BeckyD @ James Martin Chevy
Old 01-01-2012, 08:35 AM   #1
20camaro12
20camaro12's Avatar
Drives: 2012 45th anniv. Convertible SS LS3
cam DD worth it?
Is a cam really worth it for a DD? I love the way a cam makes the car sound, but reading through the forums about different cams, I think it is going to be more of a hassle for a DD... Opinions? Anyone have one with the SW retro cat-back?
20camaro12 is offline   Reply With Quote
Old 01-01-2012, 09:02 AM   #2
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
The LS9 cam is a mild bolt in upgrade. It is inexpensive, can be used with the stock valve springs, pushrods and timing chain. It idles very similar to stock, still gets good gas mileage and drivability is like stock. With CAI and LT's it makes about 15 to 20rwhp over stock LS3 cam tuned. If you can do the cam swap yourself, it is a good upgrade at a reasonable cost.
Ed M.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, ZLI calipers & rotors, BMR Trailing & Toe Arms, full rear cradle & diff bushings, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, ZL1 Brembo Brake pads, GTO clutch reservoir, LS9 cam, Comp Cam valve springs, Melling 10296 oil pump, CR 5 timing chain, LS2 damper, CAI Cold Air Induction, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9.5 & 20x11 DS3 wheels w/Vredestein 275/40/20 & 315/35/20 tires, '11 Convertible spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat
flht99b is offline   Reply With Quote
Old 01-01-2012, 09:06 AM   #3
mlee
www.CamaroFans.com
mlee's Avatar
Drives: 2017 A10 ZL1
You don't show whether you have an Auto or Manual... it makes a difference. Autos w/ a nice Torque Convertor make a great daily driver w/ a cam... Might be more of a PITA for a Manual
Old 01-01-2012, 09:09 AM   #4
simonmcnasty
The Juggernaught
simonmcnasty's Avatar
Drives: 2010 IBM 2SS/RS
DD here. It would just depend on your expectations. I've been driving some sort of modified vehicle as a DD for as long as I can remember so to me its a normal drive and I wouldn't have it any other way. I can't stand driving a bone stock vehicle..too boring for me.
I suppose if you had been driving bone stock cars your whole life then you might find it "different". Is it worth it? opinions vary.
2010 IBM 2SS RS / LG G6X3 Cam / 1 7/8" Kooks headers / Hi-Flo Cats / ADM Cold air / Magnaflow 3" exhaust / UD Pulley / Sam Miller Tune / SAE 481RWHP 441RWTQ / Eibach Pro-kit / Eibach front and rear sway bars / Elite Catch Can / DRL Harness and AAC Plasma bulbs
simonmcnasty is offline   Reply With Quote
Old 01-01-2012, 09:18 AM   #5
Supercharged SS
Drives: 2010 Camaro
The greater the "lope" the more it will drive NOT like stock. So you didn't specify if you wanted the power more or the sound more. You can get a cam that drives and sounds close to stock that will still make good power and be easy to DD but once you get into those really lopey cams the driveabilty will begin to suffer.
Old 01-01-2012, 09:31 AM   #6
Rage
TRI-COUNTY CAMARO... FTW!
Rage's Avatar
Drives: 2010 Camaro 2SS M6 Cyber Grey
You learn to drive with the cam...... takes a little while, but once you dial in how to launch it, you're golden. And yes.... definitely worth it
CAI inc. cold air intake, LG G6x3 cam, Patriot Gold Extreme Dual springs, Titanium retainers and locks, LG SuperPro 1 7/8 Long Tube headers with full 3" exhaust, DynoMax VT mufflers, SLP 4" tips, Moroso catch can, Race Ready electronic exhaust cut outs, Full painted Razzi body kit, Headlight Armor Smoke taillight and marker blackouts, T-Rex aluminum upper and lower grille, Polished aluminum front and rear bowties. Professionally installed and Dyno Tuned by HorsePower Sales, Pompano Beach FL.
