Old 01-01-2012, 12:07 PM   #1
BrandX
Camaro Again?
BrandX's Avatar
Drives: 2016 Camaro SS
Question for those with LT headers
I am thinking about a set of long tube headers for my 2012 LS3 SS. In the past with similar type of upgrades with other vehicles, I noticed some extra noise with LT headers. I am not talking about increased exhaust tone. What I am referring to is noise from the headers themselves consisting of "Ring" or extra noise from the exhaust rushing through the headers (people who know cars will know what I'm talking about) . I actually find it kind of annoying and was wondering if I could expect that from this car. I know material and construction has alot to do with the noise, so any suggestions or opinions are appreciated.
My other thought is to keep the stock manifolds and add a set of Solo High flow Cats. I think the gains would be close.
Thanks for the input.
2SS, NGM, NPP, MRC, 6M, NAV, Blk Bowties, Split Spoke Gray wheels
BrandX is offline   Reply With Quote
Old 01-01-2012, 12:48 PM   #2
Camaro_Custom_Painted
Choke on that causality!
Camaro_Custom_Painted's Avatar
Drives: 2010 2SS/RS
The will certainly give more noise - a sharp 'ring' as you call it - at idle its not much but gets louder from there.
Edelbrock EForce - Stainless Works Headers - BMR Sways & Arms & Toe Links & Control Arm Bushings & End Links - Rotofab CAI - Assorted Interior, Exterior, Underhood Bling - Red Jewel Stripes & Full Body Clear - Lexani LX15 Wheels - JRE Fuel Rail Upgrade - Kenne Bell BAP - Heartthrob XPipe - Elite Catch Can - Pedders Cradle & Front Arm Bushings - Hotchkis Strut Brace - MSD Wires - Carbotech Brakes - DSS 1000HP Axles & Driveshaft - Mickey Thompson Tires - Halo Harness - Granatelli Brake Lines - AutoMeter A/F, Boost, Fuel Pressure Gauges - Whats Next?
Camaro_Custom_Painted is offline   Reply With Quote
Old 01-01-2012, 12:54 PM   #3
blk5genss
blk5genss's Avatar
Drives: 2010 Camaro 1SS/RS
Try your best to ensure that all the bolts and brackets are tightened, other that it's just part of hot rodding!! Lol
TSP Cam 231/236 112 LSA,TSP UD,Fast 102 w/Ported TB,AirAid CAI,1 7/8 catted Stainless Power LT,3 IN MBRP 3 in Exhaust/180*,Spohn LTA's,Toe Links, Drag Bar,Diff bushings,Hurst shifter,Hendrix/DSS 1400HP Axles,Nitto NT555R's,Lethal Performance Custon Tune 480 RWHP 454 RWTQ!! Best run so far is 11.94@121 LPE 3.91's Coming soon NW 102, and DSS DS, then car should be complete!!!
blk5genss is offline   Reply With Quote
Old 01-01-2012, 01:55 PM   #4
BrandX
Camaro Again?
BrandX's Avatar
The reason I asked this is becuase the car is very refined and quiet for what it is on the road. Hoping to keep some of the NVH out of the equation.
NVH= Noise/Vibration/Harshness
Old 01-01-2012, 02:50 PM   #5
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Less NVH and our hobby to modify these cars DO NOT go hand in hand period. If you want to increase the horse power from your camaro then forget about
1. cold air kit because that will make you actually hear the air coming in. FORGET IT
2. Headers forget that too more power more air more noise from your stock exhaust, the tubes will amplify your valve train noise too. AND no solo cats will NOT have the same power results as LT headers SORRY if someone misinformed you. FORGET IT
3. Catback? No because obviously you will increase the noise levels drastically (compared to stock).
YOur ONLY option my friend is "keep it stock and add lots of dynomat".
Old 01-01-2012, 02:52 PM   #6
sschevybear11
sschevybear11's Avatar
Drives: 2011 Black 1SS
Coated dynatechs with out cats and zero extra noise up front.
2011 Black 1SS M6 12.75@110.91 bone stock
Now: Coated Dynatech LT's/!Cats/Hurst Shifter/Roto-fab/SLP SS badges/JRE 415HP Tune, Scoop & Washer Relocation Bottle,Hurst Stunner 20X9 Wheels, Moroso Catch Can, ASP pulley, Magnaflow X-pipe, GTO remote clutch reservoir
1989 Silver 5.0 Mustang LX Coupe
1999 Pewter Tahoe LT
2011 Blue Camry SE
sschevybear11 is offline   Reply With Quote
Old 01-01-2012, 02:56 PM   #7
FRANK121
FRANK121's Avatar
Drives: 2011 Camaro SS
I have noticed what sounds like more valvetrain noise after my LT headers and thought maybe something was going wrong. Is it true that the headers will ampliy that noise? That is good to know if true. I have not noticed any ring as stated but I do have a CAI and that plus the exhaust is all I hear when on the gas
2011 Victory Red 2SS/RS
630hp. and 550ft. lbs.
