Cold Air Inductions
Old 12-31-2011, 06:49 PM   #1
ricks-ss
Drives: 2011 rs/ss,cai,borla attack exhaust
o2 sensors
so who has installed headers and high flow cats and had to replace o2 sensors? i had one front and one rear strip out now i have to wait till monday to order new ones
ricks-ss is offline   Reply With Quote
Old 12-31-2011, 07:05 PM   #2
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
It's not unusual to "drop a thread" when removing O2 sensors. Those things are in a HOT spot.
Be sure to use anti-seize compound when you replace them.
Best removal technique for me is to use a heavy open end box wrench on the sensor (are they 15/16th?) and tap the far end of the wrench with a hammer. Never had a problem doing it this way.
Old 12-31-2011, 07:30 PM   #3
gelboy1015
gelboy1015's Avatar
Drives: '10 2SS/RS, MKIII Supras
I did the same technique and all of my O2 sensors came out fine
2010 Camaro 2SS/RS
- LS3, M6. -
Build Thread/Mods List
gelboy1015 is offline   Reply With Quote
Old 12-31-2011, 08:00 PM   #4
blufin
blufin's Avatar
Drives: Fire Engine
A little penetrating oil will also help. heating up the bung with a torch is good too.
My went pretty smooth, nothing stripped.
Good luck.
12.618 @ 110.75 Bone Stock 1/4 mile
8.165 @ 86.52 Bone Stock 1/8 mile
11.189 @ 124.44 on a 1.73 60' TVS2300 3.4 pulley, JRE tuned, Kooks LT headers and HF cats, MBRP catback exhaust, CAI intake, ADM scoop. Stock wheels/tires.
Sold
blufin is offline   Reply With Quote
Old 12-31-2011, 09:49 PM   #5
Skidpuppy
ACE5
Skidpuppy's Avatar
Drives: 2010 2SS/RS LS3
I had to buy one rear. Luckily, the nearest Chevy dealer had one.
SIM 2SS/RS LS3, Vararam, RX Catch Can, SOLO HF Cats, Flowmaster AT Catback, Skip-Shift Eliminator. 404HP/414TQ
Skidpuppy is offline   Reply With Quote
Old 12-31-2011, 10:26 PM   #6
eclipsen
Drives: 2010 Camaro 2SS/RS
I had to buy 2 rear sensors. Both were a pain to remove. One of them was cross-threaded from the factory. The fronts came out with no problems.
2010 Camaro 2SS/RS, 6M, ADM Race scoop, CAI intake, VMAX TB, Kooks LTs, Solo Mach X, MGW Shifter, Dynotech driveshaft, 1LE 3.91 gears with JRE updates, BMR bushings/Toe/Trailing Arms, Pedders ZL1 sways and XA Coilovers, Heritage Grill, Yenko side stripes, SS emblems, Havoc Rear Spoiler.
eclipsen is offline   Reply With Quote
AAC Afterburners + Parking Sensors - Problems? x7productions Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 7 05-11-2013 12:19 PM
What will a GM dealer exactly do when programming TPMS sensors on the car?Wont Reset! 55Designs Wheels and Tires Talk Sponsored by The Tire Rack 13 02-20-2011 09:02 PM
Have All Issues Been Worked Out With TPMS Sensors? LYCAN Wheels and Tires Talk Sponsored by The Tire Rack 12 01-31-2011 04:13 PM
Tire Monitoring System monevz28 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 7 11-22-2009 04:42 PM