Rage is offline   Reply With Quote
Old 01-01-2012, 10:05 AM   #7
20camaro12
20camaro12's Avatar
Good to know everyone. I have an LS3, and I believe that is noted in my Avatar. The LS9 cam might be the way to go since I have a slightly modified car already. I am pretty happy with the power almost at 400rwhp, and its more of the sound, I think, I am going for. This is my true daily driver and if I get a commute in traffic I think the lopey cams are not going to do me any justice. Since I am in afghan for awhile it doesn't really matter right now. I just think it would be kinda nice to make the sound (already to my liking) a little bit more unique and one of a kind. Guess when I get home the best thing would be to listen and drive in camaros with aftermarket cams.
Old 01-01-2012, 11:05 AM   #8
Rage
Rage's Avatar
If u are doing the install yourself, then by all means, go mild. If you are dropping $1500+ on an install, why not get the power at the same time? That kind of money for 20-30rwhp just seems like a waste. But then again..... to each their own.
Old 01-01-2012, 11:14 AM   #9
nycoupe11
Drives: 2011 2ss/rs Summit White
Do it. Your drive to work will be a happy one with all the heads you turn
2011 2ss/RS Summit White / Grey and Black Interior. TSP VVT-2 Cam, ARH heads and Exhaust, CAI, Ported Throttle Body, Plasti Dipped tailight bezels and rims. AAC interior lighting. Tuned by East Coast Supercharging.
nycoupe11 is offline   Reply With Quote
Old 01-01-2012, 11:32 AM   #10
mlee
www.CamaroFans.com
mlee's Avatar
I really don't think you are going to get what you want from the LS9 cam... there are plenty of stage II cams out there with perfect drivability and a cool lope... and FWIW LS3 or M6 is not in your avitar section.
Old 01-01-2012, 12:13 PM   #11
BowlingSS
Camaro Owner Since 1987
BowlingSS's Avatar
Drives: 2011 2SS/RS L99 RJT
I agree. Go with a Stage II cam. You will not regret it.
Bill
2011 Camaro 2SS/RS L99 RJT
CAI, Inc. Cold Air Induction;ADM Scoop
Rx Catch Can;Rx Breather;Roto-Fab Washer Container
VMax Ported RJT Throttle Body
XSPower Headers and XSPower 3" Exhaust System
Elite Engineering Tunnel Brace,
Gorilla Wheel Lock System; Bear Rotors, Hawk HPS
Tinted Windows 35%;EFILive Tune
BowlingSS is offline   Reply With Quote
Old 01-01-2012, 12:21 PM   #12
steeleshark2
steeleshark2's Avatar
My 231/236 is my daily driver. I love it!!
Old 01-01-2012, 12:22 PM   #13
Ivan @ Southwest Speed
I've always subscribed with the whole "if you're going to do it, do it right the first time" mentality.
While the LS9 cam is definitely a straight shoot install with nothing else required, the return on the time spent to actually install it is going to be a letdown.
You're more than halfway into doing a "Stage 2" Cam and the payoff there is exponential.
Let us know if you have any specific questions or needs...we can get you squared away with a selection that will make you more than happy for your money.
Ivan
Old 01-01-2012, 02:19 PM   #14
camslambam
Drives: 2010 SS, 06 SRT10 Ram
I DD with a cammed auto with no converter.
It was a pain the first week but I got use to it fast and the sound is pleasing. You learn to toggle N and D in traffic .
camslambam is offline   Reply With Quote
ULTIMATE CAM Specs/ Info thread for the LS3/ L99!! mike25 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 31 04-29-2014 12:09 PM
Vengeance Racing Stage 3 cam 1977and2010 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 21 08-22-2011 12:55 PM
LS7 Cam For Sale $100 + sh PRICE DROP + 4x 3 bolt cam sprocket for sale PICS ADDED! CAMAR0 V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 0 01-04-2011 01:17 PM
Vector Motorsports Stage 2.5 cam kit installed! pics and video topgun1 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 38 12-18-2010 11:28 PM
Camshaft Basics Milk 1027 Wiki 1 12-09-2009 01:00 AM
