Old 12-29-2011, 07:05 PM   #1
pears2
Drives: 2011 Black/Silver Synergy Series
Clutch Question (Bad Smell)
I have a driveway which is on an upward incline. I usually put the car in reverse and back it up into the garage. As I drive in reverse up the incline, I have the clutch about half way out until I reach the garage. The drive way is about 150 feet long. I have noticed a bad smell coming from the car as I drive backwards, kinda smells with rotten eggs. The car has 700 miles on it, 2SS, M6. Anyone have any ideals what the smell is from. The only time I have noticed it is when I drive backwards up the driveway.
pears2 is offline   Reply With Quote
Old 12-29-2011, 07:14 PM   #2
GlennP
Drives: 2011 Camaro 2SS
If you are just holding the clutch halfway up and running it up your driveway like that, you are burning up your clutch. You need to release it fully if you are going to drive any distance, especially uphill.
GlennP is offline   Reply With Quote
Old 12-29-2011, 07:23 PM   #3
dshep214
dshep214's Avatar
Drives: 2011 Camaro 2ssRS Ls3
new clutch burning. Once the car gets more broke in it won't happen as often.
dshep214 is offline   Reply With Quote
Old 12-29-2011, 07:44 PM   #4
CamaroKid300
ace5.org
CamaroKid300's Avatar
Drives: 2012 2SS/RS LS3
Yeah I don't suggest holding the clutch halfway 150 feet worth of backing up...
but that is exactly why its doing that.
I've burned mine a few times backing up, but I only have 1400 miles so I still expect it a little.
NightOwl RGB Halo Kit V2, Kooks 1-7/8 LT Headers, Cam Motion Cam, CAI Intake, Catless Midpipes, Borla ATAK Catback, 35% Tint, Vinyl Gill Blackouts, RX Catch Can, Devil Tail Side Stripes, Front Lip Blackout, Dual Color Bowties, Ghosted Sidemarkers,
Exhaust Video (Manifolds) Exhaust Video (Headers) White Lightning
A.C.E.5.
xxx RWHP/xxx RWTQ
CamaroKid300 is offline   Reply With Quote
Old 12-30-2011, 12:11 PM   #5
SGDM
SGDM's Avatar
Drives: 2016 2SS
15 K on mine and still get clutch burn now and again in 1st
Who Dares...Wins
ADM Performance Built LT4 SC
SGDM is offline   Reply With Quote
Old 12-30-2011, 12:14 PM   #6
ITGuy11
Burning up tires
ITGuy11's Avatar
Drives: 2010 Camaro 1SS/RS
You are KILLING your clutch! Always fully release clutch the pedal when driving, that is unless you are purposely slipping the clutch to launch at the track.
Blower, cam, supporting mods 644RWHP 615RWTQ
My Build Thread COTW 11/19/12
Detroit 5th Gen Camaro Club
ITGuy11 is offline   Reply With Quote
Old 12-30-2011, 01:22 PM   #7
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
The smell of a burning clutch alone should be enough incentive not to let that happen.
Old 12-31-2011, 02:00 PM   #8
v6sonoma
v6sonoma's Avatar
Drives: 2010 SS RS
Definitely release the clutch once you get going. Thats to long a distance.
9/26/09 Took delivery!
Old 12-31-2011, 02:04 PM   #9
jamie
Drives: 2011 cyber gray 1LT
Always release the clutch all the way once you are moving... This would be no different than driving around while holding the brakes... Not good for the friction surface on your clutch... You will be replacing it soon if you don't stop that behavior.
jamie is offline   Reply With Quote
Old 12-31-2011, 07:05 PM   #10
almarlowe
Drives: 2010 Camaro SS RS
slipping a clutch is exactly what it sounds like, the clutch plate is spinning at a lower speed than the flywheel and pressure plate. This creates heat from friction and this creates clutch burn and pressure plate and flywheel damage, and the associated smell. Let the clutch out as soon as you can to prevent clutch, pressure plate, and flywheel friction heat and associated damage-yes this heat can ruin all 3 components
almarlowe is offline   Reply With Quote
Clutch Question Mungo V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 5 12-14-2009 08:34 AM
Clutch Question francone13 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 5 11-26-2009 10:28 AM
QUESTION about clutch on LS3... IROCanSS V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 5 11-04-2009 08:38 AM
Clutch question Chewy V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 0 11-03-2009 10:56 AM
Bad smell from 2007 Avalanche A/C vents? Mavtop General Automotive + Other Cars Discussion 3 06-14-2009 10:57 PM
