Gen5DIY
Old 01-01-2012, 10:49 PM   #1
gtfitter597
gtfitter597's Avatar
Drives: 2010 2SS/RS
Billet timing set help!
Guys,
I swapped my cam now buttoning everything up.
The instructions with the JP set are very vague. Does the stock crank gear just come off by prying?
Also I feel I have read in the past that the billet timing sets don't use a tensioner?
Any help is appreciated.
Thanks
gtfitter597 is offline   Reply With Quote
Old 01-02-2012, 07:41 AM   #2
flyby
Drives: 2010 Silver SS
use a puller
flyby is offline   Reply With Quote
Old 01-02-2012, 09:57 AM   #3
gtfitter597
Drives: 2010 2SS/RS
Ok....if you need a puller to get it off is there a installer to get back on?
Again, is the tensioner used? I can't find the thread that I thought stated the tensioner is not used.
Old 01-02-2012, 01:38 PM   #4
flyby
use the bolt and washer to draw it back on
Old 01-02-2012, 03:01 PM   #5
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Then make sure you are dot to dot this way.
Old 01-02-2012, 08:21 PM   #6
gtfitter597
Drives: 2010 2SS/RS
What washer? There was no washer w/ crank bolt, are you saying there should be a washer with the puller????
Again what about the tensioner.
Would appreciate someone who has done this to chime in. I have no other issues with the install just need this bit of info.
Thanks
Old 01-02-2012, 08:46 PM   #7
mgoodbar
White 2ss, LT, CAI, Tune
Drives: 2010 L99
use the puller to remove the gear.. you can heat the gear up to reinstall it... a propaing tourch is usually used... do not heat it till it red. just go around it and heat it up to about 400-500 degrease.. it will slide on... dont beat and pry on it.. there is a installer kit some were that has a pipe and a big washer that will fit over your crank shaft and you use the crank bolt to press it back on..... Dont heat the crank shaft up at all.. hold the gear in some channel lock pliers. heat it up some... then put it on the crank. you may still need something round that will fit over the crank that you can LIGHTLY tap on... dont drive it on... you will mess the crank bearings up...
mgoodbar is offline   Reply With Quote
Old 01-04-2012, 07:08 PM   #8
gtfitter597
Drives: 2010 2SS/RS
So for the fourth time....is the tensioner used with the billet set?
Thanks
Old 01-05-2012, 05:15 AM   #9
Stingr69
'69 Owned Since '79
Stingr69's Avatar
If you have the 2-bolt black plastic "bow tie" shown in post #5 then you do not need the original tensioner. Seems like a simple reliable solution and many reputable builders prefer this older style setup over the current production tensioner for reliabillity purposes.
There are some Kent Moore tools that are called out in the service manual to do the R&R. I bought some of them used on Ebay a while back. You could just buy them and resell them after the job is done if you want to save money.
These are used to get the gear off if you can't find a suitable puller.
J-41816-2
J41558
J8433
This is used to install the gear. Also will replace the harmonic damper/pulley assy.
J41478
J41665
a metric nut from Home Depot.
-Mark.
FTI/RX Billet Torque Converter special!! SC2150 Transmission / Driveline 122 07-23-2013 07:19 PM
Empire Billet Black billet bowties SA CHEVY Exterior Parts & Accessories 3 08-13-2011 10:29 AM
NEW Camaro RS Xenon Headlights w/ ORACLE ColorSHIFT Halos- SEMA Demo Set... SAVE! AACstyle Exterior Parts & Accessories 45 01-19-2011 12:18 PM
Billet Custom Products LLC has released a NEW all billet valve cover kit for the 2010 Bruce at Billet Engine Internals 5 11-20-2010 12:14 AM
