JUICEDMOTORSPORTS
Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum All audio, video, bluetooth, nav, radar, and electronics discussions.
Old 01-02-2012, 08:16 PM   #1
Caddyroger
Caddyroger's Avatar
Drives: 2011 RJT Camaro LT2 RS auto shift
Best navigation unit
Which one of the here would be best to get?
1. Pioneer AVIC-Z130BT or
2. Kenwood dnx7180
I am leaning towards the Pioneer.
Caddyroger is offline   Reply With Quote
Old 01-02-2012, 08:20 PM   #2
RED DEMON SS
OFF THE HOOK
RED DEMON SS's Avatar
Drives: RED DEMON!
Just picked mine up with the Pioneer installed with Metra kit, awesome sound and Navigation!
Old 01-02-2012, 08:23 PM   #3
Caddyroger
Caddyroger's Avatar
Thanks. That set up looks very good.
Old 01-02-2012, 08:29 PM   #4
RED DEMON SS
OFF THE HOOK
Drives: RED DEMON!
I am very impressed, no scratches or anything else my car is babied and i was happy with install and installer! I had the best Alpine Double Din Selected and when i went into the shop to see how they were doing i didn't like it at all because of the way it curves at the bottom in the Metra kit, so i had them change it to the Pioneer deck!
Old 01-02-2012, 08:31 PM   #5
simonmcnasty
The Juggernaught
simonmcnasty's Avatar
Drives: 2010 IBM 2SS/RS
Pioneer FTW
2010 IBM 2SS RS / LG G6X3 Cam / 1 7/8" Kooks headers / Hi-Flo Cats / ADM Cold air / Magnaflow 3" exhaust / UD Pulley / Sam Miller Tune / SAE 481RWHP 441RWTQ / Eibach Pro-kit / Eibach front and rear sway bars / Elite Catch Can / DRL Harness and AAC Plasma bulbs
simonmcnasty is offline   Reply With Quote
Old 01-02-2012, 09:06 PM   #6
justonemic
@jbadd
justonemic's Avatar
Drives: Black 2011 ls camaro
Do u know where I can find the bypass info so u can watch movies while driving
justonemic is offline   Reply With Quote
Old 01-02-2012, 09:27 PM   #7
Eich
Drives: '11 SW/Beige 2SS RS Manual
For Pioneer head units, go to avic411.com for bypass info on all models. Lots of good information there.
Eich is offline   Reply With Quote
Old 01-02-2012, 10:14 PM   #8
Ivan @ Southwest Speed
Southwestspeed.net
Drives: '10 2SS/RS, '96 Z28
Damn that looks really good!
Makes me consider swapping this Spring.........
Ivan
Old 01-06-2012, 06:27 AM   #9
Hamilton2400
Hamilton2400's Avatar
Drives: 2011 Camaro ls/2012 GMC Terrain
Kenwood hands down has a better nav than pioneer. Pioneer may have a better user interface, but I would do kenwood. Also better sound quality.
Hamilton2400 is offline   Reply With Quote
Old 01-06-2012, 08:01 PM   #10
Double D Mods
Double D Mods's Avatar
Drives: 2012 Grand Sport Convertible Vette
I agree
Kenwood is the way to go
The new Kenwoods for 2012 are sweet
I will be able to post all info on radios when we get back form CES next Friday
here is the bypass info for a z130bt
First
This is for those who want to know how to perform the bypass on the new Pioneer x930bt and z130bt
I am not recommending this by any means and always stress the safety and messing with this stuff can distract you while driving. So perform at your own risk and be careful whil driving:thumbs::cheers:
For those who want to know how to bypass the safety features on the new X930BT and Z130BT
This is what you will need to do
First you start with the stock harness from Pioneer. Note the yellow mute wire. This is the wire we will be messsing with.
Next step is to pry up the little cover on the connector. After this is done I simply took a razor blade and made two more slits in the connector to allow me to easily remove the yellow mute wire
after cover is up and slits put into it you should carefully pull out the pin and will have this
next step is to simply drop the pin directly below where it was in the harness to start with. Will look like this when pin is inserted. Push it in and you will feel it click into place.
Next step is to take the mute wire you just moved, the light green parking wire, and the black ground (green wire and black are on second Pioneer harness) and twist them together and then you are ready to connect it to the ground wire on the harness you will be using.
and That is it!
All you need to know to bypass the unit and to have full control of NAV and DVD while driving.
AGAIN
We are not recommending this and not responsible for unfortunate mishaps that you could have happen while messing with this while driving.
Dennis
Double D Mods is offline   Reply With Quote
Old 01-06-2012, 08:05 PM   #11
twentytwelvebee
twentytwelvebee's Avatar
Drives: 2012/2ss "transformers edition"
i have a pioneer nav in my truck and its ok, didnt like the fact that i lost the use of my steering wheel controls. i heard kenwood doesnt have that problem.
twentytwelvebee is offline   Reply With Quote
Old 01-07-2012, 08:43 AM   #12
Double D Mods
you just need to add a pac swi-ps or swi-rc or the metra aswc module to the radio is all and your controls will work with your Pioneer
Old 01-07-2012, 09:24 AM   #13
Big Top Gt
Big Top Gt's Avatar
Drives: IOM 2010 2SS/RS (LS3)
Send a message via AIM to Big Top Gt Send a message via Skype™ to Big Top Gt
That site is an incredible resource for Pioneer information. (I've been a member for awhile.)
Big Top Gt is offline   Reply With Quote
Old 01-12-2012, 10:32 PM   #14
Pkrimmer
Pkrimmer's Avatar
Drives: 2011 Black 2SS Convertible
Questions
Does the unit still have the Sirius on it and does it have a backup camara function for adding later?
Pkrimmer is offline   Reply With Quote
Pioneer AVIC Z-110BT Navigation Unit lsuguy Audio / Visual / Electronics/ Gauges / Nav 12 09-13-2011 07:16 AM
Group Buy: SmartMirror Navigation Solution *CHEAP* EVS Motors Inc. Audio / Visual / Electronics/ Gauges / Nav 49 03-31-2010 11:17 AM
Finally a Real Navigation System for the 2010 Camaro! EVS Motors Inc. Audio / Visual / Electronics/ Gauges / Nav 46 02-08-2010 03:32 AM
Finally a Real Navigation System for the 2010 Camaro! EVS Motors Inc. Audio / Visual / Electronics/ Gauges / Nav 21 02-03-2010 06:01 PM
