HeadlightArmor
Old 12-31-2011, 10:42 PM   #15
s/c ss
s/c ss's Avatar
Drives: 13 ZL1, 10 Silverado LTZ, Chopper
Originally Posted by darnelhouston View Post
I installed 1inch drop springs from Eibach all round. And sway bars from BMR fully stiffened. And the 4 pt BMR strut tower brace.
What can I do to return to a more confortable ride?
You've installed the items above so of course your suspension is going to ride and feel stiffer. Springs are tighter so less "spring", sway bars are thicker so less "sway".
s/c ss is offline   Reply With Quote
Old 12-31-2011, 10:48 PM   #16
darnelhouston
Drives: '10SS, CAI, Resonators delete, Dyno
Thing is. The ride is horrible.
darnelhouston is offline   Reply With Quote
Old 12-31-2011, 10:50 PM   #17
darnelhouston
It got worst after bottom out.
Old 12-31-2011, 10:53 PM   #18
PitchBlack
(with a little chrome)
PitchBlack's Avatar
Drives: The Black Knight
Is it possible for your suspensions to stiffen up. Or somehow make your ride more painful. Recently my camaro has been driving really rough. I can feel even the smallest dips more than usual and cracks on the road.
I did have all this installed for almost a month now but didn't notice much untlil just about a week ago.
*i have to say, a couple of night before I started to notice this poor ride- I was going about 50mph and went through a dip in the road. The car almost lost control. I hop so hard my head hit the top of the car. Bottomed out.
Go back to the suspension system that the Chevy engineers gave you to start with.
_______________________________________
[COLOR=seagreen]Mods Installed:
Backup sensors
American Racing Rogue Wheels
AAC LED Interior Light Kit
Ordered:
BlingLights Fog Light Kit
AAC Footwell Ambient Lighting Kit
Complete Lamp Protection Kit
(Smoked Finish)
PitchBlack is offline   Reply With Quote
Old 12-31-2011, 11:13 PM   #19
s/c ss
s/c ss's Avatar
+1
Old 01-01-2012, 02:50 AM   #20
darnelhouston
But now I can take turns at 75mph
Old 01-01-2012, 09:02 AM   #21
2010SSRSM6
2010SSRSM6's Avatar
I'd start in the vendor section of the marketplace and see what gets your attention.
Pedders, Pfadt, BC etc, you can't seem to go wrong with any of them. If you look outside C5, KW Variant 3's are pretty dang good too.
Old 01-01-2012, 10:49 AM   #22
JamesNoBrakes
JamesNoBrakes's Avatar
Drives: 2SS 1LE
I think this is why they tend to say that drop-springs are more of a cosmetic enhancement, sure it lowers the CG, but your damping rates are all screwed up based on the spring force now. I got sways and a strut bar and got the chance to tear up some mountain roads in the Eastern CA Sierras over the last week and all I can say is WOW, soooo much fun. Yeah, it would be neat if my car looked lower, but it's not worth the hassle with drop-springs.
JamesNoBrakes is offline   Reply With Quote
Old 01-01-2012, 01:07 PM   #23
Bruce@raymondsperformance
Bruce@raymondsperformance's Avatar
Drives: 2014 Z28 camaro
Any ideas or links on the parts I would need. I have some money saved. I was planning on changin my interior trim red and do some inserts. Darn it.
After the shop checks your car over and gives you an idea of what is wrong,give me a call and we can go over what you should do to prevent it from happening again.As said in this thread the coil overs are the best way to lower your camaro,and we still have the Pedders on sale if you are intersted.
Bruce@raymondsperformance is offline   Reply With Quote
Old 01-01-2012, 09:34 PM   #24
mws444
mws444's Avatar
Drives: 701 RWHP Lingenfelter/Pedders Beast
+1 Give him a call and he will get you back up and running smooth in no time. Have to watch the drop springs as they will age your struts pretty quickly. Coilovers while a lot more expensive are a long term fix, you can get your car down lower and still mantain a good ride long term.
Lingenfelter forged balanced and blueprinted LS3, Maggie TVS 2300 LPE 9.5" Rearend 3.73,LPE dual disk clutch,10/14 rib belt drive,
MTI shifter,RPM Level VI,Corsa stainless cat back, Racing Brake Rotors, LPE calipers, LPE twin fuel pumps, American Racing long tube headers, GT9 cam Port and polished heads and an ADM majic tune.
701 RWHP,Fully Pedderized w/complete bushings and Sportsryder Supercar Remote resevior coilovers.
CCW 505t's Nitto Invo's and DR's
Beware of the LPE Brotherhood!
mws444 is offline   Reply With Quote
Old 01-02-2012, 05:17 AM   #25
darnelhouston
Okay thanks guys. Tomorrow I'll see into buying the bc coil overs. I'm on a tight budget that seems to be my only option -price/sale wise.
Old 01-02-2012, 03:10 PM   #26
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
If your ride quality was acceptable before hitting the dip, and then began to get worse from there make sure you get the car to a shop for a through inspection of the suspension up on a lift. Your ride quality shouldn't dramatically change a month after installing the suspension unless there is something damaged or maybe binding. A very hard look at the sway bars, endlinks, struts, all mounting points and condition of the control arms and bushings may turn up something that's been damaged after your hard impact.
A "blown" shock will likely leak, and feel loose and uncontrolled. If the car is feeling significantly firmer or more harsh than it did after you first installed the suspension package look for something binding or damaged. Either way a professional inspection should shed some light on the situation.
Old 01-02-2012, 03:39 PM   #27
EM1/SS
Drives: 11 2SS/RS M6 vert
I would try to find out what's wrong with it before I bought anything else.
LSA supercharger, Borla S-Type cat back, BMR/ Pedders Suspension, Kooks stepped LT's, GM 3.91, and RDP tune.
EM1/SS is offline   Reply With Quote
Old 01-02-2012, 04:41 PM   #28
darnelhouston
Got it. Will get it checked. Just have so much going on. I will take it to a suspension shop.
bmr, eibach, ride quality, springs
Lowered Ride Quality PsshPlzz Suspension / Brakes / Chassis 42 06-30-2010 02:20 PM
Ford gets 5 top quality awards KILLER74Z28 General Automotive + Other Cars Discussion 5 06-13-2007 01:28 AM
