 AM   #13
MikeOD
Drives: 2010 M6 2SS
He says he already has the trunnion upgrade...hopefully you didn't lose a snap ring on the trunnion and lose one of the comp bearings...if a bearing from the comp upgrade kit comes completely off of the trunnion, there are similar needles that you could lose inside the engine.
2010 Camaro SS M6. Heads/Cam/Intake/Headers/Exhaust/Suspension
MikeOD is offline   Reply With Quote
Old 12-29-2011, 11:58 AM   #14
MileMAN402
RIP JoePa
MileMAN402's Avatar
Yeah unless they are stuck in the engine elsewhere these are all that came out and I flushed some extra oil through. I think Jannetty's is closed for a couple more days but I want to talk to Ted directly before I go pulling valve covers cuz idk what exactly to look for. Maybe I'll be doing a forged stroked sooner than I thoughtN
BMR Launches New Product - 2010 Camaro Trailing Arms w/Spherical Bearings (TCA027) BMR Suspension Suspension / Brakes / Chassis 4 05-28-2010 11:42 AM
Wheel Bearings (How to Replace them?) Zabo General Automotive + Other Cars Discussion 2 10-28-2009 08:00 AM
Whats my car worth, 1997 Coupe (Engine Bearings gone) 97_Camaro 4th Generation Camaros 5 06-16-2009 05:57 PM
Spherical Control Arm Bearings PfadtRacing Wheels and Tires Talk Sponsored by The Tire Rack 0 03-26-2009 11:39 AM