Black Rally Stripes
6 Speed Automatic
Whipple 2.9L
LS3 Conversion
ARH LT Headers and X-Pipe
GMMP Axle Backs
Yank 2800 Stall
RotoFab CAI
RX Performance Catch Can
VMAX Ported Throttle Body
Built by C.B.I. Streetcars
Tuned By DSX Tuning
GM Quarter Flares
Camaro Floor Mats
FRANK121 is offline   Reply With Quote
Old 01-01-2012, 03:49 PM   #8
geaux_tigerss
geaux_tigerss's Avatar
Drives: 2014 GMC Sierra Denali
It's louder, no question. From the front of my car the valve train noise is louder than the exhaust at idle and my exhaust is LOUD. I also hear the exhaust flow at normal rpms; it is also noticeable above the highway/wind noise at 80. If you listen for it, which it sounds like you would, you will notice it. It's not bad, just noticeable.
That said, I've heard that the ceramic coating option reduces this noise by a considerable degree. I'd find someone local with your build options and ask them to check out their car.
2011 2SS/RS M6 CGM Rotofab CAI, Kooks 1 7/8, Corsa (LS3)
geaux_tigerss is offline   Reply With Quote
Old 01-01-2012, 04:44 PM   #9
Bay Area SS
Bay Area SS's Avatar
Drives: 2010 rs/2ss
My car as well as others I have ridden in that have headers are louder all the way around. Some have weird noises coming from the engine bay as well. Soon as I started modding, the refinedness went out the door.
1 7/8 long tubes full XS Power exhaust no cats, Rotofab CAI, PowderPro Ported TB, Hurst short throw, TSP 231 236 cam, tuned by Synergy Motorsports 454RWHP, 440 RWTQ. More to come!
Bay Area SS is offline   Reply With Quote
Old 01-01-2012, 06:11 PM   #10
BrandX
Camaro Again?
BrandX's Avatar
CAI's do not add the type of noise I am talking about. CAI is on the list of mods coming to this car and they do not add any noise unless you are on the gas!!!!!
Headers can work if they are quality units. I know there will be extra noise and I'm cool with that as long as it is manageable.
A good sounding exhaust with no drone is also acceptable.
I'm not doing sound deadening.
Look I know headers will add noise. What I'm looking for is if it is really noticeable in this car. I do like to carry on a conversation while I drive sometimes.
Old 01-01-2012, 06:17 PM   #11
redirish
redirish's Avatar
Drives: 10' IOM 2SS/RS/M6
Is the ceramic coating the same as the Jet Coat that some get on there Kooks?
redirish is offline   Reply With Quote
Old 01-01-2012, 06:28 PM   #12
casper sc/1ss/rs
casper sc/1ss/rs's Avatar
Drives: 2011 camaro ss vortech supercharged
i am 100% satisfied with sw 2" headers going down the interstate my car is no louder than stock and they added unbelieveble power i went with no cats and left stock from there back because i dont want a loud car i just wanted the extra power, it dont get loud until WOT. hope this helps
casper sc/1ss/rs is offline   Reply With Quote
Old 01-01-2012, 06:54 PM   #13
Smirnoff
Smirnoff's Avatar
Drives: Camaro SS
Keep it stock - if you want performance, go the FI route with stock exhaust manifolds, cats, mufflers.....
11.90's w/headers, CAI, tune, & some high-test (no bling).
Smirnoff is offline   Reply With Quote
Old 01-01-2012, 07:16 PM   #14
MarylandSpeed
MarylandSpeed's Avatar
Drives: 2012 ZL1 & 2010 2SS/RS
Stainless is not as thick as the cast iron manifolds, so you do get a small pinging sound from the front of the car after installing them. I have never found this to be a big deal because it is really not very loud or anoying. Cats helps keep the sound down some to.
443-730-9428 - www.marylandspeed.com - Great Prices and Free Shipping!
MarylandSpeed is offline   Reply With Quote
Bassani LT headers and exhaust The Stig Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 9 09-28-2011 04:25 PM
question about headers LT mydreamcar Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 4 06-14-2011 04:25 PM
LT Headers + Cat Back Exhaust SamSS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 02-15-2010 07:00 PM
Modern Muscle Exhaust and Intake Special modern-muscle V8 Bolt-Ons & Tunes 1 01-20-2010 06:46 PM
